god503
Wednesday, January 06, 2021 9:38 PM
OPTIMUS WATER BLOCK INSTALLED!!!!
Ok so here where my best air cooling on port royal. Thats all i have done testing so far,,, So on air the best I was getting was +175 GPU and +275 MEM no boost lock on 500 watt bios. Tried the XC3 bios but changed nothing on my score which led me to believe my card was throttling. GPUZ showed a high of 84C and a power draw high of 485 Watts [for port royal. I was able to hit 500+ peaks on other more demanding games so I dont feel I was power limited. My systems is threadripper 3 24 core on 4.35 all core boost (not a gaming CPU obviously, probable costs me about 200 to 300 points on 3dmark) asrock tiachi MB and dd4 at 3666 14T mem locked to 1:1 infinity fabric. So best score i ever got on a port was 13950.
So in goes Optimus!!!!
SOOOOOOOO HEAT LIMITED ON AIR!!!!!!
Mem went to +375 GPU went to +200 WITH BOOST LOCK ON.... 14547!!!!!! A 600 point Increase!@!!!!!!
So this is what i noticed. Not a good paste job on the GPU or quality paste and thermal pads when i took off the cooler. I did use liquid metal instead of kryonout. My temps max out at 40C. My power draw dropped to about 455 watts so the fans take about 12-15 watts per fan!!!! Will try the xc3 bios to see if it makes a difference since heat is out of the equation.
So bottom line.... IMO I think we are dealing with thermal throttling that keeps these cards from hitting power limits. On air i noticed throttling starting at 60C with big time throttling above 70C. And i was hitting 84C.
My card has red lips and 14 on the serial number
Will up date when i have time to play with it more.
richardgoncalves
Re: Optimus water cooler for 3090!!!!
Wednesday, January 06, 2021 9:47 PM
That's awesome! You've got me all excited. Waiting on my EK Block ... not as fancy but should do the trick. How many and what size rads in your rig? Anything else outside of the CPU & GPU under water as well?
god503
Wednesday, January 06, 2021 9:50 PM
Just cpu and gpu. Each have there own loop on a quad rad
richardgoncalves
Wednesday, January 06, 2021 9:55 PM
god503 Just cpu and gpu. Each have there own loop on a quad rad
You got some nice results - congrats! Pics? Super excited to finish this build now.
sunlight0
Thursday, January 21, 2021 5:29 PM
god503
Thursday, January 21, 2021 5:43 PM
Added the 1000 watt bios. Have it set for 600 crossed 15k on port royal and almost 12k on time spy extreme. Made the top 30. This block is no joke.
carlitos_mg
Thursday, January 21, 2021 10:04 PM
[<font][cita-dios503] Se ha añadido la biografía de 1000 vatios. Que se fije para 600 cruzado 15k en el puerto real y casi 12k en el extremo espía de tiempo. Llegó al top 30. Este bloque no es una broma. [/cita] hi, i'm waiting for the optimus block, i'm from batch 2, where can i download the 1000w bios? do you have the download link? i have the rtx 3090 ftw3 ultra currently with xoc
carlitos_mg
Re: Enfriador de agua Optimus para 3090!!!!
Thursday, January 21, 2021 10:06 PM
god503
Thursday, January 21, 2021 10:59 PM
Tech power up. Search the xoc bios thread. The link is in there
straha20
Thursday, January 28, 2021 2:39 PM
richardgoncalves
Thursday, January 28, 2021 2:51 PM
DrunkenDemon
Thursday, January 28, 2021 3:04 PM
Fabulous looking system you have there!
god503
Thursday, January 28, 2021 3:24 PM
THAT IS AN AWESOME SETUP!!!!. I'm using the 1k bios and the power is set for 650 watts. Time spy extreme sucks every watt of that. A couple hours if cyberpunk and it tops out at 51c. At 650 watts. This water block is no joke.
SprayingMango
Thursday, January 28, 2021 3:51 PM
That is an absolutely amazing build!!!
Affiliate Code = I6E6SHELAX12900KASUS Z690 Strix E32GB DDR5 Corsair Dominator 5600Samsung 970 Evo Plus 2TBWD Black 2TB PCIe 4 NVMEEVGA 3090Ti FTW3 UltraCorsair AX1600i PSUCorsair 1000D Corsair QL120 fans x 15Corsair H150i Pro XTAsus PG27UQ w/ PG279Q x2
christobol
Thursday, January 28, 2021 5:45 PM
straha20 Finally got my system up and running with an Optimus block. This thing is a cooling beast! Tops out in the low 40c range at 2100mhz after an hour under full load. Pics of my system...
Not to trumpet everyone else, but that looks fantastic. I really like the super clean setup up top and using the passthroughs to hide the tubing moving around the case. On my first water cool build ja few months ago I did bent hard tubing and inside a Corsair 1000D. That case is so huge you end up with some long ass runs and you can see .5 degree deviations from 90 degrees on bends, especially when you stack 4-6 pends per tube. Super nice clean and nice.
post edited by christobol - Thursday, January 28, 2021 10:27 PM
Please consider using my Associate and Rewards codes to save 3-10% off your next EVGA purchase
richardgoncalves
Friday, January 29, 2021 2:06 AM
I can’t stop looking at this build. I don’t know how you focus on games; I’d just stare at this thing and get one tapped.
Just so much thought and care put into this design. So impressive!
ice water
Friday, January 29, 2021 10:12 AM
neomage2021
Friday, January 29, 2021 5:02 PM
Nice. I just got mine in! I was surprised how hefty it was! I also have a threadripper absolute waterblock from optimus
ajs2294
Friday, January 29, 2021 6:29 PM
Awesome build, just ordered mine today. Surprised how good looking the block is, the website photos stink!
phroze
Friday, January 29, 2021 6:33 PM
Case: Lian Li O11 Dynamic XLMobo: Asrock X570 TaichiCPU: Ryzen 5900xGPU: EVGA RTX 3090 FTW3 UltraRAM: Crucial Ballistix OC to 3800 16 18 18 1:1PSU: EVGA SuperNova G2 1600wCooling: Custom hardline loop: optimus blocks, primochill stuff, lian li stuff, HW Labs 60mm radiators, custom stuff
straha20
Friday, January 29, 2021 6:46 PM
phroze
straha20
richardgoncalves
Beautiful build! I just ordered the GPU block myself. Likely one of the first on today's batch as I was F5ing like crazy. Now comes the wild ride of waiting which can be quite the roller coaster with Optimus I hear. My question to you is what RGB strip did you stick on the block and what did you use to stick it on?
Thanks! The light strip is... https://www.amazon.com/gp/product/B088FKZWDQ/ref=ppx_yo_dt_b_asin_title_o05_s00?ie=UTF8&psc=1 And the adhesive is... https://www.amazon.com/gp/product/B007Y7EWRO/ref=ppx_yo_dt_b_asin_title_o03_s00?ie=UTF8&psc=1 The block uses 41 LEDS, and I soldered by own power and data connector on. I did not take the blue LED strip adhesive protector layer thingy off so that the back of the LED strip wouldn't stick to anything. The thickness of the clear adhesive and LED strip is a perfect snug with with the armor on my Crosshair Hero VIII board.
swiftblue
Friday, January 29, 2021 7:24 PM
I wanted to order the Optimus block today, but they didn't announce a time and went out of stock before I could refresh... Fun. Guess I'll stick with my EK block?
phroze
Friday, January 29, 2021 7:37 PM
swiftblue I wanted to order the Optimus block today, but they didn't announce a time and went out of stock before I could refresh... Fun. Guess I'll stick with my EK block?
They'll be releasing small batches weekly. Every Friday at 9am pacific. I got lucky today and got mine. Good luck to you.
phroze
Friday, January 29, 2021 7:40 PM
swiftblue
Friday, January 29, 2021 7:49 PM
phroze
Interesting, where'd you hear that? They still haven't responded to my email last week, or to my tweet. I was expecting them to release at 9am their time, so I was up early to spam refresh at 7am PST. I thought this was their first time opening orders since October.
phroze
Friday, January 29, 2021 7:51 PM
swiftblue
phroze
The info is on their website and on twitter. This is their first time opening orders since batch 2 and they are changing up the way they are doing the batches to weekly smaller batches.
straha20
Friday, January 29, 2021 7:52 PM
waldoh86
Wednesday, April 28, 2021 6:19 PM
Hey I am looking at the optimus block for my 3090. Do you have any vram junction temps during furmark or mining?
phroze
Wednesday, April 28, 2021 6:20 PM
waldoh86 Hey I am looking at the optimus block for my 3090. Do you have any vram junction temps during furmark or mining?
I hit max 74 junction temps while mining eth.
neomage2021
Wednesday, April 28, 2021 6:23 PM
When mining full time at max temp vram junction for me is 74 degrees as well
