How do you drain your water cooling loop?
ak420boarder
2013/03/09 22:08:58 (permalink)
At some point you need to drain the loop. How do you do it?
Do you just disconnect and quickly move over a bowl?
Do you have a plug at a low point specifically for draining?
I've only built one loop. When I did it I was advised to put a T at the low point so I could easily drain if I needed.
How do you do it?
25 Replies Related Threads
    rmorse27
    • Ribbons : 19
    Re:How do you drain your water cooling loop? 2013/03/10 05:03:49 (permalink)
    This is what I did to drain my loop,I placed a bitspower shut off valve at bottom of my res.I connect a piece of extra tubing to it then open valve and drain into a empty gallon jug.This also helps to flush the system as well.
    Intel i9 14900kf-Asus Z790 Rog Strix-E Wifi-Corsair 64GB @6400 DDR5-EVGA 3080TI FTW HC-EVGA G6 1000 PWS-Samsung Pro 2TB 4.0-Thermaletake Case-Corsair Pump/Res Combo
     http://www.heatware.com/eval.php?id=66896
    flasher4q
    Re:How do you drain your water cooling loop? 2013/03/10 10:58:18 (permalink)
    I put in a drain plug at the bottom of my loop...the block and plug I used Koolance....their are others out their....I find it easier it to have a drain bottom with enough to get the drain plug outside of the case that way no water inside...just my .02.....in my mods pics the first pic you can see my drain plug and temp setup...
    Asus ROG Strix B550-F gaming
    Ryzen7 5800x
    Corsair Dominator Platinum 32 Gig 3600
    Samsung 1T 980 PRO PCIe 4.0
    Samsung 500Gig 970 Evo PCIe 3.0
    MSI GTX 1080Ti
    Thermaltake Pump/Res combo
    Primochill 2 120x2 Radiators
    Bitspower G1/4" Premium master fittings
    Corsair RM 850x
    CoolerMaster H500P Case
    EK-Quantum Velocity D CPU cooler
    Bose Companion2 Speakers
    loveha
    • Ribbons : 65
    Re:How do you drain your water cooling loop? 2013/03/10 12:37:41 (permalink)
    I drain as much as I can from the bottom port of my GPU block. Then I just start taking things apart and drain as I go. I tried doing the whole drain line thing, just to much of a hassle.
    Case - Phanteks Enthoo Evolv X
    Mobo - EVGA X570 FTW
    CPU - AMD Ryzen 9 5900X
    RAM - 32GB Trident Z Royal 3600MHz 14-14-14-34
    GPU - EVGA RTX 3080 Ti FTW3 Ultra Gaming
    PSU - Seasonic Prime TX-1000
    Heatkiller IV CPU Waterblock / Heatkiller V GPU Waterblock
    Heatkiller V EBC Active Backplate / Two Heatkiller Rad 360 L
    Six Noctua NF-A12x25 / Heatkiller D5 Pump
    tpb7463
    • Ribbons : 9
    Re:How do you drain your water cooling loop? 2013/03/10 19:13:34 (permalink)
    Put a ball-valve with drainport drilled into the bottom of the case (from my build-log):
    SR-2 Buildlog: http://www.evga.com/forums/tm.aspx?m=1018539
    EVGA SR-2 | 2 x 5650's @ 4 GHz | 2 x EVGA GTX590's | GTS 450
    CAxVIPER
    Re:How do you drain your water cooling loop? 2013/03/10 19:32:30 (permalink)
    I had the same as above. Drain port with a ball valve. Would just take it outside and let it drain
    ak420boarder
    Re:How do you drain your water cooling loop? 2013/03/10 20:01:58 (permalink)
    Interesting where did you obtain that ball valve? and more importantly do they carry 3 ways?
    CAxVIPER
    Re:How do you drain your water cooling loop? 2013/03/10 20:07:05 (permalink)
    ak420boarder
    I just picked mine up from performance PC. It is a bits power fitting, not sure if they make 3 way or not.
    feniks
    • Ribbons : 38
    Re:How do you drain your water cooling loop? 2013/03/10 20:19:30 (permalink)
    I have an inline drain valve (Koolance) below my GPUs right before the tubing goes back up to reservoir. To drain the loop I usually tilt my case, rest it against a desk and open the drain stretching the piece of tubing over a bowl/bucket. With sealed loop this drains only a little (vacuum lock effect).
    Later I attach a piece of tubing to it and route it to bucket while I open the fill port on reservoir and open the drain on my external radiator. That drains most of water out, pretty much it leaves only pump and internal 360 rad with water in.
    If I need to totally drain the system I disconnect the parts and drain them completely as I remove them.
    Having a drain valve at bottom of loop rarely drains the whole system, all depends also on how the tubing is routed, how radiators are placed (horizontal/vertical), where the ports are, etc. etc.
    Even with drain at bottom, my loop is a b*tch to drain unfortunately and having an external rad with bottom ports (that I used as extra drain ports) is a life saver. Draining the front 360 Crossflow radiator placed vertically is another story LOL, to that I usually remove it together with pump (connected to its "bottom" fitting) and drain those outside of case.
    post edited by feniks - 2013/03/10 20:27:14
    dipdippotatochip
    Re:How do you drain your water cooling loop? 2013/03/10 20:39:06 (permalink)
    Why must the loop be drained?
    Rei86
    • Ribbons : 9
    Re:How do you drain your water cooling loop? 2013/03/10 20:45:26 (permalink)
    dipdippotatochip
    Just like how you gotta clean the dust out from a air system, you drain a loop to make sure the water stays fresh to keep algae and other build up.
    RIG 1 - i7-4790K / Asus Z97 Gryphon / AMD Sapphire RX Vega 64 / 8GB*8GB G.Skill Trident X 2400Mhz CL10 / SeaSonic Prime Ultra 1000w Plat
    RIG 2 - Pentium G3258 / ASRock Z97 Extreme9 / AMD XFX RX580 GTS XXX x4 / 8GB*8GB Kingston HyperX Fury 1600Mhz CL10 / Corsair AX1200i
    dipdippotatochip
    Re:How do you drain your water cooling loop? 2013/03/10 20:53:22 (permalink)
    Rei86
    dipdippotatochip
    Isn't that what silver coils and anti-macrobiotics are for
    lundrog
    Re:How do you drain your water cooling loop? 2013/03/10 21:49:11 (permalink)
    Subscribed to learn more.
    Roger Lund - Turbo VMware Nerd.
    Intel I7 3930k in Thermaltake 2.0 extreme water AIO push config
    ASUS Rampage IV Extreme EATX Motherboard
    Kingston HyperX Beast 64 GB Kit (8x8 GB) 2133MHz DDR3 PC3-17000
    3X EVGA GTX 980 SC in SLI
    3x Micron M500DC 256GB, 2x Micron M600 500GB , Samsung 1TB Evo.
    2x Evga supernova 1300 g2 PSU w Vantacor Dual PSU Adapter Cable 24 Pin 2-way
    Corsair 900d case
    ak420boarder
    Re:How do you drain your water cooling loop? 2013/03/10 22:13:48 (permalink)
    dipdippotatochip
    Clean it. Repair or replace a part. Upgrade a part. Things like that.
    ak420boarder
    Re:How do you drain your water cooling loop? 2013/03/10 22:22:16 (permalink)
    CAxVIPER
    ak420boarder
    Found them thanks. Though i'm really interested in a 3 way valve if anyone knows where those could be found.
    feniks
    • Ribbons : 38
    Re:How do you drain your water cooling loop? 2013/03/10 22:29:19 (permalink)
    ak420boarder
    dipdippotatochip
    mostly this for me LOL. I usually drain it every or every other month in order to replace/upgrade/add something ... that surely has to stop at some point LOL as it gets me tired LOL.
    ak420boarder
    CAxVIPER
    ak420boarder
    I use a 4-way + drain (or 5-way if you remove the drain) Inline Koolance Valve like that:
    http://www.frozencpu.com/...Fitting_VLV-XTSPL.html
    using 2 ports for water temps sensors, one goes to motherboard (so I can see it in software) and other goes to LED Display in case so I can see it whenever I look
    post edited by feniks - 2013/03/10 22:32:59
    ak420boarder
    Re:How do you drain your water cooling loop? 2013/03/10 22:33:21 (permalink)
    There is always something a little more shiny! :)
    ak420boarder
    Re:How do you drain your water cooling loop? 2013/03/10 22:44:22 (permalink)
    Very interesting. Do you happen to also have a link for the temp sensors you are referring to?
    • Ribbons : 282
    Re:How do you drain your water cooling loop? 2013/03/11 05:58:26 (permalink)
    flasher4q
    Same here and with Koolance.
    Bill
    Also for the Drain Valve from Koolance is only $12.99
    I order from Koolance's site for all Koolance`s products.
    post edited by bcavnaugh - 2013/03/11 06:03:03
    feniks
    • Ribbons : 38
    Re:How do you drain your water cooling loop? 2013/03/11 07:33:05 (permalink)
    ak420boarder
    something like those:
    http://www.sidewindercomp..s.com/big1tesestfi.html
    and here's a few kits with LED display from Phobya (seems they use BP and XSPC parts):
    http://www.performance-pc...dto=&x=21&y=13
    Afterburner
    • Ribbons : 110
    Re:How do you drain your water cooling loop? 2013/03/11 08:09:21 (permalink)
    Using the 800D I have a single loop cooling the two 680's, the Vreg's and the CPU OC'd to 4.0... I drain this loop on the cheap... Everything is routing to the back for a very clean loop on the visual side...
    Here is what it looked like on the other side when it was running a pair of 570's...
    jrees
    Re:How do you drain your water cooling loop? 2013/03/22 15:14:08 (permalink)
    I just connect extra QDCs to a piece of hose, and connect that to the loop and do it that way. Very simple, and more importantly, very easy.
    OV3RCLK4
    • Ribbons : 21
    Re:How do you drain your water cooling loop? 2013/03/22 16:21:42 (permalink)
    Very carefully
    MSI Unify X
    i9 12900k @ 5.2ghz
    2x16GB GSkill DDR5 6400mhz
    EVGA 3080ti FTW3 Ultra Gaming
    Seasonic 850w Titanium Power Supply
    Radiator: MO-RA3
    Water Blocks: EK Supreme HF Full Copper and EK Quantum Vector FTW3
    Pump/Res: XSPC Dual Bay Reservoir w/ MCP-655 Pump
    #23
    bluvert89
    Re:How do you drain your water cooling loop? 2013/03/23 08:39:56 (permalink)
    Put it on its backside and let it drain..
    #24
    TECH_DaveB
    • Ribbons : 46
    Re:How do you drain your water cooling loop? 2013/03/24 09:09:19 (permalink)
    Personally, I always use a T of some sort at the lowest possible point of the loop, and a threaded plug in the end.  I also not have the shut off valve for it as well from BitsPower.  From the shutoff is a couple feet of tubing and the plug, so I open the side panel, hand the line out of the case into a container, remove the plug, and open the valve, let gravity do the rest.  Once it's drained, close the valve, then replug it and tuck the hose back inside.  No spills, messes or surprises.  If you don't have room for the extra tubing, with the valve like that, you can keep it separate on a barb and just thread it into the valve as needed, works just as well.
    #25
    TheSME
    Re:How do you drain your water cooling loop? 2013/03/28 04:33:46 (permalink)
    I use koolance quick disconnects, just disconnect each part separately and drain that way.
    ___________________________________________________________________________________
    i7 2700k
    ASUS Maximus Extreme z68
    2 x GTX Titan Hydro Copper
    Enermax Platimax 1500w
    OCZ revodrive 3 240gb
    Corsair Dominator 8gb
    Mountain Mods Accension Case
    4xD5 pumps
    3x360 Black Ice sr1 radiators
    2xEK dual pump Blocks
    1xEk supreme cpu block
    2x Frozen Q res
    1x Aquacomputer 5 xl control unit with 4xPA2 controllers
    #26
