AnsweredNeed help finding a CPU Air Cooler that will fit the X299 DARK EATX before I buy.
rusTORK
Re: Need help finding a CPU Air Cooler that will fit the X299 DARK EATX before I buy. 2019/02/22 06:23:17 (permalink)
saberwalk
Yes, that is because I used the offset to clear the VRM fan assembly at the top.  As I recall, I tried the other orientation first, but the clearance was not good.
Can you please find time to take picture of the gap between Noctua NH-D15S and X299 Dark VRM heatsink\coolers? Quality of the picture isn't important, but it may help me to understand gap of and possible option to install another cooler - Phanteks PH-TC14PE.
Here is scheme of Noctua NH-D15S:
At bottom right you may see that cooler is 150mm total, but distance to center isn't equal: one side is 67mm, another is 83mm. That's why it must be rotated? Longer side will be at top PCI-Express slot side, short one - at VRM side. Am i correct?
Another my question is - how much free space is left at VRM side? You may place phone camera near motherboard power button (parallel to RAM) and take picture of the gap.
Also, can i use top PCI-Express slot with a Riser (for vertical GPU mount for example)?
#61
jollydet
Re: Need help finding a CPU Air Cooler that will fit the X299 DARK EATX before I buy. 2019/02/23 19:44:58 (permalink)
Phanteks PH-TC14PE fits i have one i use when cleaning out my waterblocks.
#62
rusTORK
Re: Need help finding a CPU Air Cooler that will fit the X299 DARK EATX before I buy. 2019/02/24 00:26:04 (permalink)
jollydet
Is it fit o.k.? Not blocking anything? Which configuration do you use (1,2,3 Fans)?
#63
max1024
Re: Need help finding a CPU Air Cooler that will fit the X299 DARK EATX before I buy. 2019/10/12 05:24:43 (permalink)
Does Noctua NH-U12A fits ? It would be nice to see somewhere a list of compatible air coolers for this wonderful motherboard. What are the most powerful air coolers suitable for it so that the first PCi-E slot does not overlap and regular fans remain on the VRM?
i9 10980XE, 32Gb DDR4 4133Mhz, EVGA x299 Dark
3175X, 48 GB DDR4, EVGA SR-3
#64
FROSTYBE3R
Re: Need help finding a CPU Air Cooler that will fit the X299 DARK EATX before I buy. 2019/10/13 02:13:47 (permalink)
Can you please not buy the x299 dark if you're going to use an air cooler? That's a waste ffs.
#65
  • Ribbons : 86
Re: Need help finding a CPU Air Cooler that will fit the X299 DARK EATX before I buy. 2019/10/13 02:21:20 (permalink)
FROSTYBE3R
I sort of agree on this. Buy a good AIO watercooler at least.
#66
FROSTYBE3R
Re: Need help finding a CPU Air Cooler that will fit the X299 DARK EATX before I buy. 2019/10/13 02:23:53 (permalink)
FROSTYBE3R
No, just no, custom loop, chiller, dice or LN2. This board isn't for normies, neither is X299.
#67
