THEEDUUDE
I'm curious, how much power is everyone's 3090FTW3 pulling, OC/No OC. Also, anyone daisy chain at least one of the power leads, and is it stable? I have a Seasonic 850w Gold PSU.
vapinghanso
Re: Total power draw, 3090FTW3
2020/10/13 17:24:22
THEEDUUDE
2020/10/13 17:26:56
vapinghanso
2020/10/13 17:40:52
THEEDUUDE
2020/10/13 18:04:12
This coming from first hand exp? Or rumors/bandwagon?
akaash00
2020/10/14 03:57:07
BRB when Schrödinger’s GPU box arrives in The Netherlands and it exists...
Intel i9 7900x 4.7 GHz@1.215v - Corsair H115i Aio EVGA 3090 FTW3 Ultra -> Got PCB v1.0 after v0.1 died. Asus Rampage VI Extreme Motherboard G Skill Trident Z RGB 32gb 3200mhz (16-18-18-38) Samsung 960 PRO M.2 SSD 1TB Corsair HX1000i 1000 watt PSU 80+ Platinum LG 27GN950-B (4k 144 Hz !) Lian Li PC-011 Dynamic XL White ROG Certified
chumeniuk
![](//www.evga.com/community/modsRigs/images/sm_mods_off.gif)
2020/10/14 04:57:11
107% on the power slider is not enough. GPU-Z shows anywhere between 400-450w of usage. I've been tempted by the Strix vbios, but not sure it's worth it beyond benchmarking as games run well above 60fps at 4k.
Aurummorituri
2020/10/14 05:12:28
Overclock.net has most card BIOSes uploaded and logged. 3090 FTW3 BIOS reads 450W max. The Strix is 480W, but it's kind of pointless as it pushes temps into the 80's without max fan speed. Remember, these coolers are not much bigger than last year's, yet the chip is pulling 100W more. They are going to struggle.
justin_43
- Ribbons : 7
2020/10/14 05:22:36
Hopefully EVGA will decide to release a VBIOS of at least 480w, the same level of the ASUS strix for these cards in time for the release of full cover waterblocks. I'd hate to be power limited of I'm not temperature limited. But then again I'd like to just be able to actually purchase a card at this point.
ASUS RTX 4090 TUF OC • Intel Core i7 12700K • MSI Z690 Edge WiFi • 32GB G.Skill Trident Z • EVGA 1600T2 PSU 3x 2TB Samsung 980 Pros in RAID 0 • 250GB Samsung 980 Pro • 2x WD 2TB Blacks in RAID 0 • Lian-Li PC-D600WB EK Quantum Velocity • EK Quantum Vector² • EK Quantum Kinetic TBE 200 D5 • 2x Alphacool 420mm Rads LG CX 48" • 2x Wasabi Mango UHD430s 43" • HP LP3065 30" • Ducky Shine 7 Blackout • Logitech MX Master Sennheiser HD660S w/ XLR • Creative SB X-Fi Titanium HD • Drop + THX AAA 789 • DarkVoice 336SE OTL
Cadillac94pimpin
2020/10/14 08:18:15
justin_43 Hopefully EVGA will decide to release a VBIOS of at least 480w, the same level of the ASUS strix for these cards in time for the release of full cover waterblocks. I'd hate to be power limited of I'm not temperature limited. But then again I'd like to just be able to actually purchase a card at this point.
Based on past releases, do the Hybrids come with a higher power limit compared to the non Hybrids?
i9-9900K EVGA 3090 KPE (PUSH PULL) MSI Z390 MEG ACE 32 GB 3200 MHZ CORSAIR H150i Pro WD BLACK SN750 SEASONIC 850W Focus Gold+ Lian Li O11D XL + 10x LL120s+3xML 120s
Robob
2020/10/14 08:57:15
I have 750W and non oc my UPS only reported max draw of 630w with PC and monitor during folding@ home full load test. after OC of card/CPU UPS reported max draw of 753w peak with PC and Monitor during folding @ home testing. So 850 will be plenty for stock or OC
post edited by Robob - 2020/10/14 08:59:36
CPU - Intel i7 10700K @ 5Ghz / 1.29v Heatsink - EVGA 280mm CLC Motherboard - EVGA Z490 FTW (V1.10) RAM - 32Gb Corsair LPX DDR4 3200Mhz GFX - EVGA RTX 3090 FTW3 Ultra (10Ghz Mem/2100Mhz Core) SSD - Samsung 970 Pro 512GB M.2 PSU - EVGA G3 750w Case - Corsair Carbide 678C Monitor - LG 27GN950B 4k@144Hz OS - Win 10 Pro x64 HID - Corsair K70 / EVGA X17 HMD - Valve Index & Controllers Past EVGA MB - 680i/750i/Z68 Past EVGA GFX - 8800/275/560Ti/680SC/Titan(Kepler)/1080Ti
justin_43
- Ribbons : 7
2020/10/14 10:09:45
Cadillac94pimpin
I don't know. I've never used a hybrid card. Not sure if cooling performance is near a true watercooled card or not. But really it would be nice if they would release a higher limit BIOS for all 3 pin 3090s. The cards do have a temp limit where they will shut down anyway if someone were to over stress the card without proper cooling.
post edited by justin_43 - 2020/10/14 10:12:47
arestavo
- Ribbons : 77
2020/10/14 11:38:32
Aurummorituri Overclock.net has most card BIOSes uploaded and logged. 3090 FTW3 BIOS reads 450W max. The Strix is 480W, but it's kind of pointless as it pushes temps into the 80's without max fan speed. Remember, these coolers are not much bigger than last year's, yet the chip is pulling 100W more. They are going to struggle.
My card hovers around 70C with auto fans on the 450W OC VBIOS (3090 FTW3 overclocked hovers around 1950 to 2000MHz, and +750 on the VRAM) even under the most stressful loads (which include Folding @ Home's new CUDA enabled work units (running all day)). Yet I have great airflow because my case has two fans on the removable side blowing cool air directly onto the card - lots of folks complain about the temps, but don't have cases with side fans that used to be standard. Under full (CPU/GPU) stress testing, my rig pulls about 1KW from the wall. Idle is around 330W at the wall. Full specs in the ModRigs link. GPU only being fully loaded & overclocked - about 750 watts from the wall, GPU-Z reports 400 to 450 watts for board power, with it staying mostly right around 400W when Folding. Interestingly, while Folding I'm seeing 123% power limit in PX1 even though PX1 shows a 107% max limit (it bounces, but hits over 120% most of the time) - that's with GPU-Z reporting a fairly steady 400W board power draw.
post edited by arestavo - 2020/10/14 11:54:24
AHowes
- Ribbons : 27
2020/10/14 11:42:51
Just buy a 1000watt gold rated psu and rest assured your covered.
My 2080ti kingpin and 9900k at 5 2 maxes out around 650+ watts on a bench.
ehabash1
2020/10/14 12:21:16
last time the kingpin bios did not work with the 2080ti ftw3 unfortunately. Our best bet might be an xoc from evga when you compare the 3080 bios, going from 400w to 450w is a huge gain of 12.5% power. going from 450 to 480 is only 6.5% gain and because of the high consumption, it wont be used properly without a waterblock. Ideally we will get a 520-525w bios to play with
justin_43
- Ribbons : 7
2020/10/14 12:41:02
ehabash1 Ideally we will get a 520-525w bios to play with
That would be ideal. No real reason they can't, I just don't know if they will. They seem to limit power so much now due to RMA concerns. If only water coolers would use the BIOS they would be fine but of course people with air will still flash it anyway. I wish bioses were still moddable. Or better yet back to no power limits at all.
post edited by justin_43 - 2020/10/14 12:43:42
chumeniuk
2020/10/14 13:21:09
What benchmark/stress test is the best for seeing if a card is able to get the advertised power draw? At default settings, I'm around 350W board draw and average around 1735 core in Port Royal. The PerfCap Reason is Pwr over the entire run. To see if this was an issue with the rest of the system, I swapped the card into another, updated all drivers and seeing the same behavior. System 1 AMD 3970X 64GB DDR4 3600 CL16 Asus ROG Zenith Extreme Season Prime Ultra Platinum 1000W EK block on the CPU Enthoo 719 Case System 2 Intel 9900K @ 5Ghz all core 32GB DDR4 3200 CL16 Asus ROG Code EVGA G3 1000W Corsair AIO CPU on the exhaust side NZXT H700 The card would draw 450W+ prior to the latest PX1 firmware update and Nvidia driver update. If necessary I can always rip apart my ITX build which has a 10700k/2080 Super and see if that cpu/board make a difference but not sure it's worth it.
kirbyrj
2021/05/22 08:23:06
I've been playing through AC: Valhalla: Wrath of the Druids, and my EVGA 850W Gold PSU trips occasionally with a 3090 FTW3 and a 5950X. I guess I'll have to either flip the bios switch to use less power or upgrade the PSU.
arestavo
- Ribbons : 77
2021/05/22 15:14:47
kirbyrj I've been playing through AC: Valhalla: Wrath of the Druids, and my EVGA 850W Gold PSU trips occasionally with a 3090 FTW3 and a 5950X. I guess I'll have to either flip the bios switch to use less power or upgrade the PSU.
If it's a GA model RMA it - the GA originally had an issue with 3080s and 3090s that was fixed a couple months ago. Just make sure to let EVGA know about your 30 series card causing reboots/shutoffs and they should get you the fixed version.
