Why are power supply cables so expensive?
BrandSlav
2019/02/22 19:25:17 (permalink)
I am just wondering why the modular cables for power supplies so expensive? Is it the material or manufacturing costs? Is it harder to make a modular cable than one that is sautered to the psu?
4 Replies Related Threads
    the_Scarlet_one
    formerly Scarlet-tech
    • Ribbons : 79
    Re: Why are power supply cables so expensive? 2019/02/22 19:53:38 (permalink)
    I wouldn’t say it is harder to make a modular cable than it is to solder a cable for a PSU. With the modular cables, there are a lot more connectors and connections that have to be created.
    Soldered cables. PCB, solder, Wire, female or male pin, then appropriate connector.
    Modular cable: PCB, soldered male connections, female connectors, male connectors, female pins, wire, male or female pin, appropriate connector.
    There is a lot more parts going into a modular cable.
    The expense of the main modular cables you see is the individual sleeving as well. That gets very expensive very quick. For most stock wires, all of the wires are put together, and one set of heat shrink and one sleeve is installed, which is seemingly quick and easy versus all of the single wire sleeving.
    Modular is also far more attractive, and makes cable management much easier.
    BrandSlav
    Re: Why are power supply cables so expensive? 2019/02/22 22:39:49 (permalink)
    I never thought there would be much to a cable, but I was wrong. Hopefully prices shrink in the near future and modularity becomes more affordable to the average consumer
    Vlada011
    • Ribbons : 11
    Re: Why are power supply cables so expensive? 2019/02/23 05:28:17 (permalink)
    Several time I saw discounts for around 50$, full sets.
    That's not too much.
    http://www.evga.com
    http://www.intel.com
    http://www.nvidia.com
    https://watercool.de
    http://www.lian-li.com
    BrandSlav
    Re: Why are power supply cables so expensive? 2019/02/23 16:35:36 (permalink)
    Well compared to power supply prices which for 60 on b-stock you can buy a 550w g3 with the modular cables. For someone on a budget buying 50 dollar cables is out of the question.
    post edited by BrandSlav - 2019/02/23 16:41:46
