lil.looka
Saturday, January 19, 2019 7:20 PM
I know this isn't really a place for this, but there is no forum about tik tok problems. Basically, I have the samsung grand neo i9060, and i wanted to try and make a video. So i started recording and as i was recording, it was normal. Until i wanted to see the video, the screen had a red glow over it. Here's the picture:  Does someone know how to fix this? Thanks for help in advance.
mike406
- Ribbons : 13
Re: Tik tok problem with camera...
Saturday, January 19, 2019 9:36 PM
☼ Best Answerby lil.looka Sunday, January 20, 2019 3:18 PM
Reinstall the app? Does it happen with the stock camera app?
lil.looka
Sunday, January 20, 2019 3:47 PM
No, nothing happend. Its still the same. And, on my default camera app is normal.
Tyver
Sunday, January 20, 2019 5:47 PM
Try other apps with cameras and see of they do the same thing. I know you said the stock camera app is fine but just to get more to compare it to. Could be a issue with the Tik Tok app itself and how its behaving when interacting with your phone. If you have another device, try the Tik Tok app on said device and see if it behaves the same way. I know this wont help you fix it but it would help you isolate the problem to only your current phone, especially since a reinstall didnt help.
Just a novice following the dream to be a master
lil.looka
Monday, January 21, 2019 3:39 PM
Nope. Its working on other 3 apps i tried and still tik tok camera doesen't work.
Tyver
Monday, January 21, 2019 3:54 PM
I would say its specifically something with the TikTok app and how it interacts with your device. Only things I can say is contact TikTok themselves, reinstall the app and delete all residual data on your phone when doing it, make sure the app and your phone are as up to date as possible, or if you're really wanting the app then see if a factory reset does anything.
lil.looka
Monday, January 21, 2019 3:57 PM
Ok, thanks for the help. I will see what happens, if it still doesen't work, maybe i won't use the app.
Hoggle
Monday, January 21, 2019 4:11 PM
It almost looks like it is recording the light sources and what is in focus. My Sony RX10 camera has an option to use a mode like that so you can tell what is in focus and what is not.
