startekselva
- Ribbons : 6
Hi guys let me introduce my self im a audiophile nooby i do own lot of audio gear and I always want to hear the details in everything from music to gameplay I'm a play player in siege so audio meant a lot in gaming too so lets get to it - What equipment did you use?
- Burso Audio Play,Burson Audio Playmate,,Schiit jotunheim Balanced Dac,Mayflower ARC,Mayflower O2/ODAC,Creative Zxr,Asus Strix Raid Dlx,Fostex HP-A4BL,Asus xonar phoebus
- Beyerdynamic DT 1770 PRO, Beyerdynamic DT 1990 PRO,Beyerdynamic Custom One Pro, Beyerdynamic DT990 Pro, Beyerdynamic DT 880 Chrome Edition,Audeze El-8 open Back,Audeze LCD-2, Sennheiser HD600, Sennheiser HD58x jubliee,Sennheiser HD6xx
- How you did you test the card?
- side by side with Class A DAC AMP
- i love music and games for music since im form india i love classic now MUSES opamps comes into play it make instruments are in front to my eyes and ears and Burson Audio V6V,V6c since i had to remove the EMI shield to use it NOTE:V5i dont require to remove the emi shield if you want back cover go get one from COLDZERO.EU
- What did you enjoy the most about the EVGA NU Audio Card?
- Independent volume with integrated power level for both speaker and headphone
- very good dac chip AKM 4493 https://www.akm.com/global/en/products/audio/audio-dac/ak4493eq/ and swappable opamp and i do own lot of opamp from Muses 01,02 to Burson V5i,V6V,V6C Burr-Browns,NEC,
- MIC TEST https://www.dropbox.com/s/iaf1qsquqsi8ely/MIC%20TEST.m4a?dl=0
- What improvements would you like to see?
Software level need hell lot of improvement especially 3d sound its crap and please EVGA dont integrate Nahimic Audio from my perspective in hardware level is very good dont ruin the software level - After NU Audio Driver Release v0.2.1.2 Nahimic Audio Works as described good job EVGA but i always like stereo with open back headphone
- What was your overall impression?
- Best sound card i had ever seen period good work EVGA and AUDIO NOTE
post edited by startekselva - 2019/11/17 07:22:02
Duranta123
Re: SOUND CARD PERFECTED BY EVGA AND AUDIO NOTE
2019/11/03 02:21:51
startekselva
Which op-amp did you like the most with this card? Muses or Burson?
startekselva
- Ribbons : 6
2019/11/03 02:24:58
Duranta123
startekselva
right now im using MUSES 02 previously used MUSES 01 i use Burson with my playmate
Duranta123
2019/11/03 03:27:31
startekselva
Duranta123
startekselva
Thanks. How much improvements did you notice with the Muses compared to original/default op-amp? Worth rolling?
startekselva
- Ribbons : 6
2019/11/03 04:08:55
Duranta123
startekselva
Duranta123
startekselva
sound stage improved a lot but bass reduced and now i can hear sub bass
startekselva
- Ribbons : 6
2019/11/03 09:23:50
Duranta123
2019/11/03 10:44:34
startekselva if you want crisp treble and mid bass wide sound stage then go with
Thanks for your suggestion. I like rich engaging vocal and mid-range warmth. Any suggestion? Are Muses suitable for that?
startekselva
- Ribbons : 6
2019/11/03 18:10:48
Then go for muses 02 and please do buy for genuine seller lot of fake muses circling the market I prefer Mouser.com,digikey.com
Duranta123
2019/11/03 20:49:35
startekselva Then go for muses 02 and please do buy for genuine seller lot of fake muses circling the market I prefer Mouser.com,digikey.com
Okay bro. Thanks a lot.
Hoggle
2019/11/04 02:46:56
That is a different shroud on the NU Audio. First time I have seen that one but got to say it does look nice. Maybe it's an international version of the card that is different then the silver metal I am used to seeing.
startekselva
- Ribbons : 6
2019/11/04 03:19:31
startekselva
- Ribbons : 6
2019/11/04 03:19:31
startekselva
- Ribbons : 6
2019/11/05 07:19:47
A great feature of the EVGA NU Audio card is the capability for future upgrades and modification by swapping op-amps, sometimes referred to as 'OP-Amp Rolling'. For this we have provided two sockets, U613 and U564, However, the AD8056 op-amp is a very specialized IC and has a maximum operating voltage of 6V (symmetrical +6V, -6V), which means it can only operate in the 5V environment of the Line amplifier, which is socket U613. Socket voltage specification:• U613: +5V, -5V symmetrical, three stage regulated • U564: +14.5V, -14.5V symmetrical, two stage regulated Remember, the AD8056 op-amp will be damaged or destroyed if it is placed in the U564 socket! TIP: Although sockets are provided for 'OP-Amp Rolling' not all op-amps will work satisfactorily or provide better audio quality. EVGA and Audio Note will endeavor to help wherever possible, but we cannot guarantee against poor performance or damage caused by swapping op-amps Muses 01operates at 9v +or - symmetric the sound card can't fully utilize its potential so muses 02 is perfect fit
post edited by startekselva - 2019/11/05 23:13:28
RadioHorst
2019/11/13 10:22:08
startekselva if you want crisp treble and mid bass wide sound stage then go with OPA2134PA http://www.ti.com/product/OPA2134
Thanks for this tip. i think that is the sound which i prefer.. But i have and question for replacement. In this thread i asked about the both op-amp. The finding was: EVGATech_LeeM
RadioHorst @jll544: Thanks for the clarification. So that means for me, if i want to "modify" the sound with an different op-amp, then i can do it: - for the headphone output at 2 positions (AD8056+OPA275) - and for line-out "only" at 1 postion = AD8056 So that is very helpful for me and my questions, which i have post in the "Op-Amps Question" thread , because i asked which op-amp i can use to change instead of OPA275 (i use headphone only). In this thread "EVGATech_LeeM" have posted some op-amps to change AD8056. So now i can begin with the AD8056 ....
I'll see if I can get you a little more detailed answer, but yes, you can modify the headphone through both op-amps.
I hear to 100% with headphone. What do you think, which op-amp position (AD8056/U613 or the OPA275/U564 ) i should prefer to change, to put in the OPA2134PA or maybe an Burson Vxy ? Do you have an technical explanation where it makes more sense for replacing (U613 or U564) ? Thanks !
startekselva
- Ribbons : 6
2019/12/02 09:17:18
i have ordered LT1469CN8 from mouser ill do my review once it delivered peace out
startekselva
- Ribbons : 6
2019/12/16 01:38:47
Guys received the famous Linear technology LT1469CN8 it totally changed the sound signature of the sound card first now i can hear the mid bass clearly just like my Burson Conductor V2+ Sound stage is very high with high positioning Treble is even it was very high before now its even. The linear technology LT1469CN8 suits EVGA NU Audio card since i own all Burson V5i,V6V,V6C are costlier then this its more affordable one and this suits gamer and music listeners well good job EVGA please do provide firmware and software update to this card for a long time NOTE:ill post more op-amp rolling in the following years peace out
post edited by startekselva - 2019/12/19 17:43:33
startekselva
- Ribbons : 6
2020/08/21 10:46:30
BEST card till now good work evga do give us driver support for 10 years
LCaldas
2020/08/24 04:22:15
Like the quality of sound. Um using a custom amplifier with 4 card. ( Bi-amp) 2 for Bass and 2 for mid/high
62D834170D53492
2020/11/15 13:55:22
Since you have the ZxR, whats your opinion with that vs Nu Audio Pro? To me the SBX Pro Studio software (Crystalizer etc) offers an incredible improvement in audio, espcially in gaming. Does the Nu Audio really compete against that?
majikbear
2020/11/29 01:55:29
If you plug a DAC into your soundcard and send the digital signal from the sound card to the DAC you are bypassing the sound card's DACs and amplifiers, thus rendering having the sound card pointless. At that point you might as well take the optical output from your onboard audio and send that to your DAC.
