Hot!Thermaltake Intros ASTRIA 200 and ASTRIA 400 ARGB Tower-type CPU Coolers
  • Ribbons : 86
2024/05/06 05:00:33 (permalink)
https://www.techpowerup.com/322152/thermaltake-intros-astria-200-and-astria-400-argb-tower-type-cpu-coolers
Following up on last week's launch of the ASTRIA 600 ARGB dual-stack CPU cooler, Thermaltake today introduced its single-stack siblings from the lineup, the ASTRIA 200 ARGB, and the ASTRIA 400 ARGB. The three coolers were unveiled by the company earlier this year at the 2024 CES. Both the 200 and 400 are single fin-stack tower-type CPU coolers. The 200 has a slightly smaller fin-stack, and uses four 6 mm-thick heatpipes, through a direct-touch base; while the 400 uses a slightly heavier fin-stack, six 6 mm-thick heatpipes, and a nickel-plated copper indirect touch base. Thermaltake rates the ASTRIA 200 ARGB for thermal loads of 210 W, while the ASTRIA 400 ARGB is rated at 230 W. Both coolers feature ARGB LED lighting in the form of a diffuser top-plate, and LEDs in the fan.
The ASTRIA 200 ARGB measures 124 mm x 93 mm x 160 mm (L x W x H), while the ASTRIA 400 ARGB measures 124 mm x 94 mm x 160 mm. Both coolers include an identical type of 120 mm fan, which takes in 4-pin PWM input, turns at speeds ranging between 500 and 1800 RPM, pushing up to 65 CFM of airflow, at 2.56 mm H₂O static pressure, and 26.8 dBA of maximum noise. The fan is rated for 40,000 hours. Among the CPU socket types supported by both coolers include LGA1700, the upcoming LGA1851, AM5, AM4, and LGA1200/115x.
I suspect Thermaltake will show these off during Computex 2024.
0 Replies Related Threads
