Thermaltake Unveils TOUGHFAN 12 and 14 High Static-Pressure Radiator Fan White Edition
  • Ribbons : 86
2021/12/23 01:16:36 (permalink)
https://www.techpowerup.com/290157/thermaltake-unveils-toughfan-12-and-14-high-static-pressure-radiator-fan-white-edition
Thermaltake, the leading PC DIY premium brand for Cooling, Gaming Gear, and Enthusiast Memory solutions, unveils the new TOUGHFAN 12/14 High Static Pressure Radiator Fan White to add some flair to the original TOUGHFAN series while continuing to achieve superlative cooling results. The multicolored TOUGHFAN series become more comprehensive with a series of colors including Black, Turquoise, Racing Green and White for the TOUGHFAN 12, and Black and White for the TOUGHFAN 14.
Alike all the TOUGHFAN series products, the TOUGHFAN 12/14 High Static Pressure Radiator Fan White Edition guarantees quiet cooling performance, outstanding stability, and superior lifespan. The TOUGHFAN 12/14 White features a high static pressure fan with PWM-control, allowing the fan to perform at a maximum operating speed of up to 2000 RPM while maintaining a low audio noise level of only 22.3 dB-A. The centerpiece of the TOUGHFAN 12/14's motor hub is made of full steel and copper housing that reinforces the shaft, which can help to enhance the stability and durability as well as lower noise level while the fan is operating. The anti-vibration rubber pads attached to the corners also helps dampen the vibration and protect the fan as well as the case. Besides, an optimized second-generation hydraulic bearing in a unique structure design allows lubricant to concentrate in lubricating the critical areas, better reducing friction and further extending the fan's lifespan.
The fascinating appearance of TOUGHFAN 12/14 White is a highlight which cannot be neglected. Installing the white-color fans is like putting the finishing touches on your PC builds. The fan blade is made from liquid crystal polymer (LCP) compounds that are very tensile in strength; their low thermal expansion coefficient can reduce the fan's vibration under full-speed load. The fan blades of White Edition are in the color of light gray with a pearl reflection, being elegant and extremely stunning for an all-white build.
The TOUGHFAN 12/14 High Static Pressure Radiator Fan White is available for purchase now. PC enthusiasts who are looking for both functional and beautiful fans for your PC, or those who are keen to build an all-white setup, don't miss out!
Availability and Warranty
The TOUGHFAN 12/14 White High Static Pressure Radiator Fan is available for purchase via the Thermaltake worldwide network of authorized retailers and distributors. Fans are backed by a two-year warranty and supported by the Thermaltake worldwide customer service and technical support network.
The warranty is good. Hopefully the price will be equally good.
0 Replies Related Threads
