Sli Gtx 670 who dont have the same core speed and memory speed
Domly
Thursday, September 20, 2012 2:15 PM (permalink)
exemple: one GTX 670 SC with GTX 670 FTW
Core speed are diffrent and the memory speed very near.
I question me if it will be ok to run in sli perfect?
Thanks for reply :)
4 Replies Related Threads
    maxh22
    Re:Sli Gtx 670 who dont have the same core speed and memory speed Thursday, September 20, 2012 3:29 PM (permalink)
    Yes
    loveha
    • Ribbons : 65
    Re:Sli Gtx 670 who dont have the same core speed and memory speed Thursday, September 20, 2012 3:34 PM (permalink)
    They will run just fine. Boost clocks will most likely run at different speeds anyways.
    Case - Phanteks Enthoo Evolv X
    Mobo - EVGA X570 FTW
    CPU - AMD Ryzen 9 5900X
    RAM - 32GB Trident Z Royal 3600MHz 14-14-14-34
    GPU - EVGA RTX 3080 Ti FTW3 Ultra Gaming
    PSU - Seasonic Prime TX-1000
    Heatkiller IV CPU Waterblock / Heatkiller V GPU Waterblock
    Heatkiller V EBC Active Backplate / Two Heatkiller Rad 360 L
    Six Noctua NF-A12x25 / Heatkiller D5 Pump
    Domly
    Re:Sli Gtx 670 who dont have the same core speed and memory speed Thursday, September 20, 2012 4:23 PM (permalink)
    Do i need to get the less clocked card in the pcie slot 1 to work or anyware its work?
    Because i see forum on this it say he need to put the less clocked card in slot 1 due to the highest clock to the other .
    The slot 1 card will downclock the second.
    A lot say it crash it not do this.
    I wonder if its the same with the 600 series?
    loveha
    • Ribbons : 65
    Re:Sli Gtx 670 who dont have the same core speed and memory speed Thursday, September 20, 2012 4:27 PM (permalink)
    With the 600 series I doubt it. Even if it was a 500 Series it didn't really matter. I would not worry about it.
