AnsweredTrying to control RGB for 1080gtx Precision X1 does not have an RGB or LED icon
mnevgafan
2023/05/18 19:47:44 (permalink)
My card definitely has RGB.  I have a new case, and because it has glass panels I can actually see the RGB now.   Problem is, my chair and the case is positioned in a position where the side of the LED is really annoying.   I would like to be able to control the RGB or I would also accept just turning it off.
I installed precision x1 and have seen some videos of how to adjust the RGB.  Looks pretty straight forward, but at the top of the page it only has a vga 1, hwm, power, and rebar icons.   There is supposed to be another icon for LED< but it's not present.
My card is an evga 1080gtx ftw dt gaming, it has rgb.
Thanks for any help!
  • Ribbons : 123
Re: Trying to control RGB for 1080gtx Precision X1 does not have an RGB or LED icon 2023/05/18 20:13:25 (permalink) ☼ Best Answerby Hoggle 2023/05/19 08:14:02
Welcome to the EVGA Forums & Congrats to your first Thread
with a 1080 GPU you may need to use EVGA Precision XOC .... that was the GPU software when the 1080 was new
https://www.evga.com/precisionxoc/Default.asp
FYI - set the LED to black = Off
Also found this it might also be of help to control LEDs (I'm not sure, it is also older software from Nvidia)
GeForce Experience GeForce GTX LED Visualizer User Guide
CirkEVGA
Re: Trying to control RGB for 1080gtx Precision X1 does not have an RGB or LED icon 2023/05/18 21:09:06 (permalink)
Thanks a ton!  Your post was spot on!
Hoggle
Re: Trying to control RGB for 1080gtx Precision X1 does not have an RGB or LED icon 2023/05/19 08:15:04 (permalink)
Hope you enjoy the 1080. It’s an older card now but still plays everything it seems just fine unless you have to have ray tracing.
