Thermaltake Outs Toughpower PF1 ARGB Power Supply Series
  • Ribbons : 86
Thursday, April 25, 2019 5:36 AM (permalink)
https://www.tomshardware.com/news/thermaltake-toughpower-pf1-argb-psus,39160.html
Thermaltake today rolled out the Toughpower PF1 ARGB of high-end power supplies. Available in three high-Wattage models of 850W, 1050W, and 1200W, these PSUs are characterized by their large 140 mm Riing Duo 14 RGB fans, and addressable RGB LED embellishments along both sides of the body, which together make up 18 diodes. To control the lighting, the PSU plugs into a 3-pin addressable RGB header of your motherboard or lighting controller. In the absence of external control, you can cycle through built-in lighting presets by pushing buttons at the tail end of the PSU, located sufficiently away from the main AC switch. Another switch located close to the AC switch, completely turns off the fan.
The 850W model has up to six 6+2 pin PCIe connectors, while the 1050W and 1200W offer eight. Thermaltake is backing these PSUs with 10-year warranties. The company didn't reveal pricing.
Thermaltake quality is very good and there is a little RGB unless your PC case has a PSU cover.
0 Replies Related Threads
