Red led
munitgol
Tuesday, September 29, 2015 1:41 AM (permalink)
According to the EVGA Classified manual there should be a green power led, yellow dim led, and a blue standby led on the motherboard near the 24 pin connector.  Right now I see a red led, yellow led, and a white led (but this could be a blue led).  Everything works and the board boots up fine into the BIOS so I'm just wondering if the red led is OK.  Maybe I have to flash a newer version of the BIOS.
6 Replies Related Threads
    TECH_DaveB
    • Ribbons : 46
    Re: Red led Tuesday, September 29, 2015 5:22 PM (permalink)
    Where is the red LED?  If it is near the BIOS switch it is likely the light showing you which BIOS you are using.
    r4serei
    Re: Red led Tuesday, September 29, 2015 5:59 PM (permalink)
    it's just to the left of that LED. i got the same three lit up on my classified. i'm guessing it's a misprint in the manual?
    TECH_DaveB
    • Ribbons : 46
    Re: Red led Tuesday, September 29, 2015 9:48 PM (permalink)
    Would it be possible to get a pic of the light so I can see exactly where it is?
    r4serei
    Re: Red led Wednesday, September 30, 2015 1:43 AM (permalink)
    I couldn't get a clear pic of it so here's a pic of the motherboard with them outlined. The BIOS indicator LED's are right above them.
    The go in this order: white on top - yellow middle - red bottom
    TECH_DaveB
    • Ribbons : 46
    Re: Red led Wednesday, September 30, 2015 9:39 PM (permalink)
    Check out the attached pic, that should clear it up for you.
    Please let me know if you have further questions.
    munitgol
    Re: Red led Tuesday, November 10, 2015 5:07 PM (permalink)
    Sorry it took me so long to reply.  I was having too much fun enjoying my new computer.  Anyway, I have attached the best image I could take of what the lights look like when my computer is powered on.  Like said it is white (or maybe blue as the manual states) at the top, then yellow, and then red at the bottom (instead of green like the manual states).  Since someone else is having the same results I guess it was just a misprint in the manual but I just wanted to make sure.  Thanks.
