Phanteks Robotic-Looking Evolv Shift XT Case, Compact PSUs, and White Edition Products
Flint 1760
  • Ribbons : 45
2022/01/05 09:50:58 (permalink)
TechPowerUp - Phanteks Previews Robotic-Looking Evolv Shift XT Case, Compact PSUs, and White Edition Products
"Phanteks debuts a host of new products for the upcoming year at CES 2022 - The brand new Evolv Shift XT Mini-ITX Chassis and Revolt SFX Power Supplies, Matte White Editions for the Evolv X & Eclipse P600S Chassis, white SK PWM D-RGB Fans, white AMP Power Supply and a complete range of Gen4 PCIe Riser Cables and Gen4 Vertical GPU Bracket.
The Evolv Shift XT brings a unique small form factor that can extend in size to tailor to your cooling performance needs. The Evolv Shift XT has no compromise on performance with support for powerful hardware, whether in Compact, Aircooled, or Liquid Cooled Mode.
Being part of the Phanteks Evolv series, the Evolv Shift XT offers premium build quality and components using thick anodized aluminium panels, PCIe X16 Gen4 riser cable, and USB-C Gen2 front IO. Performance is uncompromised with Ultra-Fine Mesh panels and vented aluminium panels while providing a clean and stylish appearance with the tempered glass infinity mirror.
Revolt SFX Power Supplies - 650 Gold, 750 Gold and Platinum Editions
The super-compact SFX form-factor maximizes its versatility to fit Small Form-Factor chassis and free up space in larger chassis for better cable management. The silent 92 mm Fluid Dynamic Bearing (FDB) fan with intelligent thermal control optimizes noise and cooling performance with a 0 RPM mode when under 30% load for ultimate silence.
The Revolt SFX power supplies are developed with renowned power supply manufacturer Seasonic to ensure the best possible endurance and stability.
Evolv X & Eclipse P600S Matte White Edition
The Evolv X and Eclipse P600S chassis are now available in Matte White with matching white SK D-RGB fans and clear tempered glass making them a perfect fit for your all-white colored build. The two chassis are premium mid-towers offering dual system capabilities, massive storage, and extensive water-cooling support. The Evolv X and P600S Matte White Edition includes 3x 140 mm white D-RGB fans and a D-RGB lighting strip in the PSU cover. All the lighting can be directly connected to compatible motherboards.
SK PWM D-RGB White Fans
The SK fans are known from the award-winning Eclipse Series chassis such as the P400A and its cooling performance. The built-in PWM capabilities help precisely control the speed to offer higher airflow or a quiet cooling solution when needed. The new white SK D-RGB models further complement the new white chassis available from Phanteks.
AMP 1000 W Gold Power Supply White Edition
The Phanteks AMP Series are high quality 80 Plus Gold Certified power supplies made in collaboration with Seasonic. The fully modular power supplies provide users with clean and great cable management with all white, flat ribbon cables. The 120 mm Fluid Dynamic Bearing Fan can be temperature controlled in Hybrid Fanless mode for ultimate silent performance.
The Phanteks AMP 1000 W 80 Plus Gold White Edition is a great and affordable choice for high performance builds and now available in all-white color.
The new Gen4 Vertical GPU Bracket allows vertical placement of any graphics card with full Gen4 speeds. Designed specifically for the P300A/P360A/P400A chassis that have an open PCI slot to allow the Vertical GPU Bracket to be installed directly. Any other ATX chassis can be easily modded to support the Gen4 Vertical GPU Bracket. Graphic Cards with up to 4-slot sizes are supported with access to ports on the first 2 slots. The included 220 mm long PCIe Gen4 x16 Riser Cable allows any Gen4 graphics card to run at full speed without compromise.
Also, Phanteks will offer the Flat Line PCIe Gen4 x16 Riser Cables. The dual-layer design improves the performance and stability of the high bandwidth signals ensuring the system are running stable and reliable. Each individual laneway is shielded from EMI/EFI interference to prevent interference between channels to further improve signal integrity. The Flat Line riser cables will be available in 150 mm (90-degree adapter), 220 mm (90-degree adapter), and 300 mm (180-degree adapter).
Pricing and Availability:"
My thoughts:  The latest updates to Phanteks’ products.  It looks like a lot of manufacturers are offering more products if you are interested in all white build.
0 Replies Related Threads
