be quiet! 2023 Thermal Pastes and Light Wings White Fans Pictured
  • Ribbons : 86
2023/01/05 23:52:07 (permalink)
https://www.techpowerup.com/303151/be-quiet-2023-thermal-pastes-and-light-wings-white-fans-pictured
Also at the 2023 International CES, be quiet! showed off its new and upcoming thermal interface materials and new Light Wings lines of case/radiator fans. The DC2 PRO is an enthusiast-grade liquid-metal thermal interface material for high-performance applications, targeting overclockers who know how to handle liquid metal. The company wouldn't put out thermal conductivity numbers but mentioned that the DC2 PRO should be competitive with the best liquid-metal TIMs out there (north of 70 W/mK). The DC2 (non-PRO) is a conventional ceramic base TIM that's electrically non-conductive, and can be used with bare copper surfaces (such as coolers with direct-touch heatpipes). We expect this one's conductivity to be north of 10 W/mK.
be quiet! also showed off its Light Wings White 140 mm fans in two variants, one with a standard RPM range, and another with an undisclosed high-RPM limit. These fans feature high-endurance dynamic bearings, 4-pin PWM control, and 3-pin ARGB control for their addressable RGB LED diffusers along the bore of the frame. These are sold in packs of 3, and include a 6-channel LED controller.
Interesting that be quiet! decided to put out a metal thermal grease. The white fans with white cables also looks very good.
0 Replies Related Threads
