- Ribbons : 86
![](//www.evga.com/community/modsRigs/images/sm_mods_off.gif)
https://www.techpowerup.com/292598/silicon-power-announces-the-marvel-m02-usb-flash-drive Take your data anywhere with the new Marvel M02 USB flash drive from Silicon Power (SP). The Marvel M02 Type-A USB flash drive is equipped with a USB 3.2 Gen 1 interface, which allows for speedy data transfers up to 5 Gbps. On top of that, with up to 128 GB of storage capacity, you'll have more than enough space to take what you need with you. On the inside, the Marvel M02 is always ready with True Plug & Play technology, which eliminates the need for external power. On the outside, its aluminium casing is lightweight and durable, while a detachable cap protects the USB connector when not in use. Features - Type-A USB 3.2 Gen 1 interface allows for speedy data transfers up to 5 Gbps
- Instant storage expansion up to 128 GB capacity
- Detachable cap protects the USB connector when not in use
- Built-in straphole design for easy attachment to keychains or bags
- True Plug & Play Technology eliminates the need for external power
- Recuva File Recovery allows for recovery of erased files, such as digital photos, documents, music, and videos
- Free SP Widget software available for download for backup & restore, AES 256-bit encryption, and cloud storage
Specifications - Capacity: 16 GB, 32 GB, 64 GB, 128 GB
- Dimensions: 60.6 mm x 19.3 mm x 9.9 mm
- Weight: 9.5 g
- Color: Silver, Blue
- Material: aluminium + Plastic
- Interface: Type-A USB 3.2 Gen 1 (USB 3.1, USB 3.0, USB 2.0 compatible)
- OS Compatibility: Windows 10/8.1/8/7/XP, Mac OS 10.3.X and above, Linux 2.6.X and above
- Operating Temperature: 0°C - 70°C
- Certification: CE, FCC, BSMI, UKCA, Green dot, WEEE, RoHS
- Warranty: 5 year limited warranty
If the price is good this should be a very fast USB stick.
