GALAX GeForce RTX 4060 Ti Max 16 GB Unparalleled Max is the First Single-Slot RTX 40
  • Ribbons : 86
2023/12/06 00:06:32 (permalink)
https://www.techpowerup.com/316422/galax-geforce-rtx-4060-ti-max-16-gb-unparalleled-max-is-the-first-single-slot-rtx-40-series-gpu
NVIDIA's GeForce RTX 40 series lineup of graphics cards has been supporting massive cooler designs ranging from three to four slots in thickness, with gamers rarely even getting a standard two-slot solution available. However, GALAX recently announced a novel entry into this lineup: the RTX 4060 Ti Max 16 GB Unparalleled Max, a GPU noted for its unprecedented single-slot design and exceptionally thin 20 mm profile. This model, previously previewed on GALAX's China website, stands out with its unique vapor chamber cooling system paired with a copper heatsink, diverging from the typical multi-fan setups seen in the market. Measuring at 267x111x20 mm, the design is very friendly towards smaller cases with room for only a single slot cooler.
The RTX 4060 Ti Max is set to operate at a default clock speed of 2535 MHz, with a power target of 165 Watts, suggesting a solid performance base for all GPU-intensive sessions. Currently, GALAX has yet to indicate the availability of an 8 GB version or the inclusion of a non-Ti model with this cooler, as only a 16 GB version has been shown. Interestingly, GALAX has made overclocking the card possible; however, the voltage regulation module setup is 6+2 VRMs placed on a six-layer PCB, not providing an ideal overclocking setup. Additionally, while feasible, overclocking the GPU with such a tiny single-slot cooler should be approached cautiously.
I wonder how noisy the blower fan is as well as the load temps.
1 Reply Related Threads
    revenantx02
    EGC Admin
    • Ribbons : 8
    Re: GALAX GeForce RTX 4060 Ti Max 16 GB Unparalleled Max is the First Single-Slot RTX 40 2023/12/06 15:37:45 (permalink)
    Now I want one for my NAS/plex server
