Thermaltake Announces the Divider 370 and 170 TG ARGB Chassis
  • Ribbons : 86
2022/06/26 23:36:15 (permalink)
https://www.techpowerup.c...nd-170-tg-argb-chassis
Thermaltake, the leading PC DIY premium brand for Case, Cooling, Gaming peripherals and enthusiast memory solutions, is pleased to announce the Divider 370 TG ARGB Mid Tower Chassis and Divider 170 TG ARGB Micro Chassis, adding new members to the Divider Series. The new models emphasize on the ultimate airflow performance with a large airflow-optimized mesh front panel and the pre-installed ARGB PMW fans to offer better heat dissipation. The Divider 370 and 170 also maintain the excellent features of Divider series, the modern design with the unique panel that comprised a steel panel and a 3 mm scratch resistant tempered glass window on the left side, offers a visually divided look while offering a great view of interior. Divider 170 and Divider 370 are now be available in black and white.
Divider 370 and 170 are the next-gen gaming PC case, the ample interior space to support hardware and cooling solution can satisfy the demands of gaming enthusiasts. The Divider 370 has a room for E-ATX motherboard (12"x13") and up to a 360 mm radiator at the front and top, it also comes with three preinstalled three hydraulic bearing 120 mm ARGB PWM fans which can effectively lower the operation noise and enhance the thermal efficiency with excellent reliability. The distinguished ARGB PWM fan is designed to synchronize with ASUS Aura Sync, GIGABYTE RGB Fusion, MSI Mystic Light Sync, and ASRock Polychrome. It supports motherboards with a 5 V addressable RGB header, allowing you to control the lights directly from the software mentioned above without installing any extra lighting software or controllers. For Divider 170, it can support up to a Micro ATX motherboard and a 280 mm radiator at the front. Besides, the brilliant built-in two hydraulic bearing 120 mm ARGB PWM fans allow the system to achieve better cooling performance.
What's more, full length built-in PSU cover of Divider 170 and Divider 370 helps the users maintain clean and organized cable management and not to obstructing the air flow in the case, it is designed to provide sufficient space to hide the unsightly cables and let your flawless setup to take the center stage. In addition for Divider 370, the pre-installed GPU holder enables vertical GPU installation and prevents graphics card from sagging.
With the stylish unique appearance, user-friendly functions, ultimate cooling solution, and upgradable system, Divider 170 TG ARGB Micro Chassis and Divider 370 TG ARGB Mid Tower Chassis allow you to build your epic build in sleek and sturdy way.
Features of the Thermaltake Divider 370 TG ARGB Mid Tower Chassis:
Unique Side Panels Design with a Tempered Glass Window
The exceptional feature of the Divider 370 TG ARGB is that the unique panel that comprised of a steel panel and a 3 mm tempered glass window on the left side. The side panel is visually divided to create a unique look, and it is tool-free and easy to remove. Tempered glass window is thicker and more scratch-resistant compared to standard acrylic.
Mesh Front Panel
The Divider 370 TG ARGB comes with a large airflow-optimized stylish mesh panel at the front, offering a unique divided design and additional air intake through the mesh.
Three Preinstalled ARGB PWM Fans
The Divider 370 TG ARGB comes with three pre-installed hydraulic bearing 120 mm ARGB PWM fans which can effectively lower the operation noise and enhance thermal efficiency. The fans' lighting effect can be either controlled by the physical RGB button on the I/O panel or motherboard software from ASUS, GIGABYTE, MSI, and ASRock. There are 27 RGB lighting modes to play around with when using the physical RGB button, and it's simple to switch between physical button control and motherboard software control by long pressing the RGB button for three seconds.
PSU Cover & Pre-Installed Vertical GPU Holder
The built-in PSU cover is designed to hide unsightly cables with overall good ventilation. The pre-installed GPU holder enables vertical GPU installation, but also helps reduce the weight on the PCI-E slots.
Excellent Dust Filtration
The Divider 370 TG ARGB has a well-designed removable magnetic fan filter on the top and the inner right side. At the base, the removable filter provides excellent dust protection and dirt reduction, ensuring a dust-free environment.
Air Intake and Exhaust
The cooling performance of the Divider 370 TG ARGB is excellent. The large airflow-optimized mesh panel at the front allow optimal air intake. Cooling exhausts are located at the rear of the case. On the top and right side, there are venting mechanisms for air intake or exhaust depends on the user's overall PC layout design.
Excellent Hardware Support & Cooling Solution
The Divider 370 TG ARGB has great hardware support. It can support a CPU cooler with a maximum height of 170 mm, VGA with maximum length of 400 mm (without radiator), a power supply with a length of up to 230 mm (with HDD Cage), two 3.5" HDDs with two 2.5" SSDs or a total of four 2.5" SSDs. When it comes to cooling, the Divider 370 TG ARGB comes preinstalled with three hydraulic bearing 120 mm ARGB PWM fans which can effectively lower the operation noise and enhance the thermal efficiency, you can also choose to put three 140 mm fans at the front and one 120 mm fan at the rear. Moreover, it can hold up to three 120 mm fans at the top, two 120 mm fans on the right of the motherboard side. For radiator compatibility, it can support up to 360 mm at the front and top.
Handy I/O Ports
Two USB 3.0 and one HD Audio jack is placed on the top panel to grant direct access when needed.
Sync with Motherboard RGB Software
Designed to synchronize with ASUS Aura Sync, GIGABYTE RGB Fusion, MSI Mystic Light Sync, and ASRock Polychrome. It supports motherboards with a 5 V addressable RGB header, allowing you to control the lights directly from the software mentioned above without installing any extra lighting software or controllers. For more details, please visit ASUS, GIGABYTE, MSI, and ASRock official websites.
Features of the Thermaltake Divider 170 TG ARGB Micro Chassis:
Unique Side Panel Design with a Tempered Glass Window
The exceptional feature of the Divider 170 TG ARGB is that the unique panel that comprised of a steel panel and a 3 mm tempered glass window on the left side. The side panel is visually divided to create a unique look, and it is tool-free and easy to remove. Tempered glass window is thicker and more scratch-resistant compared to standard acrylic.
Mesh Front Panel
The Divider 170 TG ARGB comes with a large airflow-optimized stylish mesh panel at the front, offering a unique divided design and additional air intake through the mesh.
Two Preinstalled ARGB PWM Fans
The Divider 170 TG ARGB comes with two pre-installed hydraulic bearing 120 mm ARGB PWM fans which can effectively lower the operation noise and enhance thermal efficiency. The fans' lighting can be either controlled by the physical RGB button on the I/O panel or motherboard software from ASUS, GIGABYTE, MSI, and ASRock. There are 27 RGB lighting modes to play around with when using the physical RGB button, and it's simple to switch between physical button control and motherboard software control by long pressing the RGB button for three seconds.
Built-in PSU Cover
Divider 170 TG ARGB comes with a full length power supply cover providing plenty of space to tuck away cables, while keeping airflow clear for your hard drives and PSU.
The Divider 170 TG ARGB has a handy magnetic fan filter on the top and the inner left side which simply attaches for easy dust filtration and particulate protection. At the base of the chassis, additional filter provides excellent protection against both dirt and dust.
The cooling performance of the Divider 170 TG ARGB is excellent. The large airflow-optimized mesh panel at the front allows optimal air intake. Cooling exhausts are located at the rear of the case.
The Divider 170 TG ARGB has great hardware support. It can support a CPU cooler with a maximum height of 160 mm, VGA with maximum length of 350 mm (without radiator), a power supply with a length of up to 200 mm (with HDD Cage), two 3.5" HDDs with two 2.5" SSDs or a total of four 2.5" SSDs. When it comes to cooling, the Divider 170 TG ARGB comes preinstalled with two hydraulic bearing 120 mm ARGB PWM fans which can effectively lower the operation noise and enhance thermal efficiency, you can also choose to put two 140 mm fans at the front and one 120 mm fan at the rear. Moreover, it can hold up to two 140 mm fans at the top. For radiator compatibility, it can support up to a 280 mm at the front.
Handy I/O Ports
Two USB 3.0, one USB 2.0, and one HD Audio are placed on the top panel to grant direct access when needed.
For more information, visit the product pages of the Divider 370 TG ARGBDivider 370 TG Snow ARGBDivider 170 ARGB, and Divider 170 TG Snow ARGB.
Not a bad looking Mid Tower case. Looks like there is plenty of space for most motherboards.
0 Replies Related Threads
