https://www.techpowerup.c...h-50-75-w-power-limits A Chinese OEM put a desktop Intel Arc "Alchemist" A380 GPU on an MXM board for notebooks and mobile workstations with upgradable graphics. This isn't the mobile A380M, but rather the desktop A380 that has been designed into an MXM 3.1 type-A board that's capable of PCIe Gen 4 x8. The 6 nm ACM-G11 ASIC is flanked by three GDDR6 memory chips that make the board's 6 GB of memory across its 96-bit memory bus. What's interesting about this board is its tight power limits, which are set at 50 W, that can draw up to 75 W. The card puts out three HDMI and one DP outputs. Its cooling solution mount-hole spacing appears to match that of the popular GeForce GTX 1050 Ti.
I expect this to support low level graphics.
