air cooler for x299 dark I9 7940x in place of NHD- 15S
fenice19
Friday, February 08, 2019 10:06 AM (permalink)
Hi, someone can suggest me a good cpu aircooler for this cpu: I9 7940x (not overclocked) and compatible with x299 dark.
My previous cooler NH D15-S ( used with asrock x99) ( in noctua website is listed as mechanicaly not compatible).
i'm using now an AIO but if it'll wail i come back with an air cooler.
Walter
3 Replies Related Threads
    • Ribbons : 282
    Re: air cooler for x299 dark I9 7940x in place of NHD- 15S Friday, February 08, 2019 7:32 PM (permalink)
    I would Not recommend an Air Cooler for your Intel® Core™ i9-7940X X-series Processor on Any Motherboard.
    See this Thread about Air Coolers and the X299 Dark
    Need help finding a CPU Air Cooler that will fit the X299 DARK EATX before I buy.
    roko71
    Re: air cooler for x299 dark I9 7940x in place of NHD- 15S Sunday, February 17, 2019 8:08 AM (permalink)
    I'm using the BeQuit Dark Rock 4 until the watercooled setup is complete.
    This cooler is capable of 4900 Mhz on all cores(9800X) using OC robot. Mind you, this is a 100C celcius plus gig at full load :)  So do not use 24/7 :(
    I am using this setup at stock speeds until all the parts are in to watercool it.
    It is however a verry snug fit, there is a paper thin gap between cooler and vrm fans, see photo.
     PS
    On stock speed it runs at +/_ 40 C, the photo is taken at 4900Mhz
    post edited by roko71 - Sunday, February 17, 2019 8:13 AM
    • Ribbons : 86
    Re: air cooler for x299 dark I9 7940x in place of NHD- 15S Sunday, February 17, 2019 8:47 AM (permalink)
    My suggestion is to use an AIO for that CPU. This is the best solution to cool those processors.
