AzN-SoLjA
- Ribbons : 14
Let me know? Been looking around for some kind of fan controller to handle 14-20 fans. Thanks :)
| EVGA Z68 FTW | EVGA GTX 780 Ti SC 3GB | EVGA GTX 1080 Ti FTW3 | Custom EK Water Loop | Red Harbinger Cross Desk | i7 2600K @ 4.5GHz @ 1.24v | Corsair 16GB Vengeance | Corsair Neutron 256GB SSD | Corsair AX850 | Lamptron FC5V3 | ASUS VE278 27" | | Creative Inspire T6160 5.1 & X-Fi Fatal1ty 7.1 Champ | Razer Marauder & Spectre & Tiamat 7.1 | Affiliate Code: 3MHCIBME48 | Associate Code: 08HWLPJXE0O5MPM
Xantac
Re: Fan controller? Best route for 14-20 fans?
2014/03/03 08:51:14
Aquacomputer Aquaero 6 XT! I kid I kid. I just ordered a lamptron CW611, there is also the Lamptron FC5 V3 which I almost ordered instead. They a great products without the aquacomputer prices, one would cost 300 with the accessories. what's your budget
- Rig 1: Rampage5/w 6850K g.skill 3200 cas15 16gb, High-speed PC HPTX Bench w/ GTX 980
- Rig 2: RIVE/3930k /w Koolance mobo/cpu blocks/16gb 2133 c9, EVGA 1080 Ti Sli EK Nickel Blocks & a 78MH/s Eth
- Rig 3: asus rog crosshair vii hero (wi-fi)/2600x, g.skill 3200 cas15 16gb, gt 730
- Acer Predator Monitor
- Xantac's Heatware
TECH_DaveB
- Ribbons : 46
2014/03/03 12:06:52
I am using Lamptron FC5-v3's myself, love those controllers. 30 watts per channel times 6 channels, so 180 watts of can control. Pretty nice. Got some really high current fans on it, big, high SP fans for rads, no issues, excellent control, lots of colors for display, personally I'm using blue, but there are others as well. If you are using normal to low wattage fans you will be able to run far more than the 14-20 you are asking about.
AzN-SoLjA
- Ribbons : 14
2014/03/03 12:08:50
TECH_DaveB
- Ribbons : 46
2014/03/03 13:03:24
The controller I recommend will handle those fans and more. As for the loop, what case is this in, what budget are you likely to have, also, how cold are you looking at getting this, just cool and quiet, or enough overhead for brink OCs for competitive clocking on ambient temps? Also, how important is keeping the system quiet? The will dictate radiators and fans used.
Xantac
2014/03/03 19:35:39
EVGATech_DaveB I am using Lamptron FC5-v3's myself, love those controllers. 30 watts per channel times 6 channels, so 180 watts of can control. Pretty nice. Got some really high current fans on it, big, high SP fans for rads, no issues, excellent control, lots of colors for display, personally I'm using blue, but there are others as well. If you are using normal to low wattage fans you will be able to run far more than the 14-20 you are asking about.
Hi Dave do you know if there is a display fader on the FC5-v3? Its pretty much the reason I choose the cw611, I actually like the fc5-v3 a little better.
- Xantac's Heatware
AzN-SoLjA
- Ribbons : 14
2014/03/03 23:56:52
EVGATech_DaveB The controller I recommend will handle those fans and more. As for the loop, what case is this in, what budget are you likely to have, also, how cold are you looking at getting this, just cool and quiet, or enough overhead for brink OCs for competitive clocking on ambient temps? Also, how important is keeping the system quiet? The will dictate radiators and fans used.
The "case" is the desk show above. I want to make something nice, with a little help from EVGA members for the creativity with the possibilities that can be done. I've never done a water cooling loop before, but I want it done right. But as you can see below, is the reason for the fan controller. So thanks for all the info so far  This will be a over time progression to save up for all the parts needed.
- Ribbons : 271
2014/03/04 17:56:21
Why two computers at one desk?
AzN-SoLjA
- Ribbons : 14
2014/03/04 21:51:17
Why not?  Dedicated folder and server for my 10 HDD's for my network? To name a few. I don't run my main rig 24/7 but having this option to run a dedicated computer. But as I said before, I want it done right! :D I'll be making another thread later in the month once this has been delivered to inquire the parts and designing/layout of it.
the_Scarlet_one
formerly Scarlet-tech
- Ribbons : 79
2014/03/05 05:54:51
That's a desk... I wonder if it will fit in my dorm room... I have two Pc's right meow... Lol
TECH_DaveB
- Ribbons : 46
2014/03/05 08:51:24
Xantac
I do not recall a fader, however IMHO it is not terribly bright. Don't have a pic handy but I will see what I can get, won't be right away though, go a lot going on outside of work atm.
AzN-SoLjA
- Ribbons : 14
2014/03/09 21:46:50
So if I pull the trigger on the FC5v3, what else do I need for connecting all the fans to this unit? Alot of extensions lols? I never had a fan controller so I'm not sure what to expect. I plan to have at least 14 fans to start with.
Nexillus
2014/03/10 08:49:53
I want something like that O_o....
Intel Core I7 3930K @4.6GHz +.050 offset | 16GB DDr Ripjaw Z 2133 MHz Asus Sabertooth X79 | 2x Sapphire 290s 240GB Vertex 3 SSD x2 Raid 0 | 3TB Segate x2 Raid 1 Seasonic PLATINUM-1000 | Thermaletake Chaser MK-1 Razer Naga | Maxkeyboard Knighthawk X9 | Win 7 Pro Custom Watercooling: XSPC Raystorm | 2x XSPC 290 Full Waterblock Black Ice Stealth 360/240mm Rads | 5x GT AP-15 1850RPM Fans Swiftech Dual Bay Res w/MCP35X single pump
TECH_DaveB
- Ribbons : 46
2014/03/10 12:49:03
I have splitters by Phobya. So I control 3 fans per nob, wire them up you will see RPM and voltage used. Look at the total wattage of the fans, from there you can figure out how many you can run per node, and organize/cable from there.
AzN-SoLjA
- Ribbons : 14
2014/03/10 13:03:03
EVGATech_DaveB I have splitters by Phobya. So I control 3 fans per nob, wire them up you will see RPM and voltage used. Look at the total wattage of the fans, from there you can figure out how many you can run per node, and organize/cable from there.
Sweet, thanks for the info. Are those the Phobya Y splitters on FrozenCPU? edit: Can't seem to find the w usage on these fans http://www.cougar-world.com/us/products/fans/cfd_blue_led_fan.htmlTrying to figure out how many of these I can place on 1 port on the FC-5V3.
post edited by AzN-SoLjA - 2014/03/11 11:28:53
TECH_DaveB
- Ribbons : 46
2014/03/11 14:29:21
I was not finding it either. Usually the total power consumption is on the label, I ma not finding a good label view or info form Cougar. Unless someone else has some info on the actual fan specs, I would recommend calling Cougar. I would be surprised if it was less than 4 per channel, likely more.
AzN-SoLjA
- Ribbons : 14
2014/03/13 23:20:27
EVGATech_DaveB I was not finding it either. Usually the total power consumption is on the label, I ma not finding a good label view or info form Cougar. Unless someone else has some info on the actual fan specs, I would recommend calling Cougar. I would be surprised if it was less than 4 per channel, likely more.
I left em an email a couple days ago. No response. But yea as for the question before hand about the Phobya splitters. I was trying to find the ones that will work on the 2 pin Lamptron. The ones on frozen are all 3 pins? Only one I could find was on amazon http://www.amazon.com/Pho...ble-30cm/dp/B004X2X9AE is this the correct one to look for? I may need alot of extensions for the desk.
