Hot!Nu Audio Pro - Diablo IV Audio Cutting Out
RMui
2024/11/21 13:12:29 (permalink)
Anyone still using this sound card with their PC and playing Diablo IV? When I try to play audio through my headset powered by the Nu Audio Pro, the audio cuts out. If I change the audio source to my external DAC which powers my speakers, no issues with sound. I don't seem to have any issues with audio on any other games. It's just Diablo IV where I cannot get sound working. Is this an issue with the audio drivers?
4 Replies Related Threads
    EVGATech_ChrisB
    EVGA Tech Support
    Re: Nu Audio Pro - Diablo IV Audio Cutting Out 2024/11/21 14:10:55 (permalink)
    If you open the "Sound Control Panel" in Windows (Under playback, double click your headphones).
    Choose the Advanced Tab and then uncheck all of the Exclusive Mode check marks.
    • Allow applications to take exclusive control of this device
    • Give exclusive mode applications priority
    Please see if this helps you.
    RMui
    Re: Nu Audio Pro - Diablo IV Audio Cutting Out 2024/11/21 19:40:51 (permalink)
    Unchecked both settings as requested and as soon as I load into the realm, I lose sound. If I tell the game to use the EVGA card, I can hear sound momentarily, and then it just goes silent. If I change the game settings to default, I again get sound for a moment and then I lose it again. I'm attempting to scan and repair my downloaded game files to see if there is an issue with the game, but it doesn't seem too plausible since a different audio output works.
    • Ribbons : 271
    Re: Nu Audio Pro - Diablo IV Audio Cutting Out 2024/11/22 20:39:44 (permalink)
    What's your audio sample rate and bit depth? 44.1 or 48 khz and 16-bit have the best compatability.
    RMui
    Re: Nu Audio Pro - Diablo IV Audio Cutting Out 2024/11/23 15:04:59 (permalink)
    Good call on the sample rate.
    Originally had the sample rate as 24 bit, 41000 Hz, which wasn't working. On my external DAC, I had 24 bit, 48000 Hz, which was working, but it still didn't work when I changed this on the Nu Audio Pro card. Since I had no luck, I just applied the Windows default, and low and behold, it works. 32bit, 48000Hz working! Honestly, don't recall changing the sampling rate, but I've had this card for a while now. Weird this was the only gaming giving me issues with sound.
    Thank you!
