RoyalMuffin
Recently just scored a 3080 XC3 Ultra from microcenter and despite being a beast in gaming should I worry about its thermals? On Idle the card is around 60-66C and then on load the card runs around 77-83C. This is on the default fan curve and with a more aggressive on I can get it at 77C at around 90% fan speed at load. Below is a pic of my current fan setup. There is a missing fan because I am waiting for my new corsair fan to come in. When I did the testing I had all corsair fans and one fan that came with the Lian Li case where the missing fan would be. All fans are 120m
Celeras
Re: RTX 3080 XC3 Ultra Running Hot
2020/11/09 09:06:47
Your temperatures are normal. XC3s run hot, much hotter than FTW3s.
If I helped you in some way, or you just think I'm awesome.. please use my associate code! It gives you a discount
slapn
2020/11/09 09:29:11
Celeras Your temperatures are normal. XC3s run hot, much hotter than FTW3s.
27c idle ///65c gaming//////////////////ur temps are high because of air flow with a brick in the middle of the case causing restrictions
- Ribbons : 135
2020/11/09 09:37:52
RoyalMuffin Recently just scored a 3080 XC3 Ultra from microcenter and despite being a beast in gaming should I worry about its thermals? On Idle the card is around 60-66C and then on load the card runs around 77-83C. This is on the default fan curve and with a more aggressive on I can get it at 77C at around 90% fan speed at load. Below is a pic of my current fan setup. There is a missing fan because I am waiting for my new corsair fan to come in. When I did the testing I had all corsair fans and one fan that came with the Lian Li case where the missing fan would be. All fans are 120m
Maybe it is my eyes, but why does it look like every fan exhaust is mostly covered by a grill and filters that would block most of the airflow out of the case? Also I agree that giant aircoolers need to disappear. They are basically incompatible with getting optimal GPU performance.
hartsocks
2020/11/09 09:39:31
May be edging more on the warmer side(imo) but nothing I'd be frantically worried about. What's your ambient room temp? Could introduce better CFM fans or orientate them differently in your case. Can play around with different Positive airflow configurations.
Computer: Antec DF-85 Intel i7-3930K Intel 520 120GB SSD Intel DX79SI Mobo Corsair Vengence 16GB 1600MHz Mem Corsair H100 Push/Pull Corsair AX1200w PSU WD Black 3TB HDD EVGA GTX 680 HydroCopper Classified SLI Both @ 1280Boost | 3305Mem | 1.175v HWlabs GTX Gen 2 Black Ice 360mm Push/Pull 5 GT AP-15s Koolance RP-1005 Pump/res combo Primochill UV Red 3/8" Tubing Bitspower Barbs/Fittings
rain2_usa
2020/11/09 09:53:25
My suggestion is to add one more fan in the front, even if part of the PSU shroud is blocking it. The way the airflow looks in that case, there isn't much going under the card to provide fresh air. You have a total of 5 fans as exhaust/directional pull towards the exhaust (Noctua air cooler), which is probably pulling all the fresh air from the 2 case-front fans leaving little for the 3080. Experiment by adding one. If you don't have one, experiment by moving the middle one down and see if the temps are lowered. Just my observation.
Core i7 6700k Gigabyte Z170XP-SLI 2x8GB Team T-Force Vulcan Z 3200Mhz EVGA 2070 Super XC Ultra Corsair AIO? with 3D Printed spacer Mushkin 240GB SSD 1TB NVMe 1TB Seagate SSHD LG Black BD-Drive UH12NS30 Seasonic Focus GM-750 80+ Gold Silverstone Grandia GD09B HTPC Case
Celeras
2020/11/09 11:01:20
slapn
You're not getting anywhere CLOSE to 65'C with an XC3 using auto fan at maximum load. 75-80'C is the best you will do. If you want lower you need to manually increase the fan, period. "65'C gaming" means nothing to anybody, just means youre playing a game that isn't putting the card under full load.
RoyalMuffin
2020/11/23 10:12:44
UPDATE: I recently got my 3rd Corsair LL120 fan for that empty slot in the front bottom of my case. Overall temperatures didn't change at all. I'm still sitting around 60 idle and 80 at load. I hope its nothing to be worried about
QueueCumber
2020/11/23 10:19:56
You good. As long as it isn't hitting 100.... (Which it won't on the evga bios).
Celeras
2020/11/23 11:02:52
RoyalMuffin UPDATE: I recently got my 3rd Corsair LL120 fan for that empty slot in the front bottom of my case. Overall temperatures didn't change at all. I'm still sitting around 60 idle and 80 at load. I hope its nothing to be worried about
As my other posts have indicated, you're doing about as well as you can do with the XC3. Anybody who replies differently doesn't understand the thermal performance difference between XC3 and FTW3.
tyhanson
2020/11/23 13:57:23
I think that "award" is your key issue here...
pixelcowboy
2020/11/23 14:19:25
I have learned to live with my XC3 at around 78c. I can get it to around 74c, but while being loud, so I will tolerate the heat.
jenkeeez
2020/11/23 14:57:16
I think your temps are normal , I watched a streamer with same temps and same card yesterday
foofighter33
2020/11/23 15:17:01
Edit: Disregard my post.. I thought you said XC3 black which is what I have. Whoops. I think the CPU cooler is blocking the hot exhaust of the card. I have the same card overclocked 80 mhz and am able to keep it at 65-68C with a custom fan curve going from 80% at 60 degrees to 85% at 80 degrees. My case has excellent airflow though (intake below card + in front of card with the exhaust above it and there is nothing blocking the top of the card. I believe the card even has exhaust ports on the top that may be being blocked. 80C is still okay though.
post edited by foofighter33 - 2020/11/23 15:27:07
Chase Mangham
2020/12/01 09:25:16
So it turns out that this was actually not normal at all. Fans 1 and 2 on the XC3 cards have been running way under speed due to driver issues. The latest version of EVGA precision X (1.1.1) fixes this problem. My card now idles at 45 degrees instead of 65. Celeras, it turns out, was full of crap. :)
salemthecaz
Flagged as Spam (1)
2020/12/01 10:22:33
Got a FTW3 Ultra 3080 brandnew wanna trade for Asus tuf or FE 3080 located in Pittsburgh,PA if anyone interested text me at 412 378 4738, meet in person only and no scam please!
sparetimepc
- Ribbons : 27
2020/12/01 10:45:17
salemthecaz Got a FTW3 Ultra 3080 brandnew wanna trade for Asus tuf or FE 3080 located in Pittsburgh,PA if anyone interested text me at 412 378 4738, meet in person only and no scam please!
This post is a violation of forum rules, any for trade, sale, or want to buy are supposed to be in the evga market place section of the forum.
zerotide89
2020/12/01 14:33:53
Mine idles 30-32c and gets up near 70 under full load. It is a hotter card but as others have said your case setup probably isn't doing you any favors.
z1nonly
2020/12/01 18:50:13
It's dark, but it looks like you have a small card (audio, usb ports or something else?) that is rather close to the 3080 fan that's nearest the back of the PC. Looks like that fan on the GPU is not breathing well. With 3 fans, I don't know how much this contributes to your temps.
rokji
2020/12/03 08:08:03
I upgraded from EVGA 2080S XC Ultra. Right after install new card I played few games and max temp was around mid 80. I noticed something is wrong because 2080S max temp was around low 70. Check few things and realize I should've update X1,firmware. I did it and temp during gaming max 76. I set the fan curve as stealth it is now 70~72 on gaming. I guess temp lowered because of recent cold weather in ATL. My BF got me this card via EVGA queue system right before thanksgiving. So happy with it. My set up: Corsair 220T case, R7 3700x with Fuma2 air cooler
Programming4life
2020/12/05 00:59:42
OP said the card is idling at 60c that's not normal. I actually have the same card and the exact same issue.
Programming4life
2020/12/05 01:01:38
Chase Mangham So it turns out that this was actually not normal at all. Fans 1 and 2 on the XC3 cards have been running way under speed due to driver issues. The latest version of EVGA precision X (1.1.1) fixes this problem. My card now idles at 45 degrees instead of 65. Celeras, it turns out, was full of crap. :)
Hmmm I still have high temps. 60c idle.
MajorTomski
2020/12/05 01:32:38
Hi, I think your temperatures are high in IDLE because on the nvidia control panel your power management must be set to high performance... change it to optimized then reboot. Sorry for my english, i'm french
99ways2die
2020/12/05 08:04:10
MajorTomski Hi, I think your temperatures are high in IDLE because on the nvidia control panel your power management must be set to high performance... change it to optimized then reboot.
This. I had ProcLasso set to "highest performance" on power plan, and power management in NVidia Control Panel was also set to "performance." Card idled at 50-60c at 1750Mhz. Changed to "balanced" power plan in both and now it idles about 30c at 200some Mhz. -99
MajorTomski
2020/12/05 08:16:10
DorpMan
2020/12/14 12:30:32
Hello, I bought this card in late November for a new build using the Ncase M1 v6.1 (latest model) along with a 5800x cpu. This is a small case, around 13-14 liters and installation of all parts was tricky; everything is very compact. CPU is cooled with NZXT Kraken x53. Below the GPU I have two slim 120mm fans pulling air into the GPU. I have to say, this card runs cooler than my 1080 in a ATX mid-tower case with many more fans. I came here originally because I was having high temps on the GPU, similar to OP. Under load, it was hitting as high as 86c. Using GPU-Z I could see the GPU was throttling due to temperature. However, this was solely due to the fact that I was stupid and installed the bottom intake fans backwards, essentially blowing the same hot air back at the GPU. Once reversed, my GPU goes no higher than 70c under full load (tested playing Cyberpunk ultra preset with dlss on varying qualities). If this card runs hot I truly believe it's an airflow issue. This ITX case is delivering amazing temps--beyond my expectations. Edit: I should also mention that I have the GPU overclocked and am very consistently clocking at ~2050mhz with mem clock at ~10400mhz. Power maxed at 108% with voltage increased by about 50 mvs.
post edited by DorpMan - 2020/12/14 12:52:15
Celeras
2020/12/14 13:02:51
If anyone actually believes you can lower your temperatures 16'C by turning around a single case fan, then send me a DM I have a bridge to sell you [edit] and as you can see below, he isn't even using the autofan profile and clearly doesn't understand what is being discussed. Of course you can get temperatures lower by manually increasing the fan...
post edited by Celeras - 2020/12/14 16:21:18
DorpMan
2020/12/14 13:06:37
Celeras If anyone actually believes you can lower your temperatures 16'C by turning around a single case fan, then send me a DM I have a bridge to sell you
You don't have to believe it; I don't care. Just reporting my experience just incase it helps anyone here. Edit: This isn't one fan, it's two and is a significant portion of the cooling of this case. Other than the bottom chassis fans, the only other fans are intakes for the cpu pump radiator. Essentially half of the cooling of this case and for the GPU, the only cooling other than the GPU fans on the card. Also, with the fans installed the wrong way, I was likely getting worse temps than if I didn't have those fans installed at all. Again, it was just keeping hot air on the GPU. It's entirely possible to have one or two fans preventing proper airflow depending on your case. Fan curve is moderate, and I could likely lower it a bit to reduce some noise, but have not done testing and it's not a priority for me.
post edited by DorpMan - 2020/12/14 13:17:04
QingFengX
2020/12/15 05:03:13
gian1983
2020/12/15 05:13:19
Your evga its very close to the cpu cooler. you should direct fans pushing air out of the case. Improve air flow
