mikerbyrne
Saturday, January 26, 2019 1:06 PM
I am having problems with the RCA outputs on my Nu Audio card. Installed the card and have no issues with the headphone output but when I want to use the RCA outputs they don't seem to work. In windows I see there is audio output in Windows Settings when I select Speakers (2-EVGA Nu-Audio). Not sure if it is a software issue or my RCA outputs don't work. Anyone have this issue? Thanks. Mike B
ErinW
Re: Nu Audio RCA output issues
Saturday, January 26, 2019 1:30 PM
Welcome to the forums! What are you connecting to the RCA output? It's going to be a line-level signal, so it may not be audible in your headphones.
EVGA_Lee
Moderator
- Ribbons : 14
Saturday, January 26, 2019 1:32 PM
Can you describe your setup a bit more? For example: - What kind of speakers are you using?
- Are you using the RCA to 3.5mm adapter?
- Have you tried reinstalling the drivers?
mikerbyrne
Saturday, January 26, 2019 1:34 PM
I am using powered genelec monitors so the line level output is fine. Not using the adapter. I have not tried reinstalling drivers but the line in works and the mic input also works. I will reinstall the drivers.
mikerbyrne
Saturday, January 26, 2019 1:59 PM
Reinstalling the drivers did nothing. I turned the onboard audio off in the bios and removed the onboard audio drivers previously. Still no RCA output but the headphone jack, line in and mic in all work. I haven't tested the SPDIF.
post edited by mikerbyrne - Saturday, January 26, 2019 2:44 PM
EVGA_Lee
Moderator
- Ribbons : 14
Saturday, January 26, 2019 3:42 PM
If you use the RCA to 3.5mm adapter with a pair of headphones, do you get audio out? Also, keep in mind that the headphone volume only works on the headphone out port. The main volume slider is necessary for the Line-out.
mikerbyrne
Saturday, January 26, 2019 4:06 PM
Yea no sound using the RCA to 3.5mm adapter with headphones. The volume is maxed in the EVGA Nuaudio software and in windows, still no output. I do see audio levels in windows/setting/sound and in the EVGA app when the EVGA speakers output is selected but so sound from the speakers or headphones using the RCA/3.5mm adapter. Again, the 1/8" headphone jack does work just not the RCA outs.
post edited by mikerbyrne - Saturday, January 26, 2019 4:22 PM
- Ribbons : 282
Saturday, January 26, 2019 5:26 PM
What Options do you have other than Speaker? Like Line In or Line Out A- Line Out RCA - R B- Line Out RCA – L
post edited by bcavnaugh - Saturday, January 26, 2019 5:32 PM
mikerbyrne
Saturday, January 26, 2019 5:31 PM
For output I can choose speakers or SPDIF for the Nu Audio. For Input I see mic and line in for the Nu Audio.
- Ribbons : 282
Sometimes Windows changes my Speakers to my Monitor and I have to change them back the Speakers. Check your Windows Setting.
post edited by bcavnaugh - Saturday, January 26, 2019 5:40 PM
EVGA_Lee
Moderator
- Ribbons : 14
Saturday, January 26, 2019 5:35 PM
Yeah, I hate to say it, but I believe you have a bad card. I was worried we would have to troubleshoot some issue with your speakers, but if the RCA ports don't work with your headphones, then there is likely something wrong in the Line-Out section of the card. You have the Default Playback set correctly, so there's nothing else to do there. If you're willing to wait until Monday or Tuesday, I can have our engineers take a quick look to see if there's a way to fix this, but this seems like an issue that will require an RMA.
mikerbyrne
Saturday, January 26, 2019 5:37 PM
Thanks for the followup. I will wait until next week. Yea the RCA outputs don't work to my power monitors or my receiver. And like you suggested they don't work with headphones and the RCA to 3.5mm adapter.
mikerbyrne
Saturday, January 26, 2019 5:50 PM
I can select either monitor or speakers but I have the default set to speakers. Still no output. bcavnaugh Sometimes Windows changes my Speakers to my Monitor and I have to change them back the Speakers. Check your Windows Setting.
- Ribbons : 282
Saturday, January 26, 2019 6:13 PM
mikerbyrne I can select either monitor or speakers but I have the default set to speakers. Still no output.
Also no output to the monitor speakers? Do you have the NVIDIA HD Audio Driver installed?
mikerbyrne
Saturday, January 26, 2019 8:17 PM
I can get output via the monitor speakers if I select my monitor. I uninstalled the NVIDIA HD Drivers but it didn't help.
jll544
- Ribbons : 9
Sunday, January 27, 2019 1:43 AM
One of your screenshots shows you have "Back" headphone selected in the Nu software. Does it make any difference if you select "Auto" and unplug your headphones?
EVGA_Lee
Moderator
- Ribbons : 14
Sunday, January 27, 2019 1:58 AM
jll544 One of your screenshots shows you have "Back" headphone selected in the Nu software. Does it make any difference if you select "Auto" and unplug your headphones?
No, since this only applies to either the rear headphone output port (back) or the front panel output (front).
jll544
- Ribbons : 9
Sunday, January 27, 2019 2:31 AM
EVGATech_LeeM No, since this only applies to either the rear headphone output port (back) or the front panel output (front).
Does this card output simultaneously to RCA and headphone? Given what I've seen of the design (headphone signal sourced from line-out signal path), it would make sense to cut off RCA while headphone is active (to keep the signal clean from whatever is connected to RCA).
EVGA_Lee
Moderator
- Ribbons : 14
Sunday, January 27, 2019 5:21 AM
jll544
Currently, Line-Out (RCA) and Headphone-Out run simultaneously, but you can mute the Headphone-Out on the Headphone volume section. If you mute the Line-Out, it will mute both. In a future update, we'll give the option to mute either Line-Out or Headphone-Out, or allow them to run simultaneously.
mikerbyrne
Monday, January 28, 2019 3:03 PM
Yea it looks like my line out section is bad. I will need an RMA. I can get good output on the headphone jack but nothing from the RCA line output section. Mike EVGATech_LeeM
jll544
EVGA_Lee
Moderator
- Ribbons : 14
Monday, January 28, 2019 5:31 PM
Hi Mike, Our engineers also believe this is bad line-out/RCA issue, so it will require an RMA. I'll have one of our CS reps reach out to you. Thanks for troubleshooting the issue fully!
mikerbyrne
Monday, January 28, 2019 5:37 PM
Thanks I will look out for the RMA email. Mike EVGATech_LeeM Hi Mike, Our engineers also believe this is bad line-out/RCA issue, so it will require an RMA. I'll have one of our CS reps reach out to you. Thanks for troubleshooting the issue fully!
JacobB
Monday, January 28, 2019 5:39 PM
Hello! I will be reaching out to you shortly to get an RMA setup for you for the NuAudio card. Please look forward to my call / E-Mail! -Jacob B.
DRI420
Wednesday, July 31, 2019 4:39 AM
I just got my card today and am having the exact same problem.
singularity_70
Sunday, January 19, 2020 6:48 AM
Hi EVGA, I got a NU Audio card to for Christmas as a present from my wife. Card installed perfect, front panel output works flawless, but the back headphone and the rca out is extremely distorted, and it has really low volume and unpleasant crackly sound. I have the latest drivers and software also have the latest firmware. Using it in a up to date 64bit windows 10 pro environment. Also the motherboard audio is disabled in the bios.
AMD Ryzen 9 3900X ASUS X570 PrimePro v140532GB G-Skill Neo DDR4 @ 3200 CL14Sapphire 5700XTEVGA Nu Audio Pro v0.2.1.7Sabrent Rocket nvme Gen4 2Tb EKWB water cooling Win10 Pro 1909
RizenBB
Sunday, January 19, 2020 7:00 AM
singularity_70 Hi EVGA, I got a NU Audio card to for Christmas as a present from my wife. Card installed perfect, front panel output works flawless, but the back headphone and the rca out is extremely distorted, and it has really low volume and unpleasant crackly sound. I have the latest drivers and software also have the latest firmware. Using it in a up to date 64bit windows 10 pro environment. Also the motherboard audio is disabled in the bios.
Does it improve if you disconnect the front audio panel connector from the board?
- Rizen AMD Ryzen 5800X3D, MSI MEG X570 ACENVIDIA RTX 3090 FE, LG 38GL950G-B UltraGear 38" displayEVGA Nu Audio Pro, Sennheiser HD6XX + KEF LSX speakersFull custom loop, 3x SR-2 480mm rads, AquaComputer controllers, EWKB fans and blocks
singularity_70
Sunday, January 19, 2020 7:41 AM
No effect after the front audio panel connector unplugged. Same, highly crackly distorted low volume through the back plugs.
post edited by singularity_70 - Sunday, January 19, 2020 8:03 AM
Jb1234
Sunday, January 19, 2020 12:55 AM
I am also getting distortion seems to go away when I change the sample rate tho
singularity_70
Sunday, January 19, 2020 4:51 PM
Jb1234, changing the sample rate on my card has no effect on the back-output distorted crackly sound, it also has maybe 30-40% of the volume compared to the front-out. While the front-audio-out do produce flawless quality regardless of sample rate. The back-out really sounds like an under powered but completely broken paper speaker, even so i connected to a high quality AKG headphone.
