RypeSauce
my 3080ti seems to be running into a power limit sometimes at 370 and at times at 397 while running furmark https://i.imgur.com/YmCR1xz.jpg
post edited by RypeSauce - Sunday, July 18, 2021 6:38 PM
08G-P5-3785-KL 6/15/2021 11:36:17 AM PT No08G-P5-3797-KL 6/10/2021 6:16:17 AM PT Yes12G-P5-3958-KR 6/3/2021 8:05:53 AM PT No 12G-P5-3968-KR 6/3/2021 7:48:08 AM PT No 12G-P5-3967-KR 6/3/2021 7:28:32 AM PT Yes12G-P5-3959-KR 6/15/2021 11:40:43 AM PT NoPlease use my Associate Code at your checkouts for up to 10% discounts on all your EVGA purchases: R7WBIB2D5W1AMCI
- Ribbons : 86
Re: My 3080ti FTW seems to run into power limit on furmark, need help figuring out why
Sunday, July 18, 2021 7:03 PM
Furmark is the worst benchmark you can run. Try another benchmark. At one time NVIDIA put a limitation of that benchmark into their driver to throttle down the card and I don't know if that is still the case.
kevinc313
- Ribbons : 22
Sunday, July 18, 2021 8:30 PM
Try +120 core and MSAA 2x.
RypeSauce
Monday, July 19, 2021 10:30 AM
this is with 3dmark the free version , it maxes out at 395w https://imgur.com/NgELQwU trying +120 core and Msaa 2x did not change much on furmark Should i be focusing on GPU power 445w or GPU HV0 INPUT power (sum) 395w ?
post edited by RypeSauce - Monday, July 19, 2021 10:34 AM
kevinc313
- Ribbons : 22
Monday, July 19, 2021 12:21 AM
RypeSauce this is with 3dmark the free version , it maxes out at 395w https://imgur.com/NgELQwU trying +120 core and Msaa 2x did not change much on furmark Should i be focusing on GPU power 445w or GPU HV0 INPUT power (sum) 395w ?
That 447w max board power is great, that's about as good as you're going to do. Try starting Furmark, letting it run a few minutes, then reset logging and get the average power about 5 minutes. I recommend the 2x MSAA and overclock because I feel it gets the GPU into it's normal high load zone vs. just bogging it down. Your TS GPU score is pretty bad, but that probably has to do with the potatoe cpu and heatsoaking the card with the demo run on the free version.
post edited by kevinc313 - Monday, July 19, 2021 12:22 AM
Gintama6888
Monday, July 19, 2021 12:30 AM
Try different benchmark like 3DMark or Unigine Superposition etc.
RypeSauce
Monday, July 19, 2021 12:49 AM
kevinc313
yea made me curious as to why my scores were super bad, but i guess youre right ,the pottao Cpu and the demo run does hinder it a bit, just waiting on ddr5 to release so i can upgrade , Thank you for your help all of you
