EVGA Precision X1 Not Saving Target Power and GPU Temp
dainel40
2020/09/14 17:15:14 (permalink)
Hello,
I have a Titan X Pascal with the latest drivers. All my overclock settings are saved with PX1, except when I restart my computer. The GPU Power and Temp just reset themselves and chains them up again. I have tried running the software in administrator rights and no luck. Everything saves, except Target portion. Please, help.
6 Replies Related Threads
    • Ribbons : 123
    Re: EVGA Precision X1 Not Saving Target Power and GPU Temp 2020/09/14 18:17:13 (permalink)
    Is it set to load last open profile on reboot ?
    there are a couple of items to check mark to make it work - launch on Reboot & Load previously saved Profile#
    You need to select - Both of these:
         1) "Start on with OS"
         2) "Apply previous settings on load"
         3)  Apply & Save
    WARNING:  when trying to Find your best OC, Do Not select the "apply previous settings on load" --> if its an unstable setting you do not want these to load and crash your Rig on restart ---- right
    dainel40
    Re: EVGA Precision X1 Not Saving Target Power and GPU Temp 2020/09/14 18:25:33 (permalink)
    I have tried that multiple times and no luck. It just resets them every time.
    dainel40
    Re: EVGA Precision X1 Not Saving Target Power and GPU Temp 2020/09/14 18:27:03 (permalink)
    No luck with this, still same issue. See my photos above.
        3)  Apply & Save
    bob16314
    • Ribbons : 761
    Re: EVGA Precision X1 Not Saving Target Power and GPU Temp 2020/09/14 18:56:29 (permalink)
    The Power/Temp Target has always been bugged in Precision X1..You should use Precision XOC or MSI Afterburner for your card instead and it should work fine.
    dainel40
    Re: EVGA Precision X1 Not Saving Target Power and GPU Temp 2020/09/14 19:13:41 (permalink)
    bob16314
    The Power/Temp Target has always been bugged in Precision X1..You should use or for your card instead and it should work fine.
    Damn! but Precision XOC hasn't been updated in over two years! And I'm not a fan of MSI :(
    bob16314
    • Ribbons : 761
    Re: EVGA Precision X1 Not Saving Target Power and GPU Temp 2020/09/14 19:31:09 (permalink)
    Right, but consider that a TITAN X Pascal was first released in 2016 and that Precision X1 was first released in 2018 and built with 10-series and newer cards in mind..Precision X1 should work for the most part with your card, I use it with my GTX 760 SC, but some features won't be available and it's kinda buggy..So if you want the Power/Temp Target to work right, use PXOC or MSI AB..PXOC has it's bugs too.
