tornel
Received my 1gb sc EE version of the gtx 460 today and finally put it in an fired it up. My very first thought was how noisy the fan sounds, even while just browsing the net. I've been using a gtx 275 that I borrowed from a friend while he was out of town that has the exact same turbine type of fan on it (looks to be the same size too) and it's nowhere near as loud. It sounds like either a bearing is out, or the thing is just out of balance somehow, but it makes a very loud and noticeable vibration noise(and if I turn up the speed even to just 50% with the precision tool its unbearable). I know turbine type fans are louder, but this thing is so much louder than the 275 I can't believe their isn't something wrong with the fan. Any input on this is greatly appreciated. Thanks! Tornel
spyderrico
Re:GTX 460 fan noise question
Saturday, July 24, 2010 5:38 AM
tornel Received my 1gb sc EE version of the gtx 460 today and finally put it in an fired it up. My very first thought was how noisy the fan sounds, even while just browsing the net. I've been using a gtx 275 that I borrowed from a friend while he was out of town that has the exact same turbine type of fan on it (looks to be the same size too) and it's nowhere near as loud. It sounds like either a bearing is out, or the thing is just out of balance somehow, but it makes a very loud and noticeable vibration noise(and if I turn up the speed even to just 50% with the precision tool its unbearable). I know turbine type fans are louder, but this thing is so much louder than the 275 I can't believe their isn't something wrong with the fan. Any input on this is greatly appreciated. Thanks! Tornel Thats a tough question to answer without listening to it. Generally the 4xx series cards do not make (IMO) that much of a noticable difference in sound when compared to the 2xx series. I had a 280 SSC for years and usually had the fan on 100%, when compared to my 480SC at 100%, not a whole lot of difference. With that being said, if it is not a constant humm (albeit loud) then I would start troubleshooting the issue with making sure the card is properly seated. Next make sure its not something else in the case making the noise ie. wires rubbing against or other loose components too close. From your description of the issue I am led to believe that you are aware of the proper noise a GPU should make, it is possible that you may have a defective card in terms of proper fan installment. Your two options would be RMA the card for a new and compare, or try to fix the fan in the GPU, the latter which I am not educated enough to help with. Hope you find a quick resolve! Q9550@3.6 GTX 480SC 1625/2000 4GB DDR3 1600 Patriot Viper Antec 1000psu Antec 1200 case HANNS G 28' 1920x1200 ALL ON AIR
a0krn
Saturday, July 24, 2010 5:51 AM
yeah can anyone post a video of the sound? id like to hear it as well.
tornel
Saturday, July 24, 2010 5:56 AM
Just comparing it to the 275(and even my older 9800gx2) it seems way too loud (especially while not under load). If it was loud just while gaming I wouldn't mind as much,but the loud hum/vibration while checking email etc is very annoying. From your input I'll probably get the RMA process going unless someone with this card can comment on their noise levels. Thanks again!
spyderrico
Saturday, July 24, 2010 6:06 AM
tornel Just comparing it to the 275(and even my older 9800gx2) it seems way too loud (especially while not under load). If it was loud just while gaming I wouldn't mind as much,but the loud hum/vibration while checking email etc is very annoying. From your input I'll probably get the RMA process going unless someone with this card can comment on their noise levels. Thanks again! Just from the way you are describing it, even comparing to the 275, it sounds like (no pun intended) you could have a card that did not have proper fan installment for whatever reason. Now that being said, be sure to fully inspect the card's fan area, reseat the card to the mobo and make sure there are no other components touching that could be the culprit. If nothing else, RMA, when you get your new card you will have your answer on whether this is normal or not.
tornel
Saturday, July 24, 2010 6:30 AM
I took a video with my crappy camera and you can hear somewhat what I'm talking about. If you still don't hear what I'm hearing, I'll take my mic and make a recording(it's late and the camera was easier :P). As you can see no wires are hitting on the fan, and I also reseated the card to make sure that wasn't the issue and the sound remains. For anyone interested in buying this card, I'm pretty sure the fan is messed up and this is NOT the typical noise of this card so don't judge it based on this video. Here is a link if you want to give it a listen. LINK Thanks!
post edited by tornel - Saturday, July 24, 2010 6:39 AM
spyderrico
Saturday, July 24, 2010 7:01 AM
RMA for sure, definitely not normal. Your suspicions were right on. Great audio by the way, LOL, past 50% definitely annoying.
tornel
Saturday, July 24, 2010 7:30 AM
Alright lol glad to hear it wasn't just my imagination. I'll get the process started, thanks again for the help!
spyderrico
Saturday, July 24, 2010 7:33 AM
Bowenac
- Ribbons : 17
Saturday, July 24, 2010 7:54 AM
Weird I am folding right now with fans on auto and there @ 57%, and 51% and I can barely hear them. Maybe I got some quite ones. Mine sound nothing like what yours do in the video.
TArtel
Saturday, July 24, 2010 12:21 AM
Mine are unbearable!! They sound exactly as you describe! I guess maybe I also got some bas fans? I have 2 in sli and it sounds like someone is doing lawn work in my computer room. I'm going to call support today to see if this is normal
dccmadams
Saturday, July 24, 2010 3:49 PM
Which fan, EE or ref are you people using? Is anyone having a noise problem with the ref fan?Or is it only evga EE fan?
i7 2600K @ 4.6Ghz, Asus P8P67 v3.1, 16gb G.Skill Crucial M500 960 SSD, 1TB WD Black, ASUS GTX 980 STRIX, Corsair HX750 i7 860 @ 3.2Ghz, GA-P55A-UD3, 8gb Corsair XMS3 Crucial M550 1Tb SSD, ASUS GTX 970 STRIX, Corsair TX650 i5 750, MSI P55 GD65, 8gb G.Skill WD 750 Black, ASUS GTX 970 STRIX, Corsair VX550
007vsMagua
Saturday, July 24, 2010 4:25 PM
That fan sounds out of balance and possibly touching something...bad.
"Life is like stepping onto a boat which is about to sail out to Sea and sink." _Shunryu Suzuki Roshi EVGA __ RTX 3070 FTW Super --- INTEL __ i7-7700K MSI __ Z270 Gaming M7 --- GSKILL __ 16GB TridentZ 3200NZXT __ Kraken X62 / HUE+ / GRID+ v2 / AER Fans x2 / USB HubSAMSUNG __ 850 EVO 500GB --- WD __ 1TB Black / 1TB Blue EVGA __ 850 G3 --- NZXT __ S340 Elite (White) - [/siz
a0krn
Saturday, July 24, 2010 4:29 PM
They are talking about the EE version. We all know the reference one is much quieter and cooler. If your EE version is quiet Could you post a video? All we hear is that its very loud or noisy. It be nice if we could hear the quiet ones to relief some ears. Otherwise IMO the evga EE model is designed to be a alot noisier than the reference design. Many people having gotten the evga ee model and saying its loud proves that its not a bad card but a bad fan implementation
a0krn
Saturday, July 24, 2010 4:31 PM
And also it seems that it might be just only The superclocked EE version. correct me. someone. ANYone :p
TArtel
Saturday, July 24, 2010 5:14 PM
a0krn And also it seems that it might be just only The superclocked EE version. correct me. someone. ANYone :p I just have the basic EE version... still have the problem. These must be defective I just can't imagine anyone shipping cards with this kind of noise. It's one thing to get a little loud at load but being loud at idle is unacceptable!
a0krn
Saturday, July 24, 2010 5:20 PM
I agree with you there. As long as idle is quiet. Did evga respond to this? Did they say it was quiet? I feel like we need someone inside evga to just tell us its not. So we know what were dealing with.
tornel
Saturday, July 24, 2010 6:12 PM
I contacted evga tech support and they recommend I rma it. I'll repost when I get my new card and let you know if it has the same issue or not.
TArtel
Saturday, July 24, 2010 6:24 PM
tornel I contacted evga tech support and they recommend I rma it. I'll repost when I get my new card and let you know if it has the same issue or not. I feel like I'll be waiting weeks for an rma :( I'll call them today myself.
mach35
Saturday, July 24, 2010 7:23 PM
I just got a evga gtx 460 1024mb EE card & am very disappointed by the fan noise. I previously had a GTX 280 with the same type of fan design but it doesn't sound half as loud esp. once you get over 50% on the fan but even at idle it's louder . I'm thinking of taking mine back & waiting for a different brands/models to show up as it seems like the EE version's of this card is a joke. Also I tried to run Dirt2 but I get a crash right after starting it any ideas ? I have tried checking the game cache & setting it to run in admin mode but it ran great with my GTX 280. Am downloading a new copy now to see if that fixes it. I used to really like EVGA stuff but this EE card sounds like a bad design choice. Any comments from EVGA staff ?
hoonsama
Saturday, July 24, 2010 9:25 PM
I'm interested in the topic of noisiness for GTX 460's, as well. I'll wait around to see if you guys' RMA'd cards still exhibit loudness before making my decision on which model to get.
kryus7
Saturday, July 24, 2010 9:42 PM
Glad I saw this post cause the fan really is way to loud on this card.... Would I be able to send it back for a refund because its so damn loud past 50% I had thought the EE design looked really cool but at the cost of crazy loud sound I wouldn't have bought it.
Legit_Xero
Saturday, July 24, 2010 10:03 PM
I purchased two of the 1gb EE models (non-SC) from newegg and got them installed yesterday. Mine are not nearly as loud as yours in that video. I can't even hear mine when I am gaming.
a0krn
Monday, July 26, 2010 2:00 AM
Legit_Xero I purchased two of the 1gb EE models (non-SC) from newegg and got them installed yesterday. Mine are not nearly as loud as yours in that video. I can't even hear mine when I am gaming. So at idle its still loud correct? And in gaming is a big different on what kind of headphones u use or how loud your speaker is. Hmm. Just asking. Is it loud at idle?
tornel
Monday, July 26, 2010 2:24 AM
Mine is definitely loud at idle. If it was just loud while gaming, I wouldn't mind as much.
Legit_Xero
Monday, July 26, 2010 3:46 AM
a0krn So at idle its still loud correct? And in gaming is a big different on what kind of headphones u use or how loud your speaker is. Hmm. Just asking. Is it loud at idle? I don't consider them to be loud at idle. They are audible, but not to the point where it is irritating. Just the usual fan noise that comes from a computer case with all the fans running. I use a 5.1 speaker system, even if I turn them off while gaming they aren't loud enough to be bothersome. Before I got these I had 9800GT's and they were louder at idle than my 460's. However if I manually crank the fan up to say, 70%, they become VERY loud. The fan never comes close to getting that high when gaming though.
tornel
Friday, August 06, 2010 3:33 AM
Well I received my rma'd card back yesterday and it is definitely quieter than the one I sent back. It doesn't have that vibrating noise the other one had that made it sound like a lawnmower. It's still louder than the older 275 but I can live with it since the vibration is gone. If anyone knows of an aftermarket cooler that would work that is fairly quiet, I don't really care about the external exhaust (my case has very good ventilation) I would probably throw it on there to make it quieter. I'm not really sure what size cooler is needed, as this card is smaller than the other 400 series cards.
a0krn
Friday, August 06, 2010 9:03 AM
tornel Well I received my rma'd card back yesterday and it is definitely quieter than the one I sent back. It doesn't have that vibrating noise the other one had that made it sound like a lawnmower. It's still louder than the older 275 but I can live with it since the vibration is gone. If anyone knows of an aftermarket cooler that would work that is fairly quiet, I don't really care about the external exhaust (my case has very good ventilation) I would probably throw it on there to make it quieter. I'm not really sure what size cooler is needed, as this card is smaller than the other 400 series cards. Could you post another video for us again? Id love to hear a comparison with your old card and the new one.
tornel
Saturday, August 07, 2010 8:08 PM
Here is a video of my new card and it's noise level. Overall I am happier with this card over the other one because this one doesn't get that loud until 60%+ whereas the older one was loud at idle (imo). It does still have some vibration, but not nearly as bad. VIDEO If anyone knows of an aftermarket cooler(maybe one similar to the non EE versions) that would fit I'd appreciate it.
post edited by tornel - Saturday, August 07, 2010 9:35 PM
janko10
Saturday, August 07, 2010 8:16 PM
tornel Here is a video of my new card and it's noise level. Overall I am happier with this card over the other one because this one doesn't get that loud until 60%+ whereas the older one was loud at idle (imo). LINK: VIDEO If anyone knows of an aftermarket cooler(maybe one similar to the non ee versions) that would fit I'd appreciate it. Tornel your link's not working. Please fix when you get a chance, I'd like to see if it's worth returning mine. Seems like it's luck of the draw right now though.
