yaggaz
Saturday, December 28, 2019 2:29 AM
First of all, what does "individually sleeved" mean? And I want to run a 8 pin power cable and a 6 pin power cable separately to my RTX 2080 I notice the extra cables that come with the PSU have the 6 and 8 but they seem to be daisy chained/piggy backing each other? Like it ends with a 6 pin and then further down there's another 6 pin. Is this what it means when it ISNT individually sleeved? Is it possible to buy dedicated cables for my PSU that go straight from the PSU to the Video Card without any extra bits dangling off it? Does it MATTER to have more hanging off of it than the one you have plugged in? Thanks.
|| CPU: Intel 10700k || GPU: evga 3080 XC3 Ultra Hybrid || MB: Gigabyte z490 UD AC || RAM: 2 x 16GB 3000mhz DDR4 SDRAM || Samsung EVO 970 Plus 2TB || Dell S2417DG Monitor || Soundblaster AE-7 || Phanteks p400a Case || be Quiet! Dark Rock Slim CPU Cooler || Corsair AX1600i PSU || 9 Fans total in system ||
bob16314
- Ribbons : 761
Re: Power cables for Evga 750 BQ
Saturday, December 28, 2019 6:49 AM
☄ Helpfulby yaggaz Saturday, December 28, 2019 8:13 PM
Individually sleeved means each wire is sleeved (covered) separately from the rest like shown here..A sleeved (covered) cable has all the wires sleeved (covered) together inside one sleeve (cover) as shown here..Some cables have no sleeving (covering) at all like shown here..A sleeve is a protective wire/cable cover. You can use one of the two PCI-E connectors from the cable that's hardwired to the PSU and leave the other connector part hanging doing nothing..Same thing with one of the PCI-E cables that's removeable (Modular) from the PSU..Use only the connector part you need from each cable if you want to, it doesn't matter. EVGA is saying here that modular cables from BQ/B2/B3/G2/G3/G5/G+/GM/P2/PQ and T2 units are interchangable with each other..You can Contact EVGA Customer Service to get cables with just a 6-pin or just an 8-pin PCI-E connector on it (no extra bits hanging off it) or go to CableMod and get them there.
yaggaz
Saturday, December 28, 2019 11:11 PM
bob16314 You can use one of the two PCI-E connectors from the cable that's hardwired to the PSU and leave the other connector part hanging doing nothing..Same thing with one of the PCI-E cables that's removeable (Modular) from the PSU..Use only the connector part you need from each cable if you want to, it doesn't matter.
I guess I'm just not knowledgeable enough to understand what that information means on the first Evga link there so I just went with using an extra modular VGA cable that came with the PSU . So now I did as you suggested, have the eight pin from the hardwired cable and using a six pin from a modular so they are separate. Anything I need to keep an eye on for issues? Also, is it safe to cut off excess cable lengths and plugs you dont use (pic below) and just wrap it with electrical tape? It's not a big deal I'm just OCD about seeing plugs hanging down that don't connect to something :)
bob16314
- Ribbons : 761
Sunday, December 29, 2019 5:29 AM
yaggaz Anything I need to keep an eye on for issues? Also, is it safe to cut off excess cable lengths and plugs you dont use (pic below) and just wrap it with electrical tape? It's not a big deal I'm just OCD about seeing plugs hanging down that don't connect to something :)
No and yes. I was almost going to suggest before to just cut the stupid things off with some side cutters and tape up the excess but I didn't want to give people the impression that sometimes I'm a butcher that some members here already know I am  ..Just make sure there's no possibility of bare wires touching each other.
yaggaz
Sunday, December 29, 2019 9:18 AM
bob16314
Haha okay thanks.
piggradio
Sunday, December 29, 2019 9:48 PM
Just be VERY careful about insulating every single cable if you cut one or more off. You don't need a short inside your system blowing something up or burning your house down. Good luck with your project. :-)
Associate Code XX95PJN1T76IONP for discounts at the EVGA store. Thanks to anyone who uses it.
yaggaz
Sunday, December 29, 2019 9:54 PM
piggradio Just be VERY careful about insulating every single cable if you cut one or more off. You don't need a short inside your system blowing something up or burning your house down. Good luck with your project. :-)
Like, don't cut it off, then run the PC and put the exposed cut wires on my tongue? Well that's no fun...
piggradio
Sunday, December 29, 2019 10:47 PM
☄ Helpfulby yaggaz Tuesday, December 31, 2019 3:04 AM
I'd heat shrink each individual cable, but electrical tape would work if you don't mind it looking crappy. Save that tape for holding your car's mirrors on. :-)
post edited by piggradio - Sunday, December 29, 2019 10:49 PM
