Power management mode how?
vainpop1317
2017/12/13 13:22:41 (permalink)
how do you like to keep your power management mode in the nvidia control panel and why?
i am trying to make up my mind and need some good reasons.
5 Replies Related Threads
    EVGA_JacobF
    • Ribbons : 26
    Re: Power management mode how? 2017/12/14 12:07:28 (permalink)
    It doesn't really matter too much, but the prefer maximum performance will keep the card from dropping below base clock.
    Re: Power management mode how? 2017/12/14 12:48:22 (permalink)
    How I have mine set...
    Global settings power management mode = Adaptive.
    Power management mode for each game under program settings = Prefer maximum performance.
    Why adaptive for global? To keep the card from running at base clocks while web browsing. Why not optimal power for global? Optimal power could cause screen corruption while idling since optimal power reuses the same frame over & over again from the framestore.
    post edited by Sajin - 2017/12/14 13:07:31
    arestavo
    • Ribbons : 77
    Re: Power management mode how? 2017/12/14 12:49:15 (permalink)
    Adaptive. There was a long stretch of Nvidia drivers that caused crashes with the default of optimal on my system.
    • Ribbons : 135
    Re: Power management mode how? 2017/12/14 12:57:18 (permalink)
    Quite a few people are not aware of this but if you check in the profiles tab for each game/application you will see that Windows WDM  (Windows Desktop Manager) is set to adaptive by default by the driver as are Explorer.exe, Windows Shell Experience..etc etc...  So by default the desktop is running in adaptive mode. However, applications are typically set to run at optimal by default. I may experiment with running FF on adaptive for awhile to see if it eliminates the 1/2 second or so black screen flash I get every once in awhile...but never gaming.
    post edited by HeavyHemi - 2017/12/14 12:59:25
    AHowes
    • Ribbons : 27
    Re: Power management mode how? 2017/12/14 13:42:27 (permalink)
    Been there before with the screen being all weird.. i do as sajin says!
    Asus Z390 ROG Extreme XI MB
