Re: Evga 1080ti sc2 hybrid fan cable removal
2017/06/24 15:27:33
Much appreciated and helpful Quad5ny thanks, you are right though about the warranty and it would be silly to nip the cable off really for the resale value also. I just wanted a cleaner look but its not worth the agro tbh. I will still 100% change fans to PP and plug direct to motherboard header.
Thanks again.
