EVGA Precision X1 LED dim adjust
Ghost13
2019/04/12 21:00:59 (permalink)
One thing i think needs a bit of work or even added to a update, is the adjustment of brightness .
I`d like to dim the LED brightness, but the software dont have that adjustment..
All i see is just a color`s not brightness or dimming adjustment at all ..
5 Replies Related Threads
    BennyM
    Re: EVGA Precision X1 LED dim adjust 2019/04/26 06:54:51 (permalink)
    Hello,
    I can confirm the brightness slider within Precision X1 is working with the 20 series cards. Which graphics card are you using?
    • Ribbons : 282
    Re: EVGA Precision X1 LED dim adjust 2019/04/26 08:30:04 (permalink)
    Ghost13
    If you have PX1 Starting with the OS then Exit PX1 and wait a minute and then start PX1 back up and do you see the Color Block and Slider under the LED Tab at the Top?
    It is working fine on 3 of my rigs with RTX Cards installed.
    Ghost13
    Re: EVGA Precision X1 LED dim adjust 2019/04/26 10:14:09 (permalink)
    im running a 1070 FTW, but what id like to see is the slider adjust for the RGB lighting for the board Z390 FTW.  the LED lighting is brighton all the time, i would like to see a adjust slider to brighten/dim thru the board, not just the video cards.. ...
    • Ribbons : 282
    Re: EVGA Precision X1 LED dim adjust 2019/04/26 10:31:21 (permalink)
    Ghost13
     One has nothing to do with the other
    I turn mine off in the Bios, I like the Dark Side
    Ghost13
    Re: EVGA Precision X1 LED dim adjust 2019/04/26 12:33:46 (permalink)
    ya, my board i cant turn down the lighting the video card i can .  but the board is what i cant turn down, unless i darkin the color using the LED sync, and darkin it manually ..
    Me id like one control just to brighten or dim the Lighting with a slider and when using the PX1 program, nothing happens, with dimming the lighting not evne on the Video card.  its all turned full up ... i cant dim it ..
