Re: How do I make a macro for right click for Diablo 3 ? NEW TORQ X10 I won
2014/06/17 11:27:52
OK, I was just trying to create what you were looking for.
Now, within the software you can NOT make it run the same click indefinitely. Also, the software will not interrupt a macro, as even with preset timing forced into the function you cannot stop it, so with the software as it is, if you had a permanent repeat function it would work in windows AND your game.
Now, if you are trying this for Diablo3, are you doing this as a forced work-around for things like the broken mana scaling for button mashing spells like Zombie Bears, or another spell/skill with similar issue which is bound to right click?
If so, this would be my solution.
I would select button 3 rather than 2 so your right mouse buttons works as usual still, this will NOT effect the scroll function of the wheel, only using its button press function.
Go to the Macro screen. You can make rigid times using the Interval check box, then assigning a value of milliseconds, however it will make ALL values the same, so if you right click for the macro 5 times at 1000 milliseconds, it will make a macro that will right click and hold for 1000ms, release for 1000ms, right click for 1000ms etc. As I do not have Diablo3 installed here at the office, I cannot test how the right click and hold function will work in game, but that will work.
The easier way, might not be as precise would be to bypass the interval box, click the record button, then right click and wait your desired time frame and right click again. You can do around 10-15 times in a 30 second window, so you can get 30 seconds of a function form one mouse click.
Once this is done, save the macro, go back to the Button Settings Tab and reselect the macro so it will reinitialize and you should be good to go.
Again, I recommend assigning this to button 3 so you do not have to change mouse settings every time you enter/leave Diablo 3 to avoid right-click-spam at desktop and non Diablo apps.
If you need pics, I can get them for you as well, any further questions, please ask, and as I am subbing this thread.
