https://www.techpowerup.com/329942/inwin-launches-new-ar36-aio-cpu-liquid-cooler-with-infinity-mirror-design-and-neptune-argb-fans In Win Development Inc. (InWin), a leading innovator in PC enthusiast and gaming hardware, had introduced its new AR36 (360 mm) AIO liquid cooler featuring an "infinity Mirror" design, compatible with both AMD and Intel platforms.
Infinity Mirror Block
The ARGB-infused CPU block features an infinity mirror design on the front, showcasing radiant light reflections that create an infinite, vibrant, and colorful glow from every angle. Inside, high-density microchannel fins in the copper baseplate efficiently draw heat away from even the hottest processors, minimizing the temperature delta to unlock maximum headroom for sustained thermal boost clock speeds. The pump is equipped with a three-phase, six-pole motor, ensuring consistently high performance with reduced noise during operation.
Fin-tastic Heat Dissipation
Available in black or white, the 360 mm radiator is 27 mm thick and manages to fit 20 fins per inch, providing an exceptionally large surface area for heat transfer and enhancing thermal conductivity.
Silent Static Pressure Neptune AN120 Fans
InWin bundles three Neptune AN120 fans with the AR36. These ARGB fans feature a turbine blade design specifically created to generate high static pressure, making them ideal for liquid cooling radiators. With PWM control, they offer up to 60.1CFM airflow and an impressive 2.27 mm H2O pressure, at just 20.5 dBA (normal).
Tool-free Mounting on the CPU sockets
The AR36 supports all recent AMD and Intel CPU sockets, including the latest AMD AM5 and Intel LGA1851. It comes with durable mounting kits and a tool-free design for the CPU block, ensuring installation is as simple and easy as possible.
Looks like a good design.
