kikkoman123
Re: Installed Bykski Water Block on EVGA 3080 FTW3 ULTRA
2021/03/10 19:11:56
ComputersAre8ad How thick is the water block from slot down? My Alphacool block is a fatty and I'm trying to see if I can shave down a few mm so better airflow in my SFF case
does this help?
i7 10700K OC by AI 39% Asus z490-H STRIX Corsair Vengeance RGB 3200 C16 EVGA 3080 FTW ULTRA Bykski WB Corsair Hydro X Cooling: XC7 - XD5 - XR7 P&P - XR5 - 4 x 120mm QL - 3 x 120mm LL - 2 Noctua Lian Li ROG Certified O11 XL THICC Pic - https://imgur.com/qQkJpEB
Lord Winchester
2021/03/11 00:43:34
kikkoman123
does this help?
Oh heck! I totally forgot, that technical specs are a thing😂. The mounting instructions where so useless, that I ignored everything else from the website😅
micfogas
2021/03/12 05:45:46
☄ Helpfulby kikkoman123 2021/03/12 20:05:22
I ordered my Bykski block for the 3080 ftw3 ultra, from a seller on amazon. I talked with him a bit. I paid for expedited and it got to me from china in ... 3 days? Took him a couple days to ship. But I ended up getting my block well before my card, which is actually arriving today.
I didn't go for the backplate, but now I'm kinda thinking I should have. I'm vertical mounting it tho, in my view 51. I got a new PCIe 4.0 16x capable riser ribbon, since the one I've got now is the cheap thermaltake one (not the premium). I've had a new psu all week, to put in. I've been slacking and still haven't. I got sleeved white cables (I have the view 51 Snow) for my 24pin, both eps, and all 3 PCIe.
I'm also tempted to get the addon display module for the Bykski, just because it looks neat. Displays temp I think. Haven't found the back plate for sale by itself but I might talk to that guy from Amazon and see if I can get one.
I've got a lot of work to do today on my system .. 🙂
Lord Winchester
2021/03/12 06:50:44
micfogas I ordered my Bykski block for the 3080 ftw3 ultra, from a seller on amazon. I talked with him a bit. I paid for expedited and it got to me from china in ... 3 days? Took him a couple days to ship. But I ended up getting my block well before my card, which is actually arriving today.
As far as i know, they always come with Backplate. Are you sure you don´t have one?
micfogas
2021/03/12 14:21:58
Lord Winchester
As far as i know, they always come with Backplate. Are you sure you don´t have one? Â
100% positive. They had it for sale with and without. I figured since I'm vert mounting, it's not necessary. And it's not. I'm not worried about the temps. my loop should keep it well within comfort levels. But the asthetic. 🙂 I can order the back plate separate. I seem to have an issue with back plates...
rangerscott
2021/03/12 14:50:10
Is there anything in the back side of a 3080 that gets hot like that 3090's?
12900k Z690 Dark Evga 3090 Hybrid 32gb Trident z5 @ 6000 Corsair RM1000X psu
Lord Winchester
2021/03/12 14:57:07
micfogas I seem to have an issue with back plates...
Then you´re going to hate this Backplate :-D. I mean, it´s more or less straight forward, but i mounted and unmounted it about 15times changing Thermal Pad Configurations before i was happy (or maybe fed up) with the Backplate allignment and how the Cooler sits. Just be very very carefull when removing the stock Aircooler. There is not much room to wiggle and twist, before you collide the aircooler wit some Capacitors.
Lord Winchester
2021/03/12 15:00:16
rangerscott Is there anything in the back side of a 3080 that gets hot like that 3090's?
Not really. But you can passively take some heat away from behind GPU Die
micfogas
2021/03/12 16:22:32
Lord Winchester
My issue is more... Umm.. losing them. 😂 Almost cost me my step up. Thankfully I found it. Ups should be here within the hour. And I haven't even pulled my old PSU out yet. I better get moving on it.
micfogas
2021/03/12 16:24:11
How picky is this block with pad thickness/position? I mean obviously they have to line up, but anyone have an issue with the cold plate not making good enough contact with the die?
kikkoman123
2021/03/12 20:07:33
micfogas How picky is this block with pad thickness/position? I mean obviously they have to line up, but anyone have an issue with the cold plate not making good enough contact with the die?
ive read some people in the past had some issues with 2080/1080 blocks. haven’t read anything on the 3080/90 block so far. it’s cnc machined if that matters.
critofur
2021/04/12 09:08:36
Lord Winchester The Build is done BTW [pic removed]
Very nice, but, one thing would drive me nuts: the angle of your GPU card - how come it's angled like that?
kikkoman123
2021/04/12 21:52:55
critofur
its angled horizontal. do u see something else?
Rustlinjimmies
2021/04/15 22:09:00
So I ordered a byski block but found someone selling an ek block local never used so I said screw it but then I stuumbled on the thread of the ek blocks bricking the ftw3 cards so now im on the fence if I should just a avoid the ek block now. Any advice would be lovely thank you
phroze
2021/04/16 07:50:04
kikkoman123
critofur
I think he is talking about Lord Winchester's. Looks like it is running down hill. I used the EK bracket to avoid that issue.
Case: Lian Li O11 Dynamic XLMobo: Asrock X570 TaichiCPU: Ryzen 5900xGPU: EVGA RTX 3090 FTW3 UltraRAM: Crucial Ballistix OC to 3800 16 18 18 1:1PSU: EVGA SuperNova G2 1600wCooling: Custom hardline loop: optimus blocks, primochill stuff, lian li stuff, HW Labs 60mm radiators, custom stuff
kikkoman123
2021/04/18 01:23:34
Rustlinjimmies So I ordered a byski block but found someone selling an ek block local never used so I said screw it but then I stuumbled on the thread of the ek blocks bricking the ftw3 cards so now im on the fence if I should just a avoid the ek block now. Any advice would be lovely thank you
can u post a link to the thread about ek blocks bricking? u cancel yer order for the bykski block? side note: i changed my setup to bottom intake, side exhaust p/p rad and top exhaust rad, rear single intake.
post edited by kikkoman123 - 2021/04/18 01:34:41
rrusek
2021/04/21 17:58:39
Can you please PM me with guide/breakdown video of putting a Bykski water block on a 3080 FTW3 ULTRA. I would PM you but am new to the forum so I do not have enough posts to be able to pm people. Thanks, RJR
rrusek
2021/04/28 19:56:24
Can anyone confirm that they have or have not used the supplied washer / spacers for the 3080? I have been reading that they are only required for the 3090? Thanks, RJR
rrusek
2021/04/28 19:59:55
Also can the supplied thermal pads be used for the installation? I have read that you need 1mm pads for the vram and 1.5 for everything else. Thanks, RJR
rrusek
2021/04/28 20:02:01
Can someone specify what temps you are getting for the memory under load? I am getting 80c, is that normal? Thanks, RJR
ddog661
Flagged as Spam (1)
2021/04/28 20:02:33
rrusek
2021/04/28 20:14:58
Also has anyone stacked pads on the inductors so that they touch the water block? Thanks, RJR
D3_GX
2021/04/30 19:46:01
Nice but please use temps in Celsius next time.
Dabadger84
- Ribbons : 10
2021/05/01 01:38:07
So how are your temps with this thing on standard loads, like say a single run of Port Royal? I'd love to compare notes now that I have a HydroCopper block on my Kingpin.
kikkoman123
2021/05/02 03:05:41
rrusek Can you please PM me with guide/breakdown video of putting a Bykski water block on a 3080 FTW3 ULTRA. I would PM you but am new to the forum so I do not have enough posts to be able to pm people. Thanks, RJR
Its less of a breakdown but more of just a light guide. Bascially follow the gamers nexus breakdown then follow the bykski instructions. rrusek Can anyone confirm that they have or have not used the supplied washer / spacers for the 3080? I have been reading that they are only required for the 3090? Thanks, RJR
Do not use the spacers for the 3080. rrusek Also can the supplied thermal pads be used for the installation? I have read that you need 1mm pads for the vram and 1.5 for everything else. Thanks, RJR
Of course they can be used, thats what it comes with. They are 1.7 or 1.8 mm. rrusek Can someone specify what temps you are getting for the memory under load? I am getting 80c, is that normal? Thanks, RJR
80c for a air cooled or water cooled? high for air but WAY too high for water. im getting max 120f (48c) with undervolt with 80F (26C) ambient, and thats on a hot day. D3_GX Nice but please use temps in Celsius next time.
No. Merica. Dabadger84 So how are your temps with this thing on standard loads, like say a single run of Port Royal? I'd love to compare notes now that I have a HydroCopper block on my Kingpin.
I dont do synthetic benchmarks. I play games. I will say that in the Shadow of the Tomb Raider bench mark this is the result. Stock AVG FPS - 102, Min 80. OC 2160mhz - 106, Min 84. UnderVolt 1890mhz - 100, Min 73.
Dabadger84
- Ribbons : 10
2021/05/02 03:10:00
kikkoman123
Temperatures mate, not FPS. Also Port Royal is a great example of how RTX titles would play on a GPU, which is why it's a standard thing folks run to check out their new hardware or new cooling.
kalebg1
2021/05/02 12:29:55
Lord Winchester
This is the MP5WORKS Backplatecooler
Watercooled backplate. Seems excessive....Now I want one lol
AMerexican
2021/05/02 14:44:00
Isn't excessive the whole point of custom loops? :P
Dabadger84
- Ribbons : 10
2021/05/02 15:44:35
kalebg1
Lord Winchester
   This is the MP5WORKS Backplatecooler Â
If you're going to put a block on the card, the backside just needs a pad upgrade & some heatsinks as I've shown with my memory Temps.
kikkoman123
2021/05/03 06:08:00
Dabadger84
kikkoman123
The only thing that really pushes its power level that I play is quake II rtx, 120f max in a hot 80f room
