Re:Weird green pixels showing up on monitor. Need Help.
2009/11/30 10:40:43
I get the green pixels on the HD TV I have for my PS3. It's usually, for me at least, the HDMI cable wiggled out a little bit and all I do is reconnect the cable. It usually happens if the cable is hit or the table that has my HD TV on gets moved.
So much work to do... someone has to do it.
