bobmitchMy second rig is an EVGA X299 FTW K with an i7 7820X running at 4.6 GHZ all core. The CLC 280 keeps the CPU pretty tame. I set it up to ramp up and down with CPU temps and with load, I see mid 70s pretty consistently. Easy to install. I have never had any issues with the software (Flow control). All in all...pretty satisfied! The only reason I don't have one on my new system is that Flow Control has about a 10C offset with AMD...and Corsair is very accurate.
bobmitchThe kit that comes with the CLC 280 should work on LGA 1200. Just use the parts that come with it for 1151
jimmy8xI just got a CLC 280 and a couple things about it are really irking me. LED sync doesn't work with GPU (FTW3 3080.. honestly a big reason I went with it was to rep the EVGA name on the CPU block and have it sync with my 3080...)Flow Control pump software forces the fans to run at 1050 RPM minimum! They should be able to run at 650 RPM, and in fact they do run at this speed, before you install the Flow Control software.. There is no way to get them below 1050 RPM after installing EVGA's own software to control the thing!
donta1979jimmy8xI just got a CLC 280 and a couple things about it are really irking me. LED sync doesn't work with GPU (FTW3 3080.. honestly a big reason I went with it was to rep the EVGA name on the CPU block and have it sync with my 3080...)Flow Control pump software forces the fans to run at 1050 RPM minimum! They should be able to run at 650 RPM, and in fact they do run at this speed, before you install the Flow Control software.. There is no way to get them below 1050 RPM after installing EVGA's own software to control the thing!So a better option may to run them off the board and set the speed in the bios?
_2100_donta1979jimmy8xI just got a CLC 280 and a couple things about it are really irking me. LED sync doesn't work with GPU (FTW3 3080.. honestly a big reason I went with it was to rep the EVGA name on the CPU block and have it sync with my 3080...)Flow Control pump software forces the fans to run at 1050 RPM minimum! They should be able to run at 650 RPM, and in fact they do run at this speed, before you install the Flow Control software.. There is no way to get them below 1050 RPM after installing EVGA's own software to control the thing!So a better option may to run them off the board and set the speed in the bios?This is how I have mine set up. I used the usb from the pump to set the pump speeds at astound 90% as well as to occasionally change the led color, and have the fans running to my fan hub. Running a 9700k at 5.0 all core and temps struggle to break 50 in a house currently set to 65 degrees F. The temps will go up to high 60s if I use the CPU for folding, which I don't. My usually work day and gaming sees a max of around 51 with the occasional spike to 55. I tried out the LED Sync just recently, and it was meh at best. Worked fine for about a day or so. Now I just have both my GPU and the pump set to a static color that matches each other, and my led strip runs the rainbow pattern. Removed LED Sync from the machine.
jimmy8x_2100_donta1979jimmy8xI just got a CLC 280 and a couple things about it are really irking me. LED sync doesn't work with GPU (FTW3 3080.. honestly a big reason I went with it was to rep the EVGA name on the CPU block and have it sync with my 3080...)Flow Control pump software forces the fans to run at 1050 RPM minimum! They should be able to run at 650 RPM, and in fact they do run at this speed, before you install the Flow Control software.. There is no way to get them below 1050 RPM after installing EVGA's own software to control the thing!So a better option may to run them off the board and set the speed in the bios?This is how I have mine set up. I used the usb from the pump to set the pump speeds at astound 90% as well as to occasionally change the led color, and have the fans running to my fan hub. Running a 9700k at 5.0 all core and temps struggle to break 50 in a house currently set to 65 degrees F. The temps will go up to high 60s if I use the CPU for folding, which I don't. My usually work day and gaming sees a max of around 51 with the occasional spike to 55. I tried out the LED Sync just recently, and it was meh at best. Worked fine for about a day or so. Now I just have both my GPU and the pump set to a static color that matches each other, and my led strip runs the rainbow pattern. Removed LED Sync from the machine.Out of curiosity, do you know what your liquid coolant temp peaks at? & How fast do you have the fans going when at full load?
tattude69Purchased to replace 4 year old Corsair H100i very disappointed. Flow control serves no real purpose other then lighting control.(HW info) will read all sensors for CLC. Fans are very loud. Radiator fans are pigttailed from cooler which is single 4 pin fan connector for all power.If radiator fans are connected to cooler it will ramp fan speeds up at 60c. I removed mine after a few weeks sold on craigslist. The only reason to buy this cooler is if you want the Evga logo with RGB as your cpu block. To be fair this product gave me the motivation to build a custom loop. So in the end that was a great thing and the guy I sold the CLC 280 for $70 was happy.
