Help!! I need help identifying a transistor Q76 on X58 SLI FTW3 Tylersburg
alphamoosi
2024/12/18 08:58:35 (permalink)
Hello ,
I was installing a new cooler and graphics card on my X58 SLI FTW3 motherboard and I must have mis-wired something and popped my motherboard. Not sure of the extent of the damage but I found Q76 a surface mount "transistor" smoked (maybe Sot-23 package). I was able to read the codes on the part as AL3 then I am not sure, it might have been a P after the 3, also I saw an label H1 at right angles to the AL3 - Can anyone help me identify the part so I can replace it to try to troubleshoot the rest of the board? I think my version of the motherboard was called Tyleburg or Tylersburg ? not certain. The part is located back side near the JSMB connector about an inch from inward from the edge.  Thank YOU!
0 Replies Related Threads
