[Rebuild] 4 Way SLI Classified in a Cosmos S
Halo_003
  • Ribbons : 51
2011/01/13 18:34:51 (permalink)
It's time I posted my rig after putting the 762 in.  Got it for my birthday, I love it.  Also I redid some things in my WC loop to function and look better, such as the pump placement with SATA cables wrapped around the tube.  Oh and I got the sleeved extensions from Performance-PCs, they're made by NZXT.
Specs:
i7 930 @ 4.2Ghz 1.35V
Corsair Dominator GT 2000 @ 2000Mhz 7-9-7-21 1.65V
EVGA GTX 295 Dual PCB @ 702/1588/1202 1050mV(retested)
EVGA E762 4 Way SLI Classified
Cooler Master Cosmos S with window
Western Digital 1TB Caviar Black
Cooler Master R4 Red LED fans
Four Scythe Ultra Kaze Fans in pull
ABS Tagan BZ1100W PSU
NZXT black single sleeved extensions
Liquid Cooling:
HWlabs Black Ice GTX 480 Radiator
EK HF Supreme CPU Waterblock Full Nickle
EK FC-295GTX Acetal/Nickle
EK Matte Black Compression Fittings
Bitspower Angle Adapters
Primochill Black 7/16"ID 5/8"OD tubing
Laing DDC 18W version
Watercool Top
Lamptron FC-2 Fan Controller
Bitspower Water Tank Z 250mm version
Temps in C:
CPU core 100% load maximums after Cinebench @ 4.2: 62C-57-59-55
GPU cores after 1 hour on MSI Kombuster: GPU 1 - 39, GPU 2 - 38
You may notice I don't have a drain line anymore, I removed it to improve the appearance, I can drain it without a drain line.
My overall feelings on the build and my goals...
Goal... #1 Single GTX 295 worldwide on HWbot. Undoable unless I come across a 980X/970.
Q56_Monster
nateman_doo
Q?!  say it ain't so?!  booty.  You will be missed.  Congrats anyhow.  I don't see you leaving here any time soon.
Halo, in your dreams buddy, I still have the top 295 and I will breath new life into it when the time is right ;)
Thanks Nate,   and Halo, aint no way you're prying #1 295 away....if worse comes to worse, Nate's bringing his card over to my house, and he can have the credit
Challenge accepted.
My feelings?
post edited by Halo_003 - 2011/01/24 19:22:51
i7 7700K - ASUS Maximus IX Apex - 16GB G.Skill TridentZ RGB 3466MHz C16 - 5700 XT 50th Anniversary
22 Replies Related Threads
    emepror
    Re:4 Way SLI Classified in a Cosmos S 2011/01/13 18:36:04 (permalink)
    NICE!!!
    go for that goal, and have fun while your at it !
    [11:11:11] trust_me: I had a hamburger once...
    [20:32:06] moose517: ROFL i got my fro stuck on a sprinkler at work one time
    [20:32:09] moose517: that sucked
    Halo_003
    • Ribbons : 51
    Re:4 Way SLI Classified in a Cosmos S 2011/01/13 18:47:35 (permalink)
    emepror
    NICE!!!
    Thanks! I'm at 49th right now I think.
    Demonik5150
    • Ribbons : 11
    Re:4 Way SLI Classified in a Cosmos S 2011/01/13 21:23:14 (permalink)
    WoW i didnt know it fit in a Cosmos S  very nice !!
    Halo_003
    • Ribbons : 51
    Re:4 Way SLI Classified in a Cosmos S 2011/01/13 23:28:33 (permalink)
    Demonik5150
    Oh I wasn't fully sure how well it would fit, and with where the res is it damn near didn't. It fits by about 2mm width.
    Halo_003
    • Ribbons : 51
    Re:4 Way SLI Classified in a Cosmos S 2011/01/14 13:59:09 (permalink)
    Dear whoever gave me the BR....... Thanks!
    Halo_003
    • Ribbons : 51
    Re:4 Way SLI Classified in a Cosmos S 2011/01/16 17:27:38 (permalink)
    I could be mistaken, but I think he loves his GTX 295!      :)
    Maybe.. I want to cheat on it and get a few 580s though.
    Falcon_CMH
    Very nice build awesome man!
    Thanks! Btw it's a good thing your ICD sample got here when it did, just in time for the rebuild. Now using it on my CPU, both GPUs, and the board.
    Halo_003
    • Ribbons : 51
    Re:4 Way SLI Classified in a Cosmos S 2011/01/16 23:48:57 (permalink)
    Brazen_NL
    Re:4 Way SLI Classified in a Cosmos S 2011/01/17 00:13:47 (permalink)
    Oh, how very nice.
    Are you going to bunch up the SATA cables so they're nicely together?
    +1
     Linx stable at 4.25 GHz and cooled using one 120 mm radiator.
     See and rate [+1] my system in EVGA MODS RIGS.
     Your PC can help find cures for diseases while you browse the web.
     My affiliate code for product registration is D9G79LRPS5. Thanks!
    Halo_003
    • Ribbons : 51
    Re:4 Way SLI Classified in a Cosmos S 2011/01/17 00:24:17 (permalink)
    Brazen_NL
    Oh, how very nice.
    +1
    Thanks!
    I could if popular opinion is for that but I decided to try something new and use a bit a curve, besides if you knew how much spare cable there was behind the drive bays lmao it's a nightmare trying to put the side panel on.
    Brazen_NL
    Re:4 Way SLI Classified in a Cosmos S 2011/01/17 00:27:11 (permalink)
    Ah, I see what you mean. Maybe the view is a tad distorted in 2D so the video power cables look like they're together with the all the cables under them.
    gthompson62
    Re:4 Way SLI Classified in a Cosmos S 2011/01/17 15:11:00 (permalink)
    Very nice build
    EVGA GeForce RTX 2070 SUPER FTW3 ULTRA+, OVERCLOCKED|AMD Ryzen 9 3900 X|G.SKILL TridentZ RGB Series 64GB (2 x 32GB) 2|EVGA 850 BG|Crucial 2TB Sata SSD|Samsung M.2 3rd Gen SSD|4 X Samsung UE590 28" 4K|Corsair Carbonite Series 275R White|FIIO 10K|Windows 10 64 Bit
    farthestkris
    • Location: Crunching Location .......... Location Not Found
    • Ribbons : 12
    Re:4 Way SLI Classified in a Cosmos S 2011/01/17 19:32:56 (permalink)
    Halo_003
    emepror
    NICE!!!
    i smell Q and Nate breakin out the LHe
    Halo_003
    • Ribbons : 51
    Re:4 Way SLI Classified in a Cosmos S 2011/01/17 19:39:50 (permalink)
    They better, got 40th today.
    threedhero
    Re:4 Way SLI Classified in a Cosmos S 2011/01/17 20:33:55 (permalink)
    Nice clean cut Rig
    4-way classy ftw
    YerBuddy
    • Ribbons : 59
    Re:4 Way SLI Classified in a Cosmos S 2011/01/18 00:06:46 (permalink)
    So very nicely done!
    smoothie
    Re:4 Way SLI Classified in a Cosmos S 2011/01/18 05:33:37 (permalink)
    Wow nice, I have to try those timings on the Dominators as well since I have the same kit as you.
    Halo_003
    • Ribbons : 51
    Re:4 Way SLI Classified in a Cosmos S 2011/01/18 09:41:51 (permalink)
    smoothie
    Thanks! Yeah, highest the can go stable with 7-9-7-21 is about 2150Mhz, and I've only ever gotten them to 2240Mhz, due to CPU IMC limitations, it can't take them higher lol.
    threedhero
    Nice clean cut Rig
    4-way classy ftw
    Thanks, love the board. It's the best out for X58 imo.
    YerBuddy
    Thanks YB that means a lot coming from a master like you.
    YerBuddy
    • Ribbons : 59
    Re:4 Way SLI Classified in a Cosmos S 2011/01/18 10:07:03 (permalink)
    Halo_003
    YerBuddy
    The photography is first-rate!  I love that camera.
    Brazen_NL
    Re:4 Way SLI Classified in a Cosmos S 2011/01/18 11:14:45 (permalink)
    You meant to say you love the photographer who knows how to use his equipment, right? Right? RIGHT?
    smoothie
    Re:4 Way SLI Classified in a Cosmos S 2011/01/18 12:47:58 (permalink)
    Halo_003
    Im running them just a little less than 2000Mhz so they should do 7-9-7-21 im hoping. I will have to test it out once I get my step up GTX 570. Oh and I love the e762 as well, very nice board.
    Halo_003
    • Ribbons : 51
    Re:4 Way SLI Classified in a Cosmos S 2011/01/18 16:49:14 (permalink)
    YerBuddy
    Halo_003
    YerBuddy
    Just a little 12MP Olympus Stylus Tough. I wish I had a DSLR, my sister has a Rebel XSi I think.. I just take like a bunch of pics of the same shot, and use whatever looks best.
    Halo_003
    • Ribbons : 51
    Re:4 Way SLI Classified in a Cosmos S 2011/01/21 22:28:14 (permalink)
    Retested: http://img140.imageshack.us/img140/1326/93043135v.jpg
    I dunno what to make of this CPU, lol..
    #23
