Mathieas
Thursday, November 05, 2020 4:07 PM
Hi all, I current own a 10year old AX1200 PSU. I am quite uneasy about the age of this even though it has been working perfectly. I have started to look for a new PSU. My first question is, is a 1000W PSU enough for the 3090 FTW3 Ultra? I have seen reports of crazy high power spikes and i worry that 1000W may be insufficient. I am currently running a 6900k @4.2Ghz but plan to upgrade to ether the new Ryzen 5000 series or Intel's next offering Q1 next year in the near future. If 1000W is a reasonable power output max then the current PSU I am looking at is: EVGA SuperNOVA T2 1000W Titanium I was also looking at two different 1200W units to replace my current 1200W unit: EVGA SuperNova P2 1200W Platinum(It is out of stock sadly) or Corsair HX1200 CP-9020140-NA. Speaking about the Corsair, I am having trouble seeing the point in going for the more expensive AX series again. Is there a benefit here i am missing if I have no interest in software monitoring of the PSU? Thank you all for your help! Mathieas
post edited by Mathieas - Thursday, November 05, 2020 4:54 PM
CPU: AMD Ryzen 5 5800x3D - Fclk@1800mhz Cooling: EKWB 360 AIOMother Board: X570 Asus Crosshair VIII FormulaGPU: 1x 4090 MSI SUPRIM Liquid XRAM: 2x 16GB G.Skill Trident Z Neo @3600mhz CL14 (B-Die) SSDs(NVME): 1X WD sn850x 4TB, SSDs(SATA): 1X Samsung 870 EVO 2TB, 1x Samsung 850 Pro 512GB, 1x Samsung 840 Pro 256GBSound: Creative Sound Blaster ZXR Case: Phantek P600SPSU: EVGA SuperNOVA 1000W T2Monitor(Main): Alienware AW3423DW (175hz QD-Oled)Monitor(2ndary): Asus VG259QR (165hz IPS) OS: Windows 10 pro 64bit
SladeX
Re: Power supply advice for 3090 FTW3 Ultra
Thursday, November 05, 2020 4:26 PM
Your corsair psu should be fine. I'm not seeing more than 850w pull from my system overclocked while benching and I have more hdd than you have. The corsair psu is pretty decent, just ensure that you are providing separate sources for pcie power for each port and that the total wattage available exceeds 450w for the 3 plugs combined.
jankerson
Thursday, November 05, 2020 4:27 PM
☄ Helpfulby Mathieas Friday, November 06, 2020 3:42 PM
And of those PSUs will be fine really. The HX is an excellent PSU, or the HXI if you wanted the software monitoring, I like it personally. I have an HX, HXI and AXI and like all 3. Yes, it's smart to replace a PSU after 10 years.
i9 9900K @ 5.0 GHz, NH D15, 32 GB GSKILL Trident Z RGB, AORUS Z390 MASTER, EVGA RTX 3080 FTW3 Ultra, Samsung 970 EVO Plus 500GB, Samsung 860 EVO 1TB, Samsung 860 EVO 500GB, ASUS ROG Swift PG279Q, Steel Series APEX PRO, Logitech Gaming Pro Mouse, CM Master Case 5, Corsair AXI 1600W. i7 8086K, AORUS Z370 Gaming 5, 16GB GSKILL RJV 3200, EVGA 2080TI FTW3 Ultra, Samsung 970 EVO 250GB, (2)SAMSUNG 860 EVO 500 GB, Acer Predator XB1 XB271HU, Corsair HXI 850W. i7 8700K, AORUS Z370 Ultra Gaming, 16GB 16GB DDR4 3000, EVGA 1080Ti FTW3 Ultra, Samsung 960 EVO 250GB, Corsair HX 850W.
jankerson
Thursday, November 05, 2020 4:30 PM
SladeX Your corsair psu should be fine. I'm not seeing more than 850w pull from my system overclocked while benching and I have more hdd than you have. The corsair psu is pretty decent, just ensure that you are providing separate sources for pcie power for each port and that the total wattage available exceeds 450w for the 3 plugs combined.
That PSU is 10 YO, needs to be replaced, doesn't matter what it is or how good it is.
- Ribbons : 135
Thursday, November 05, 2020 4:35 PM
jankerson
No, it doesn't now, and I am not anywhere near thinking I need to replace mine. Make your case why I should. Our systems are similar. He's nowhere near doing anything with that PSU that would accelerate aging. I am currently using the same PSU, stable as a rock. Edit.. Let me say though that if building an entirely new system, I might go with a different PSU for reasons other than reliability. If you're only loading a PSU to 50%, barring a defective from manufacturing, it will outlive the interface.
post edited by HeavyHemi - Thursday, November 05, 2020 4:40 PM
Dabadger84
- Ribbons : 10
Thursday, November 05, 2020 4:39 PM
☄ Helpfulby Mathieas Friday, November 06, 2020 4:05 PM
Mathieas Hi all, I current own a 10year old AX1200 PSU. I am quite uneasy about the age of this even though it has been working perfectly. I have started to look for a new PSU. My first question is, is a 1000W PSU enough for the 3090 FTW3 Ultra? I have seen reports of crazy high power spikes and i worry that 1000W may be insufficient. I am currently running a 6900k @4.2Ghz but plan to upgrade to ether the new Ryzen 5000 series or Intel's next offering Q1 next year in the near future. If 1000W is a reasonable power output max then the current PSU I am looking at is: EVGA SuperNOVA T2 1000W Titanium I was also looking at two different 1200W units to replace my current 1200W unit: EVGA SuperNova P2 1200W Platinum(It is out of stock sadly) or Corsair HX1200 CP-9020140-NA. Speaking about the Corsair, I have having trouble seeing the point in going for the more expensive AX series again. Is there a benefit here i am missing if I have no interest in software monitoring of the PSU? Thank you all for your help! Mathieas
I would look at going with a 1000-1200W Platinum tier PSU. Titanium is overpriced & honestly unnecessary unless you're doing XOC/LN2 stuff to be honest. I bought my PSU in 2019 during holiday sales & got it for a significant margin off, I would try to pick one up in a similar manner of this model: https://www.evga.com/products/product.aspx?pn=220-P2-1200-X1 which you already suggested you're looking at. It's entirely possible if it actually comes in stock anywhere, that it will be on sale for Black Friday/Christmas purposes. My advice would be patient & pick up a quality PSU on sale. Happy hunting.
- Ribbons : 135
Thursday, November 05, 2020 4:45 PM
Dabadger84
I'm not sure why you're relating efficiency to overclocking or LN2. It isn't related. Platinum is related to how efficient the PSU is. Those who pay a bit for power, might appreciate the savings. Also more efficient runs cooler. At $0.05 per KWhr it's not much of a concern for me. For those who pay several times that, it could be worth it. Also, build quality. Attaining that level of efficiency requires quality parts and build.
jankerson
Thursday, November 05, 2020 4:46 PM
jankerson
No, it doesn't and I am not anywhere near thinking I need to replace mine. Make your case why I should. Our systems are similar. He's nowhere near doing anything with that PSU that would accelerate aging. I am currently using the same PSU, stable as a rock.
The CAPs deteriorate with age for one. Also there have been studies down over time and PSUs have been tested, quality units. They do in fact deteriorate and go out of spec over time and the protections could also fail as they can also go out of spec. A new 1000W PSU after 10 years may not even be capable of supplying 800W as a simple example. It's not how you use it, it's the age. Just sitting a PSU on a shelf and keeping it there for 10 years is the same, unless it's sealed against the elements. But then you wouldn't want to buy or use a PSU that has been sitting in a warehouse for a long time either. They don't last forever. Had some talks with John Gerow (Jonny Guru) and he does talk about if you do the research.
post edited by jankerson - Thursday, November 05, 2020 4:53 PM
jankerson
Thursday, November 05, 2020 5:08 PM
jankerson
Here is a thread made today on Linus's forum and Jonny Guru replied on that subject. https://linustechtips.com...-overlocked-cpu/
kevinc313
- Ribbons : 22
Thursday, November 05, 2020 5:17 PM
Mathieas Hi all, I current own a 10year old AX1200 PSU. I am quite uneasy about the age of this even though it has been working perfectly. I have started to look for a new PSU. My first question is, is a 1000W PSU enough for the 3090 FTW3 Ultra? I have seen reports of crazy high power spikes and i worry that 1000W may be insufficient. I am currently running a 6900k @4.2Ghz but plan to upgrade to ether the new Ryzen 5000 series or Intel's next offering Q1 next year in the near future. If 1000W is a reasonable power output max then the current PSU I am looking at is: EVGA SuperNOVA T2 1000W Titanium I was also looking at two different 1200W units to replace my current 1200W unit: EVGA SuperNova P2 1200W Platinum(It is out of stock sadly) or Corsair HX1200 CP-9020140-NA. Speaking about the Corsair, I am having trouble seeing the point in going for the more expensive AX series again. Is there a benefit here i am missing if I have no interest in software monitoring of the PSU? Thank you all for your help! Mathieas
Unless you've been running your AX1200 24/7 in warm room with poor air circulation at 75%+ load for the last 10 years, imho it is perfectly fine until suspected otherwise. For overall performance, Gold supplies in premium platforms usually perform better than the Plat or Ti equivalent. The only advantage of Ti/Plat is their efficiency, which will take a LONG time to recover the cost of. This is probably the best performing 1000w psu on the market: https://www.bhphotovideo....gd_prime_1000w_80.html
post edited by kevinc313 - Thursday, November 05, 2020 5:26 PM
d.burnette
- Ribbons : 17
Thursday, November 05, 2020 5:21 PM
I have an EVGA 1000w T2 Titanium power supply I put in this build back in Jan 2019. Hoping it will be more than sufficient for my upcoming 3090 FTW3 Ultra.
Don EVGA Z390 Dark MB | i9 9900k CPU @ 5.2 GHz all cores | EVGA RTX 3090 FTW3 Ultra | 32 GB G Skill Trident Z 3200 MHz CL14 DDR4 Ram | Corsair H150i Pro Cooler | EVGA T2 Titanium 1000w Power Supply | Samsung 970 Pro 1TB m.2 Nvme | Samsung 970 Evo 1TB m.2 Nvme | Samsung 860 Evo 1TB SATA SSD | EVGA DG 87 Case |
Dabadger84
- Ribbons : 10
Friday, November 06, 2020 3:53 PM
☄ Helpfulby Mathieas Friday, November 06, 2020 4:04 PM
HeavyHemi I'm not sure why you're relating efficiency to overclocking or LN2. It isn't related. Platinum is related to how efficient the PSU is. Those who pay a bit for power, might appreciate the savings. Also more efficient runs cooler. At $0.05 per KWhr it's not much of a concern for me. For those who pay several times that, it could be worth it. Also, build quality. Attaining that level of efficiency requires quality parts and build.
It's not about the efficiency as why I point out people use those for that, it's because they are the most likely to be able to handle huge load spikes OVER their limit, which LN2 can do. Granted, I'm pretty sure any Platinum eVGA PSU can handle over it's supposed power output just fine for short periods of time as they're quality PSUs, but that's more of what I was refering to. I know that Corsair used to brag about the fact that their 1200W PSUs (I'm talkin' back a while, when I had a Dual PSU setup & actually tested a single AX1200W PSU from them & got the draw at the wall well over the 1200+80% efficiency amount) could handle sustained load north of 1200W for an extended period of time. Nowadays, that's just expected, but it's not reality, for weaker units, and is there in most Platinum & Titanium level PSUs, because of their superior quality. It's also about cost up front. A good Platinum on sale for something like what I got mine for ($200 for the 1200 P2 I think it was, maybe even less) is reeeeeeeeeally unlikely to ever happen on Titanium PSUs because they're high end, not sold that much, and are not expected to sell that much. And the power savings between a Platinum & a Titanium unless you're actually drawing the full 1200W (in which case you should go to a higher wattage to be safe anyway) is minute unless your electric rates are beyond insane, because you're only talkin' a few percentile points. - but your point about it technically being more cost efficient over time is true, especially if you hold on to it for the full 10 year warranty, it might almost pay for itself if one's electric rates are decently "not cheap". Funny side note, I'm on solar, so if it's sunny I ain't payin' NUTTIN' lol (it's sunny about 270-300 days a year in the hell-hole I live in) Edit: Oh and I would also point out, that AX1200W I had & used for several years... is still in use by the friend that bought it off me, and has been for at least 4 years, so it's goin' on, I think, 10 years old as well, and has not given him any issues... buuuuuuut having said that it's also only powering a system (for him) that draws around 300-450W at high load currently... that'll soon tick up a bit as he's buying my GTX 1080 Ti FTW3 Hybrid soon. So overall, I would think the AX1200W would be fine, unless he's pushing craaaaazy high OCs. But, on the safe side, you don't want your PSU going of old age & taking the whole system with it.
post edited by Dabadger84 - Friday, November 06, 2020 3:56 PM
Mathieas
Friday, November 06, 2020 4:02 PM
Thank you all for the responses! I have decided to go ahead and upgrade my PSU. While I understand my 10yr old AX1200 is not guaranteed to fail it seems worth the peace of mind to go ahead and replace. I noticed the 3090 FTW3 Ultra line has been moving much quicker this week and my number is fast approaching. So with that I decided to get the 1000W T2 from EVGA. I really wanted EVGA for their support and warranty and this was the best option given the stock of PSU. Does anyone happen to know if a 1000W SuperNova T2 is able to provide more then 1000W for split second spikes? I was running some tests today and noticed my system draw getting into the low 800Ws (fraction of a second peak load) while running Furmark and Intel Burn test at the same time (This is the highest load i could manage). It seems this peak load corresponded to some aspect of the Linpak test as it was periodic and would occurs once per test cycle. On average though, the load would settle around 560W-630W. I imagine the 3090 FTW3 Ultra could pull well over 100W more then my Titan Xp during those spikes and wonder if the 1000W PSU really is enough. Is it silly to worry about these peak loads?
post edited by Mathieas - Friday, November 06, 2020 4:08 PM
jankerson
☼ Best Answerby Mathieas Friday, November 06, 2020 4:08 PM
Mathieas Thank you all for the responses! I have decided to go ahead and upgrade my PSU. While certainly not guaranteed to fail it seemed worth the peace of mind to go ahead and replace. I noticed the 3090 FTW3 Ultra line has been moving much quicker this week and my number is fast approaching. So with that I decided to get the 1000W T2 from EVGA. Does anyone happen to know if a 1000W SuperNova T2 is able to provide more then 1000W for split second spikes? I was running some tests today and noticed my system draw getting into the low 800Ws (fraction of a second peak load) while running Furmark and Intel Burn test at the same time (This is the highest load i could manage). It seems this peak load corresponded to some aspect of the Linpak test as it was periodic and would occurs once per test cycle. On average though the load would settle around 560W-630W. I imagine the 3090 FTW3 Ultra could pull well over 100W more then my Titan Xp during those spikes and wonder if the 1000W PSU really is enough. Is it silly to worry about these peak loads?
The EVGA T2 1000W works fine with the 3000 series cards.
Dabadger84
- Ribbons : 10
Friday, November 06, 2020 4:06 PM
☄ Helpfulby Mathieas Friday, November 06, 2020 4:08 PM
That T2 1000W should work great.
jankerson
Dabadger84
There is a difference in Platinum and Titanium rated PSUs and the was they work efficiency wise. Titanium will be at 90% or better efficiency at 10% loads, you know what PCs are at most of the time. Platinum, Gold etc will drop quite a bit down into the low 80% range.
d.burnette
- Ribbons : 17
Friday, November 06, 2020 4:30 PM
Dabadger84 That T2 1000W should work great.
Great to hear thanks.
buttabean
Friday, November 06, 2020 4:31 PM
From what I read, a lot of psu that are platinum and titanium are actually upper gold wattage psu. So if you buy a 850 titanium or platinum, you could actually have a 950+ depending on the manufacturer. This allows them to get the much higher efficiency ratings. I was pulling 880 watts with my 1950x threadripper oc to 4.0 with my 3090 stock bios and stock speeds. I lowered my oc to 3.9ghz and tuned in the vcore. Now hitting 600-700 watts from the wall. I have a seasonic platinum 850watt focus px-850. It hasn't shut off yet. As for the age of a power supply. Capacitors tend to swell over time and eventually start to buzz with audio amps which then need to be replaced because they're no longer producing clean power. I would think the same thing will happen with the psu capacitors and probably fail.
Associate Discount Code: KQ9JGG4415FXHVQ
jankerson
Friday, November 06, 2020 4:43 PM
buttabean From what I read, a lot of psu that are platinum and titanium are actually upper gold wattage psu. So if you buy a 850 titanium or platinum, you could actually have a 950+ depending on the manufacturer. This allows them to get the much higher efficiency ratings. I was pulling 880 watts with my 1950x threadripper oc to 4.0 with my 3090 stock bios and stock speeds. I lowered my oc to 3.9ghz and tuned in the vcore. Now hitting 600-700 watts from the wall. I have a seasonic platinum 850watt focus px-850. It hasn't shut off yet. As for the age of a power supply. Capacitors tend to swell over time and eventually start to buzz with audio amps which then need to be replaced because they're no longer producing clean power. I would think the same thing will happen with the psu capacitors and probably fail.
They actually aren't. The are different PCB's and or different platforms (Or upgraded) from the GOLD and Platinum normally.
kevinc313
- Ribbons : 22
Friday, November 06, 2020 5:10 PM
jankerson
Dabadger84
Please be aware that "The Average" Titanium or Platinum PSU is likely better than "The Average" Gold PSU, only because they just don't build Ti or Plat on lower end platforms, and they build plenty of marginal Gold PSU's. However, when you compare across the same platform, the Gold PSU performs better because it doesn't have to sacrifice performance for efficiency. The Gold will have better voltage regulation and transient response. Also, bigger PSU's typically perform better. The EVGA T2, P2, and G2 are all Superflower Leadex I platform. The Gold performs the best, slightly. The 1600w G2 is an absolute unit. The Seasonic Prime Platinum and Gold are very similar, but the Gold performs slightly better. The Corsair AX series has great performance but I don't think they have a gold or platinum equivalent. IMHO the two best performing PSU's made are the 1600w G2 and 1300w Prime Gold. Followed by the AX1600i Titanium.
post edited by kevinc313 - Friday, November 06, 2020 6:04 PM
- Ribbons : 135
Friday, November 06, 2020 5:35 PM
kevinc313
jankerson
Dabadger84
Please be aware that "The Average" Titanium or Platinum PSU is likely better than "The Average" Gold PSU, only because they just don't build Ti or Plat on lower end platforms, and they build plenty of marginal Gold PSU's. However, when you compare across the same platform, the Gold PSU performs better because it doesn't have to sacrifice performance for efficiency. The Gold will have better voltage regulation and transient response. Also, bigger PSU's typically perform better. The EVGA T2, P2, and G2 are all Superflower Leadex I platform. The Gold performs the best, slightly. The 1600w G2 is an absolute unit. The Seasonic Prime Platinum and Gold are very similar, but the Gold performs slightly better. The Corsair AX series has great performance but I don't think they have a gold or platinum equivalent. IMHO the two best performing PSU's made are the 1600w G2 and 1300w Prime Gold. Followed by the AX1600.
I have a Corsair AX1200 Gold... I'm not sure what planet you're on sometimes. Most of this post is, forgive the rudeness, nonsense. That you claim PSU's that are certified Gold for efficiency are MORE stable and HIGHER quality output than a Platinum or Ti efficiency rating is absurd. I just had to say this. Your posts are technically wrong and make folks LESS informed.
kevinc313
- Ribbons : 22
Friday, November 06, 2020 6:02 PM
HeavyHemi I have a Corsair AX1200 Gold... I'm not sure what planet you're on sometimes. Most of this post is, forgive the rudeness, nonsense. That you claim PSU's that are certified Gold for efficiency are MORE stable and HIGHER quality output than a Platinum or Ti efficiency rating is absurd. I just had to say this. Your posts are technically wrong and make folks LESS informed.
You are wrong. More efficient AND higher performance for a 20% price increase across the same platform? Suuuure. The AX1200 Gold has been out of production for years. I'm referring to the AX1600i Titanium and will specify as such.
post edited by kevinc313 - Friday, November 06, 2020 6:14 PM
jankerson
Friday, November 06, 2020 7:23 PM
kevinc313
For a pretty long time actually... Here is the list, including discontinued models. http://www.jongerow.com/C...U_hierarchy/index.html
jankerson
Friday, November 06, 2020 7:26 PM
kevinc313
jankerson
Dabadger84
Gold performs better how exactly? Compared to similar model Plat and Ti models? Personally I have never seen that happen, not even once.
kevinc313
- Ribbons : 22
Friday, November 06, 2020 8:23 PM
jankerson
kevinc313
jankerson
Dabadger84
Enjoy! https://www.techpowerup.c...pernova-t2-1600/8.html https://www.techpowerup.c...pernova-g2-1600/8.html (both these are SF Leadex I) In this case the G2 1600w walks all over the T2 1600w in ATR. Voltage load regulation too. Pretty significant difference. There are 1600w P2 figures there too. The 1000w P2 does very slightly edge out the 1000w G2. There is a smaller difference between Plat and Gold, very very similar. Really need to watch out for giving up performance with the Ti. So no, it's not a hard and fast rule, just generalized guidance and only applicable when comparing the same platform and size.
post edited by kevinc313 - Friday, November 06, 2020 8:54 PM
jankerson
Friday, November 06, 2020 9:39 PM
kevinc313
jankerson
kevinc313
jankerson
Dabadger84
Those reviews, especially the 2014 review is OLD. (Saw those before) That's why I never just look at one reviewer. Look at the Seasonic Prime differences as an example. I used those for a long time. Corsair these days however currently.
post edited by jankerson - Friday, November 06, 2020 9:58 PM
kevinc313
- Ribbons : 22
Friday, November 06, 2020 10:46 PM
jankerson Those reviews, especially the 2014 review is OLD. (Saw those before)
I guess it's expired.
pmclean
Saturday, November 07, 2020 4:07 AM
I have the exact same PSU, bought it 10 years this month. It came with a 10 year warranty so Corsair is confident that it will last at least 10 years. I haven't been running SLI or watercooling in several years, I know I've never even pulled 1000watts from it. I just ordered 3090 FTW3 Ultra just today and I am fully confident my PSU will have no trouble whatsoever running that video card, my 9900K all the hard drives and fans I have. I will be surprised if it does not last as long as I am using this 3090.
Current Build Direct die 10900KF w/Grizzly LM w/Optimus V2 Sig Block on an ASUS Maximus XII Apex, 32 GB 4000MT/s Cl 15 G.Skill Trident Z Royal RAM, EVGA RTX 3090 KingPin w/Optimus Waterblock, EVGA RTX 3090 FTW3 Ultra w/Optimus Absolute Waterblock, EVGA 1600W G+ PSU, 2 x Corsair MP510 960GB M.2 RAID0, 2 x WD Blue 1 TB SSD RAID0, 2 x 6TB WD Red Pro 7200RPM HDD RAID0, EVGA Nu Audio Card, Lian Li Strimer Plus 3x8 Pin & 24 Pin, Corsair 7000D White Case, 7 x Lian Li SL140 Fans, Corsair XD7 Distro Plate w/Xylem D5 Pump, Samsung 55" QN90A, Samsung c49RG9 Ultrawide Monitor, HyperX Cloud Orbit Headphones, Sony AV Reciever STR-DN 1080, KEF Q Series 5.1 Speakers, Glorious Model D Gaming Mouse, SteelSeries Apex Pro KB, Corsair MM300 XL & MM350 XL Gaming Mouse Pad, Vartan Gaming Chair, APC Back UPS PRO BR 1350VA, MO-RA3 420 w/ 2 x WCP D5-Vario Pumps w/HeatKiller D5-TOP, PrimoChill RevolverSX UV Pink Rigid Fittings.
