I am having issues with setting up my LED Sync/DG-77 Case. Below is the list of events:
1 - Computer was set up and running with LED Sync for a month but I had installed the DG Tuner (just didn't use it)
2 - Installed Cooler master RGB Fans and a EVGA 1080 TI Hybrid FTW3
3 - LED Sync worked on all components (CLC, MOBO, Case LED) but the GPU
4 - Booted up the DG Tuner to try and sync all lights but an error registered:
5 - So my knee jerk reaction was to uninstall EVGA Sync, so I did
6 - I also removed Sync from the registry and start up
7 - Uninstalled all EVGA Programs and removed their folders from the C:
8 - Restarted and reinstalled programs starting with the DG Tuner only to receive this Error:
9 - So I went into my temp files and cleared them all and started back at step 6
10 - Currently all of colors that I set on the case with sync (purple) have now reset to white. Might be a sign of progress?
11 - Cleared all files relating to EVGA after uninstalling, shut down, removed power cord and drained the capacitors. Upon restart all LEDs are white except the CLC which is still purple.
12 - Reinstalled Precision X OC (6.2.7) First and the LED Sync button is activated and I cannot deactivate it. Installed Flow Control and it has reset the LED to LED Rainbow but I cannot enable LED sync.
13 - Reinstalled DG Tuner v 1.0.5 and I register the same Error 1722
**Current State of RGB- RGB LED fan at the rear connected to the MOBO and MOBO (Z370 Classified K) are not illuminated
- GPU, CASE, FANS on the RGB case board are illuminated White
Looking for any suggestions or experience with this issue!
