Helpful ReplyWater cooling Xbox 360
fsuwade
Sunday, March 21, 2010 7:12 PM (permalink)
So you have an Xbox 360. Well you’re playing and then the big RROD shows up. Well I have an idea that might help keep that from happening. Yes most will say that this is kind of over kill but I wanted to make sure the RROD does not come back. Yes I could have spent my money on a new one but what is the point you just keep throwing away money when this happens. So I put this together hope you like it.
What you will need:
  1. RROD Xbox 360- worthless right now.
  2. Lian Li  XB-01 Xbox 360 case – 119.99 x 1
  3. XSPC Xbox 360 CPU/GPU Water block- 42.95 x 1
  4. Swiftech MCP655 12v DC Pump - with Speed Controller- 76.95 x 1
  5. Swiftech MCR120-QP Quiet   Power 120mm - Black MCR120-30.95 x 1
  6. Bitspower G1/4 True Silver 1/2in Fitting BP-SLWP-C01    3.25 x 4
  7. Bitspower Shining Silver Rotary 45 G 1/4 Threads # BP-45-R 9.95 x 3
  8. Bitspower 1/2in. Compression Fittings for 3/4in. BP-CPF-CC5 5.95 x 2
  9. Bitspower Silver Shining Rotary 90-Degree G1/4 Adapter - BP-90R- 9.95 x 2
  10. Bitspower Water Tank Z - POM Version 39.99 x 1
  11. Enzotech BCC9 / BMR-C1L  Low Profile Forged Copper-12.50 x 8
  12. Arctic Cooling MX-2 Thermal Compound- 26.95 x1
[size=5 font="times new roman"]This is what the XB-01 case looks like:
[size=5 font="times new roman"]Now for the work:
As most of you have already seen how to take apart an Xbox and I am not going to go threw all that for you but if you do this mod the XB-01 Case comes with a book on how to take it apart.
What she looks like taken apart all the way and cleaned up as well.
You may ask, how are you going to power the pump? Well here is how I am. I am going to add a 4 pin Molex connector to the Xbox and then I will have power for the pump, fans, and lights once I get some. If you have questions just pm me before doing this.
[size=3 font="times new roman"]
Now for the block so much copper:
Now I did have to Mod the case a little to get the pump wire behind the MB tray but here is what it looks like. I needed to cut just the corners out of the bottom of the tray.
Time for putting ever thing in:
Now for the test:
Taking an Xbox 360 from the death to live another day. Could not ask for anything better. Time for some MW2 come get some.
post edited by fsuwade - Sunday, March 21, 2010 7:27 PM
    Heatware - fsuwade01
Phoenixx45
  • Ribbons : 8
Re:Water cooling Xbox 360 Sunday, March 21, 2010 7:30 PM (permalink)
Wow dude, that's tight as hell! Looks incredible!
White Widow - NZXT 810
Processor: Intel Core i7 2700 @ ?
Memory: 8GB Corsair Dominator GT
Hard Drive(s): 1. 2x 120Gb Vertex 2 SSD 2. Raptor 70GB   3. Raptor 300GB   4. Western Digital 1TB
Video Card: 3x EVGA GTX 480 w/ Back Plate & HF Bracket in SLI
Sound Card: X-Fi Titanium Fatal1ty Champion Series
Motherboard: EVGA z68 FTW
fsuwade
Re:Water cooling Xbox 360 Sunday, March 21, 2010 7:34 PM (permalink) ☄ Helpful
thank you i spent like 12 hours getting it put together yesterday. and the reason it took so long is becasue i am not that good at soldering. but getting better hahah. i hope this helps some of you out there with your issue. its not all dead and gone. i got this xbox for my office. and bought it RROD just to do this mod. and its been holding strong 8+ hours tested on it.
Phoenixx45
  • Ribbons : 8
Re:Water cooling Xbox 360 Sunday, March 21, 2010 7:55 PM (permalink)
Did you have to replace any parts?
sims36
Re:Water cooling Xbox 360 Sunday, March 21, 2010 8:28 PM (permalink)
bud thats handy work at its best!
NEW MADNESS IN THE WORKS......STAY TUNED!!
HEATWARE: sims36
fq360
Re:Water cooling Xbox 360 Sunday, March 21, 2010 8:34 PM (permalink)
i managed to bring mine back to life from RROD - wish id thought of using water instead of new blocks
nice work
http://www.heatware.com/eval.php?id=67853
DD black tower 21 -- 3 x Asus VG236H Monitors 3d Vision Surround  -- Silverstone Strider 1500w psu --
EVGA X58 Classified -759 -- I7 980x  (4.2ghz) On Air!! -- 3 x 60g Vertex Turbo SSD (Raid 0) --
Noctua NH-U12P -- 1 x Gigabyte GTX 590 -- 12gb Corsair Dominator GT 2000mhz -- pioneer bluray/re --
Win 7 Ult x64
fsuwade
Re:Water cooling Xbox 360 Sunday, March 21, 2010 8:53 PM (permalink)
yeah i am using the fan from the lian li case for the rad. and the block is the only thing that i had to replace on the xbox. the pump turns on when the xbox turns on as well. i just wished i had got a temp sen. for it to see what the temps were on the gpu and the cpu.
just a noob
Re:Water cooling Xbox 360 Sunday, March 21, 2010 9:27 PM (permalink)
Nice build, one thing I've always heard is, that if you start running other things off the xbox, that can that get you banned, is it true? Also, is that first picture of your xbox, is that the modern warfare 2 version, or is it something you did yourself? Because that's an awesome color/finish in my mind.
hanniable
Re:Water cooling Xbox 360 Sunday, March 21, 2010 10:07 PM (permalink)
 I have to say that I think every xbox should come like that.
A.K.A wiseguy127
fsuwade
Re:Water cooling Xbox 360 Sunday, March 21, 2010 10:48 PM (permalink)
just a noob
well yeah you can but that is if your using some kinda mod chip. but i am not. i just taped into the power to run the pump and leds once they come in.
as far as the color its just the regular elite 120. so but yeah i like it. i just wished i had more time for some other things i wanted to do with it.
josediaz
Re:Water cooling Xbox 360 Sunday, March 21, 2010 11:07 PM (permalink)
Wow great job On water cooling the Xbox.  How did you know where to solder the power for the pump if you dont mind me asking?
HEATWARE
CPU: i7-920 (D0) @ 3.33 MOBO: X58 (758)
GPU:2 x EVGA GTX 580 RAM: 3x2 DDR3 1333 Mushkin
CASE:Corsiar 800D  PSU: Corsiar HX1000
xxrabid93
  • Ribbons : 8
Re:Water cooling Xbox 360 Sunday, March 21, 2010 11:08 PM (permalink)
Sick! Where does the hdd go though? I don't see it?
fsuwade
Re:Water cooling Xbox 360 Monday, March 22, 2010 0:28 PM (permalink)
josediaz
well i can not remember where i found it but i think i found it some where over a xbox scene. but i can not remember.
fsuwade
Re:Water cooling Xbox 360 Monday, March 22, 2010 0:53 PM (permalink)
xxrabid93
yeah i was not happy with the way they did that. but its in one of the pics with the case its self, its just a little hard drive slot that you have to take apart the hard drive to put it in there.
so i think i might try to find and extender cable to mod the hard drive to be hot swapable.
Gone Cruising
  • Ribbons : 45
Re:Water cooling Xbox 360 Monday, March 22, 2010 3:04 AM (permalink)
Sweet man!!! Good job!!!
Now off to the next project!!!!
....or you'll go insane...LOL!!!
Gigabyte Z390 Aorus Ultra
Intel Core I9-9900K
Corsair 32gb DDR4
EVGA RTX 2070 Super
EVGA 850W Gold
2 x 1TB Samsung SSD
2 x 3TB HD's in Raid 1
Kustom Case
https://www.heatware.com/u/67033/to
fsuwade
Re:Water cooling Xbox 360 Monday, March 22, 2010 6:31 AM (permalink)
yeah i about lost my mind with this one. but now its one that i can pass on soon to other to check out. try so give it ago. i will say its been one of the cleanest builds i have done.  so i will be happy once i get the hard drive fixed.
fsuwade
Re:Water cooling Xbox 360 Tuesday, March 23, 2010 6:24 AM (permalink)
josediaz
hahah i found it i had save it a while back and just found another time. so here is the link. but i will say and warn that if your xbox psu is not 200 and above then this might cause issues down the road. so keep that it in mind. but  here it is http://forums.xbox-scene.com/index.php?showtopic=613160
post if you want what you have done as a mod as well to your xbox in pics and lets see if it is something that i might try.
i am still looking for the mod to make the hard drive longer so that i can use any hard drive with out modding it, out side the case.
now if you can post it or link that i will try it if i can and or if i think i will work.
kickthecans
Re:Water cooling Xbox 360 Tuesday, March 23, 2010 7:04 AM (permalink)
wow this is amazing
good job, i wish i had an xbox
and watercooling
and that case, hahahahha
Asus P8P67 Pro •Sapphire 6950 Unlocked 976Core • Core i7 2600K@ 4.5Ghz  • 64GB C300
Samsung Syncmaster 2343BWX 2048X1152 • OCZ ElitexStream 800w • Lian Li V2000 Partial Mod
4GB Mushkin Ridgeback 6-8-6-20 1600• Asus Xonar DX • Windows 7 x64 Ultimate
{uZa}DOA
  • Ribbons : 15
Re:Water cooling Xbox 360 Tuesday, March 23, 2010 1:21 PM (permalink)
Very interesting! Well Hmmmm I have a Xbox360 just collecting dust... At least if I do this it would be a conversation piece...
+1 great job
Bruno747
  • Location: Looking on google to see what Nvidia is going to o
Re:Water cooling Xbox 360 Tuesday, March 23, 2010 3:03 PM (permalink)
awesome soldering job there bubba, next time maybe some flux will help out?
But otherwise neat build, I did my old 360 liquid cooled in the original case with a dual 120mm rad mounted outside.
X399 Designare EX, Threadripper 1950x, Overkill Water 560mm dual pass radiator. Heatkiller IV Block Dual 960 EVO 500gb Raid 0 bootable, Quad Channel 64gb DDR4 @ 2933/15-16-16-31, RTX 3090 FTW3 Ultra, Corsair RM850x, Tower 900
Legend83
Re:Water cooling Xbox 360 Tuesday, March 23, 2010 6:53 PM (permalink)
I got a question for you on this water cooling build. I have heard around that the wireless range is drastically reduced since the case is metal and it interferes with with RF signal. have you notice this at all with this build. If not I have 2 Xbox 360 at home with RROD and this is going to be my next project.
Thanks,
Eric
Halo_003
  • Ribbons : 51
Re:Water cooling Xbox 360 Tuesday, March 23, 2010 7:03 PM (permalink)
Very nice. I've never seen a watercooled 360. I do have one question though, that I know all of us are wondering...
Can it run Crysis?
i7 7700K - ASUS Maximus IX Apex - 16GB G.Skill TridentZ RGB 3466MHz C16 - 5700 XT 50th Anniversary
fsuwade
Re:Water cooling Xbox 360 Wednesday, March 24, 2010 3:14 AM (permalink)
Legend83
Thanks,
Eric
i really have not tested that that much but most your normal ops will be done with the xbox controler for at least me. but as far as i have tested i have not had any issue just yet so i would have to say no for now. but will test more later on.
#23
fsuwade
Re:Water cooling Xbox 360 Wednesday, March 24, 2010 3:19 AM (permalink)
Halo_003
Can it run Crysis?
haha yeah once the port is done and that will from what i read is like Q4 2010. so in short               YES!!!!!!!
#24
Gone Cruising
  • Ribbons : 45
Re:Water cooling Xbox 360 Thursday, March 25, 2010 6:13 AM (permalink)
Did you get that new reservoir installed yet?
btw, where's your Blue Ribbon for this unique build?
Intel Core I9-9900K
Corsair 32gb DDR4
EVGA RTX 2070 Super
EVGA 850W Gold
2 x 1TB Samsung SSD
Kustom Case
#25
qzwfcj
Re:Water cooling Xbox 360 Saturday, March 27, 2010 4:15 AM (permalink)
good job dude
#26
fsuwade
Re:Water cooling Xbox 360 Saturday, March 27, 2010 5:28 AM (permalink)
haha not sure.
but i think what i will have to do is get a xbox that is really messed up and take the hard drive port off the board and then extend it with wire to the top or some where on the case so i can get the hard drive to work the way i want but just need the xbox to find to do that with. ahha. well it will be a min before i get that done.
now on to the next project.
#27
dieman566
Re:Water cooling Xbox 360 Saturday, March 27, 2010 1:29 PM (permalink)
I like the idea of modding a console.  I however done like Xbox that much never have but ive seen a window mod done in a xbox from mnpc and i liked it alot!
Don't forget to protect your investment click on the picture below to register your new product and give me credit!
#28
seth89
  • Ribbons : 14
Re:Water cooling Xbox 360 Sunday, March 28, 2010 8:38 PM (permalink)
very cool. were did you get that case?
#29
just a noob
Re:Water cooling Xbox 360 Sunday, March 28, 2010 10:40 PM (permalink)
seth89
Newegg had it, the last time I looked into doing this
#30
