StarQ1
Wednesday, August 25, 2010 4:33 AM
If I only have a 350 Watt power supply, will the graphic card born out or will it wont work right?
liquid_xiron
Re:GeForce 9800 GT 1GB Minimum of a 400 Watt power supply
Wednesday, August 25, 2010 5:40 AM
Depends on the 12v rail amps and the quality of the psu. I ran my q9550 @ stock speed 2.83 wih 4gb ddr3 1800mhz @ 1.9v 5 hard drives, 4 120mm fans, DVD burner and one of my gtx 285. That was using a thermaltake tr2 430w and that psu is not even real 430w, according to a review of that psu it is around 380w. Yup, you can call me crazy but I was desperate. In any case, verify if the amps on the 12v rail of your power supply is the recommend for the card. For a 9800gt I will say a max combine of 26A will do it. BYW, the card will not burn, however you may experience BSDO's or your computer going frenzy However to be on the safe side and I will recommend you buy a new PSU 39.98 + 1.99 shipping 530 Raidmax http://www.newegg.com/Pro...x?Item=N82E16817152028 or if you can afford this go for it 59.99 + 9.65 Shipping 520w Seasonic http://www.newegg.com/Pro...x?Item=N82E16817151094
Ryzen 3600 - Mobo MSI B550 MAG - Ram 32GB - PSU Super Flower Leadex III 850W - VGA GTX 1070 FTW - CPU Cooler Noctua NH-12UP SE - Case Phanteks P600S My Heatware
StarQ1
Wednesday, August 25, 2010 6:14 AM
Opps I have a 375 Watt power supply
superacg
Wednesday, August 25, 2010 8:03 AM
Dude...get a new PSU. You shouldn't even be running anything lower than 500W. My current rig is 5 years old, and I installed a 500W PSU last year. I have 5 HDDs though...
Current Rig Built in 2005-06...present Gigabyte Socket 939 GeForce 6100 AMD 4000+ San Diego Core 3GB OCZ DDR Dual Channel EVGA 7600 GT 80GB Maxtor (Boot Drive) 150 GB Raptor X (Photo Storage) 200 GB Samsung (Photo Storage) 500 GB WD (Video Storage) 1 TB WD Caviar (Photo/Video archive) 500W PSU Crammed into original Aspire X-QPack
StarQ1
Wednesday, August 25, 2010 9:49 PM
call me noob, but how do i go by unpluging the cpu and motherboard & everything on it? I bought my pc from dell... i have another question, I already have a 9800gt 512Gb and it plays everything ok, but if I move to the 1GB, will I see a big improvement in the FPS in my games or just small improvements?
post edited by StarQ1 - Wednesday, August 25, 2010 9:58 PM
happaflapp
Wednesday, August 25, 2010 10:22 PM
Unplugging your CPU, motherboard, and everything on it? By that do you mean removing the hardware? Or, are we talking about removing the plugs from the motherboard? Or both? Going from a 512 mb 9800gt to 1gb 9800gt you will only see a minimal improvement in fps. Nothing earth shattering. If you want that, try moving up to the 4 series cards.
i7 920@ 3770 GHz w/HT & turbo*EVGA X58 X3 (E758-A1)*2x EVGA GTX 670 FTW *Corsair Dominator DDR3 1600 18gb (7-7-7-20 @ 1380 MHz \ 2T)*Corsair H50*Corsair HX850W*Corsair Force Series 60Gb +OS drive+SATA II (SSD)* Corsair Neutron series 120Gb SATA III (SSD)*XF-i Fatal1ty Pro Series*Western Digital Caviar Black 1Tb & 500 Gb*Cooler Master Stacker 830se*Logitech G19 *Logitech G9x*fUnc Archetype1030MBA*Logitech X-540 5.1*Acer G245HQABD*Windows 10x64 AMD Phenom II X4 BE 970@ 3500 MHz*Corsair H50*Asus M4N82 Deluxe*Corsair XMS2 800 8Gb DDR2(5-5-5-18 @ 800 MHz \1T)* 2x GTX470 Superclocked * XF-i Xtreme Music* Corsair Force Series 60 Gb +OS drive+ (SATA II)Western Digital Caviar Blue 1Tb & 500 Gb*Corsair 750TX*Cooler Master CM Storm*Logitech G15v2*Logitech G500*Logitech X-530 5.1*fUnc 1030 sUrface*Acer X233H bd*Windows 10x64 [/c
StarQ1
Thursday, August 26, 2010 4:06 AM
cri158
Thursday, August 26, 2010 4:20 AM
If you say 'pls' or 'plz', because its shorter than 'please', I'll so 'No' because it's shorter than 'Yes'.
happaflapp
Thursday, August 26, 2010 9:40 PM
I would need more info about your rig before I suggest any hardware upgrades. Post specs... Take input/advice... Do your own research... Then decide on a product... Purchase!
StarQ1
Friday, August 27, 2010 1:09 AM
2 CPU 2.13 Intel 4.0GB Ram 9800gt 512mb 256bit power supply 375 watts
liquid_xiron
Friday, August 27, 2010 4:13 AM
You need a new CPU, definitely. Either a E8400 if your mobo support LGA775 or a good quad such as q9550. If not you are going to have a huge bottleneck because of that 2.13ghz If you would like to oc one of those processors, you will need then at least a good 520+ psu to be on the safe side.
StarQ1
Friday, August 27, 2010 5:59 AM
I would like to put a new CPU in my motherboard, but my pc is a dell x410 and I dont know if a E8400 would be compatible with my motherboard...
liquid_xiron
Friday, August 27, 2010 2:54 PM
Please download and use CPU-Z and tell me what kind of motherboard you have. It will give you all info, I will need the processor type. If you can you can attach a screenshot.
StarQ1
Friday, August 27, 2010 6:43 PM
Manufactuer: Dell Inc Model: 0wg855 chipset: Intel P965/G965/ Rev: C2 Southbridge: Intel 82801HH (ICH8DH) LPCIO: SMSC
liquid_xiron
Friday, August 27, 2010 8:12 PM
If the one you have is an Intel XPS 410 with 0WG855 mobo It's a LGA 775 motherboard. It seems it does not support the E8400. But some people reported that q6700 does work with that board, however that cpu is expensive. Try to find the cheapest price online, I'll recommend to get a used one from ebay.
StarQ1
Friday, August 27, 2010 8:18 PM
liquid_xiron
Friday, August 27, 2010 9:54 PM
Also, I was thinking if you can sell your computer and tell me your budget and see if you change your pc insted of upgrading this one. Some people said that motherboard cannot be use to OC the CPU. Anyways just my idea.
StarQ1
Saturday, August 28, 2010 2:49 AM
Is there a program to see if your graphic card is over heating and how much power its useing?
happaflapp
Saturday, August 28, 2010 3:36 AM
You can download and use EVGA Precision for temps. Software voltage monitoring software tends to be a shot in the dark since most software relies on your motherboard for those readings. And, it seems that only good motherboards are capable of that. Dell, has a tendency to cram junk in their computers. This means that their motherboards aren't what most would consider to be a good motherboard. So, chances are that the reading you would get could be erroneous.
StarQ1
Saturday, August 28, 2010 4:41 AM
says it my graphics card doesn't support it, my 9800gt isn't from EVGA... but the new card am about to buy soon, will be...
liquid_xiron
Saturday, August 28, 2010 5:31 AM
StarQ1
Saturday, August 28, 2010 6:12 AM
StarQ1
Friday, January 07, 2011 7:45 PM
okay heres a update :I bought a 750 watt power supply and now I have 460 GTX Hawk!  .. and I will buying a new pc, very very soon.... I mean very soon lol
geek32
- Ribbons : 9
Friday, January 07, 2011 7:56 PM
^ grats that you finally upgrade all components to newer one's and if you're interested on selling off your old hardwares there's a marketplace thread on our forum so feel free to visit.
RBIEZE
- Ribbons : 12
Friday, January 07, 2011 8:08 PM
You'll need at least 50 posts to use the market place, so start spamming the forums...lol let us know your budget and well help you choose the best bang for buck parts, and even more importantly , help you avoid bad hardware / brand choices !
They say opposites attract. I hope you meet someone who is good-looking, intelligent, and cultured. http://www.youtube.com/watch?v=W2WsPN-rr9o Evga X58 4Way sli,W'Cooled i7 950 @3.8, Mushkin redline mem @6-7-6-18 1600Mhz, 2-Evga GTX770 Sli, Evga Gtx460 Physx, Corsair Neutron 120GB SSD,Samsung 240SSD, W.D Black 640GB /Corsair TX950 Psu, Hanns-G 28" Lcd, Logitech G540 5.1 Surround My Affiliate Code: EECLVEDV7Z
StarQ1
Friday, January 07, 2011 8:48 PM
aww thanks for the support guys... maybe I will do that?
