Hi,
I am trying to OC my brother gaming computer, the Q9550 runs stock at 2.83Ghz with 1333.3Mhz FSB at 350MHz BUS at 1.28V Vcore 1.20V VTT, 1.30V NB voltage, 1.5V SB voltage
RAM is a samsung DDR2 800 PC-6400 6-6-6-15 1.90V DIM voltage.
I hope I put enough information here, all that is with out manipulation.
Now I increase FSB litle by litle but I can get it stable at more then 1493Mhz = 3.12GHz CPU speed, yea I unlinked the RAM so I making sure I am running it at 800Mhz, I increase Vcore to 1.4V and NB VTT but nothing seems to make it stable and I keep failing on PRIME95 with a FATAL ERROR possible hardware failure message.
any Idea why? and what I can do to make it stable?
oo and yea this is the System specs:
Case: Thermal take I am not sure on model
mobo: ASUS P5N-D
CPU: INTEL Q9550
CPU cooler: Thermaltake Contact 30 with 120mm blue LED fan
RAM: SAMSUNG DDR2 800 PC-6400 6-6-6-15 2T 1.9V
GPU: 2x EVGA GTX285 in 2 WAY SLI
PSU: CORSAIR TX850W
wireless card not too sure the brand or model
