https://www.techpowerup.com/296747/redmagic-launches-27-inch-mini-led-160-hz-4k-gaming-monitor-with-mmwave-support Redmagic, a sub-brand of Nubia Technology and a company that is mainly known for its phones with a gaming focus, has announced its first PC accessories, namely two computer monitors, as well as a gaming keyboard and a gaming mouse. The most interesting product in the lineup is the high-end 27-inch display, as not only is it a 4K monitor with a fast IPS panel with a 160 Hz refresh rate, but it also sports Mini LED backlight with 1152 FALD zones. Redmagic claims the display delivers 99 percent of the sRGB, Adobe RGB and the DCI-P3 colour gamut, which seems a bit odd, as these values are usually never that close to each other. It's said to be DisplayHDR 1000 certified and using ultra-high frequency PWM backlight dimming, to reduce any kind of flicker from the backlight dimming.
More gaming specific features include the typical 1 ms response time, support for Freesync and G-Sync. The inputs consist of two HDMI 2.1 ports, one DP 1.4 and one USB-C port with 90 W USB-PD support. A version of the display comes with a mmWave add-on unit, for connecting mobile devices wirelessly to the display and Redmagic claims a mere 1.7 ms input lag using mmWave to connect to the display. The company didn't specify which standard that was being used, so it could be something proprietary that only works with its phones. Redmagic also announced a fairly typical 2560 x 1440 screen, although it too uses a fast IPS panel and has a refresh rate of 240 Hz, but it lacks the FALD and is only HDR 400 certified and lacks HDMI 2.1 inputs, whereas most of the remaining features remain somewhat similar. No pricing was announced and it's not clear if any of the products will be available outside of the PRC, where the products launch in September.
I think Redmagic is testing the sales in China first before they make a decision on worldwide release.
