Re: GPU-Z Power Draw/Memory Clock Spikes Normal or Not?
2021/09/02 18:55:42
☄ Helpfulby Vash_THT 2021/09/02 21:17:38
No problemo! Another thing to check if you are using GeForce Experience and aren't capturing your desktop is to disable "Desktop capture" as this can also cause higher GPU utilization at idle.
Note: If you have Instant Replay On you have to turn it off temporarily so you can disable the other setting.
1.) Press ALT+ Z (if you see Instant Replay On turn it off quick)
2.) Click cog/gear on the right
3.) Scroll down to Privacy Control
4.) Turn off Desktop capture
5.) If you turned off Instant Replay in step 1 and want it back on you can turn it back on now.
Enjoy!
GPU: EVGA GeForce RTX 3080 Ti FTW3 ULTRA HYBRID
