Help! 2 Red LED on Brand New EVGA GeForce RTX 2080 TI FTW3 ULTRA HYBRID GAMING
angelenos
Wednesday, June 19, 2019 3:35 AM (permalink)
Hi Folks,
Just put up my first PC and tried to power it on. Everything including CPU, Motherboard, RAM, PSU, HDD/SSD works fine but the graphic cards did not work. It had 2 red LED above the power cable and both fans (on the card and with the radiator) did not work. I did have the light on the "EVGA Hybrid" logo on but the motherboard failed to recognize the graphic card. Tried different PCIe slots and different PCIe cables (yes I did use 2 separate cables to power the graphic card) but didn't work. Below is the details about my PC and any helps are welcomed (including what is the meaning of 2 red LED). Thank you guys so much.
CPU: Intel I9 9900K
Motherboard: ASUS ROG Maximus XI Extreme Z390
PSU: Corsair HX850i (850 Watts)
GPU: EVGA GeForce RTX 2080 TI FTW3 ULTRA HYBRID GAMING
6 Replies Related Threads
    • Ribbons : 282
    Re: Help! 2 Red LED on Brand New EVGA GeForce RTX 2080 TI FTW3 ULTRA HYBRID GAMING Wednesday, June 19, 2019 3:55 AM (permalink)
    Welcome to the Forum
    Maybe to small of a PSU for your GPU/CPU/MB
    Do you have a Non-Corsair Power Supply to test with?
    Test with the Two Yellow Blocked as shown below.
    post edited by bcavnaugh - Wednesday, June 19, 2019 4:01 AM
    angelenos
    Re: Help! 2 Red LED on Brand New EVGA GeForce RTX 2080 TI FTW3 ULTRA HYBRID GAMING Wednesday, June 19, 2019 4:48 AM (permalink)
    Thank you for your reply. Unfortunately I only have this one on hand as it is my first PC
    I did try different combinations but didn't test this one. Is there any difference between those 8-pins ports from PSU? I thought there are identical. Anyway I will try this one and post updates
    angelenos
    Re: Help! 2 Red LED on Brand New EVGA GeForce RTX 2080 TI FTW3 ULTRA HYBRID GAMING Wednesday, June 19, 2019 3:36 PM (permalink)
    Thank you for your reply. Unfortunately that is the only PSU I have as it is my first PC.
    I tried the 2 ports you mentioned but still failed to make the graphic card work. 2 Red LED above power cable when power on the PC.
    • Ribbons : 282
    Re: Help! 2 Red LED on Brand New EVGA GeForce RTX 2080 TI FTW3 ULTRA HYBRID GAMING Wednesday, June 19, 2019 4:58 PM (permalink)
    Re-Check that the Card is Locked into the PCIe Slot.
    I would test your card in another computer before thinking of an RMA.
    Others have had the same issue on that Motherboard.
    sooperrm4n
    Re: Help! 2 Red LED on Brand New EVGA GeForce RTX 2080 TI FTW3 ULTRA HYBRID GAMING Wednesday, May 13, 2020 1:51 PM (permalink)
    Did you ever figure out what was causing this issue?
    philhalo66
    Re: Help! 2 Red LED on Brand New EVGA GeForce RTX 2080 TI FTW3 ULTRA HYBRID GAMING Thursday, May 14, 2020 1:09 AM (permalink)
    sooperrm4n
    If it's anything like the old 9800GX2 it means its not detecting the PCI-E cables or the power is too low.
    POWDERED DONUTS MAKE ME GO NUTS!
