Nakur34
I bought a week ago the EVGA GeForce RTX 3080 XC3 from the store. It runs very well. But now today it is causing the temperature to increase over to 100 plus and overheatedKindly tell me what will the issue is with it.
bdary
- Ribbons : 118
Re: How do I fix hot GPU temp? EVGA GeForce RTX 3080 XC3
Thursday, June 23, 2022 5:10 PM
As mentioned above, you'll need to provide a lot more info about your setup. What case make and model. How many case fans (intake & exhaust). Are you running PX1 or MSI AB and using a custom fan curve? What are you doing/running when you get these high temps? Have you visually verified the GPU fans are turning on?
post edited by bdary - Thursday, June 23, 2022 5:21 PM
wmmills
- Ribbons : 40
Thursday, June 23, 2022 6:24 PM
On top of those excellent questions, what are your local temps where you live, if its hot out are you in a/c and if so whats the temps inside like? How many monitors are you using and at what resolution? Are you using geforce experience and did you setup the nvidia control center at all?
MOBO: EVGA x299 Dark, CPU: I9 10900X, RAM: Patriot Viper RGB 3600 32gb, SSD: Samsung 860 EVO 1TB, M2: Samsung 970 EVO+ 1TB, PSU: CoolerMaster M2 1500, CPU HSF: EVGA 240 CLC HSF~ P/P EK Furious Vardar, G-CARD:EVGA RTX3090 FTW3 Ultra Gaming w/Hybrid kit and Noctua IPPC 3000 P/P, CASE: LIAN-LI PC-V2010B w/ Window mod, OS: Windows 10 Pro 64bit, MON: Alienware AW3821DW  New EVGA product? Register it NOW with this link: http://www.evga.com/register/default.asp?affiliatecode=4QFQRAMOII Help Our Vets From K-2! [link=https://strongholdfreedom
- Ribbons : 115
Friday, June 24, 2022 8:29 AM
Moved to the 30 Series section.
getalife
Friday, June 24, 2022 4:00 PM
First thing to point out, since you talking about over 100 degrees you prolly talking about your Micron RAM, and that's it more likely to happen if you keep the cooling curve on default. The GPU is way cooler than ram and tend to let the card without appropriate fan speed for the VRAM. Install Precision X1 and do the test by putting your fan speed at 85% and look your temperature... if this fix your problem... adjust the fan curve control and put back to auto. That will do the job!
Simply enthousiasmic about computer since 1992
RogueMaster
Friday, June 24, 2022 10:32 PM
What are you doing when the temperature goes that high? Are you playing games, doing renders, mining perhaps?
If you're mining, temps will get fairly high on the RAM. You may need to readjust your settings to limit the temps, as well as make adjustments to airflow, fan speeds, etc...
- Ribbons : 135
Friday, June 24, 2022 10:52 PM
RogueMaster What are you doing when the temperature goes that high? Are you playing games, doing renders, mining perhaps?
The only advice I give to those asking for help with their mining rigs is... well I guess I can't say that here. That said, I always wondered why so many folks ask for help with a complicated system like a PC... then basically leave out just about everything needed to be helpful to help them.
