So after looking at the card, vs reading the guide, while installing the block, I'm genuinely confused, post install, as to whether or not my card is actually setup in the correct "recommended" way or not.
I know the guide is semi-generic in some ways and specific in others to the card you have, but the guide has this:
But then the block has these little "triangle" "arrows" that my brain just assumed is meant to be flow direction indicators that literally contradict the "recommended" layout:
My main question is just that - is the Guide correct on & the Inlet being closer to the NVLink Bridge is correct, and those "triangles" aren't meant to be flow direction indicators at all, or is the guide wrong?
Also, the nook area that's circled in the picture, does that sort of impede flow? I think I'm thinking too much of how airflow works as opposed to water/liquid.
Also, why is it on the Kingpin HC block that the design (if you're using the stock KP backplate) makes it impossible to actually DO an inlet fitting on the port closer to the BIOS switch?
Oh, picture of the system's setup for reference:
She's a bit of a tube-nest, but the flow is pump --> cpu --> radiator --> gpu --> radiator --> pump/res - so the Inlet is currently on the "left" top port on the card in the picture... is that right for the "recommended/ideal" setup?
Am I the only one that saw those triangles & didn't go "are those flow indicators?" lol I know I was loopy Wednesday during assembly but I hope I'm not the only one that made that connection.
