https://www.fjoddes.net/index.php/pr-montech-launches-z3-pro-argb-fan-3-in-1-pack/ Montech, a new enthusiast PC Case, Power and Cooling solutions brand is releasing their new Z3 Pro ARGB Fans. The 120 mm Z3 Pro ARGB Fan 3-in-1 pack comes with a fully expansion ready remote controlled ARGB Fan Control Hub capable of controlling a total of 12 fans (6*3-pin + 6*4Pin PWM). The ARGB Fan Control Hub is also compatible with the latest Mainboard ARGB software. Along with proprietary silent fan blades, integrated vibration absorbers, PWM smart fan speed control and full ARGB programmability tied into a 3-in-1 fan package makes the Z3 Pro both highly competitive and feature rich addition to anyone looking to dive into RGB modding.
The 120 mm Z3 Pro ARGB Fan is the upgraded version of the Z3 with a ton of new features. Temperature based PWM Smart Control, industry acclaimed rifle bearing and proprietary fan blade design has made the Z3 Pro even cooler, smarter, quieter and even longer lasting. Besides increased performance the ARGB lighting capabilities are also vastly improved with new and better effects. So you get the best of aesthetics and performance, a cool but also quiet PC system.
I do like the RGB effect here
