EVGA Precision X Fan Speed ?
istore221
2013/01/17 02:56:30 (permalink)
What is the best method to keep my card cool
01 -
Using Auto mode software enhanced fan curve mode
02 -
when we want to play games Set fan speed upto 70% (Not auto mode) using manual system
in normal mode set fan speed to defualt value 30%
any suggest ?
will above options are harm to my vga or what ?
10 Replies Related Threads
    LeffE92
    Re:EVGA Precision X Fan Speed ? 2013/01/17 04:11:56 (permalink)
    I set it at around 50% at idle as I am used to fan noise and have it ramp to full speed at around 150F or so.
    The only thing is precision has to be loaded and in your tray for it to work, soon as the program is closed the card will default back to 30%.
    You can also use nvidia's performance ntune to set the card manually at certain fan speed before you game.
    It is more work but generally it honors what you tell it to do until you restart windows until you tell it to.
    johnerz
    • Ribbons : 7
    Re:EVGA Precision X Fan Speed ? 2013/01/17 04:32:25 (permalink)
    OK first what you asked will NOT damage you GPU :)
    Second I would consider having a Manual fan curve so that, when its idle the fan is low at 30% (minimum possible setting) and that as the GPU gets hotter the fan ramps up - but faster than at stock.
    I have
    30% to 30c ramping to
    75% at 55c then ramp again to max at 65c
    They throttle if too hot, so its best to raise the fan speed before this happens and as the fans are ok then you should not get to the temps where this happens
    After a few hours of Folding or gaming my GPU never exceeds 63c
    Benching of course can exceed this but as I only do that when my card is new to ensure its working correclty then no issues for me :)
    A bit of bedtime reading ;)
    http://forums.evga.com/tm.aspx?high=&m=1760467&mpage=1#1760467
    http://forums.evga.com/fb.ashx?m=1769993
    http://forums.evga.com/fb.ashx?m=1511014
    post edited by johnerz - 2013/01/17 05:03:40
    martinezdavid2004
    Re:EVGA Precision X Fan Speed ? 2013/01/17 06:41:12 (permalink)
    I use the automatic method with a curve made ​​by me never usually I have to change the settings to play
    michael-evga
    Re:EVGA Precision X Fan Speed ? 2013/02/14 21:01:08 (permalink)
    Hello evga forum!
    Exactly the thread I was looking for! I recently got a 670 FTW (love it) and am looking to make adjustments to keep it under 70c when under heavy load since thats where thermal throttling kicks in.
    The full 'auto' fan speed setting with no software in the loop runs the fan at a nice and quiet 30% level at idle, perfect for netflix. But under heavy load, with temps in the mid/upper 70s, the fan is only running at 55%, not so perfect for farcry3.
    I see the custom curve option in PrecisionX. Don't like that because it requires software (precisionx) to be running in windows to actually monitor temps and control the fan speed. Would like logic on the card to be handling 100% of this function w/o any program being in the loop (the cpu is very busy doing other things).
    I see the option to just enter a percent and have it run at constant speed. This is how i've been managing it.  With it set to 60%, generally stays under 70c. That works, but is somewhat tedious to set it up before gaming and take it down after.
    My question is, is there any way to get the GTX670 (in hw/fw, no sw in the loop) to be more aggressive about running the fan speed up as temps go up. I don't want a fancy curve, just a steeper ramp than the default one provided by 'auto' mode. So that at 75c the fan is running at 70% instead of 55%.
    If that more aggressive auto mode existed, I'd just leave like that always and it'd be perfect for netflix and crysis3 and whatever else.
    I think the answer to my question is "no", but thought I'd ask in case there's an option I don't know of?
    ps: I do have case fans: 2x 120mm intakes 1400rpm, 1x 120mm exhaust 2000rpm (regulated by cpu temp) pushing thru a radiator. Cool air supply in the chassis is decent, not so great as some folks with bazillion of fans, but adequate. Cool air is definitely available to the GPU. Its sits low in the chassis and an intake fan blows unobstructed in its direction from the front to the back of the case. I tweek the case fan speed settings for prior to gaming to cool more aggressively, but it would be nice to not have to tweek the GPU fan too.
    Cheers!
    i7-5820k @4.4, 980ti FTW @1467/7712, ASUS X99-PRO, Crucial Ballistix 2400 cl13, Silverstone 850W, Swiftech H240X
    i7-875K @3.9, 670 FTW @1267/6840, ASUS P7P55D-E-PRO, Crucial Ballistix 1600 cl8, Silverstone 750W, Asetek 550LC
    • Ribbons : 135
    Re:EVGA Precision X Fan Speed ? 2013/02/14 21:08:27 (permalink)
    michael-evga
    Hello evga forum!
    Cheers!
    If you only have one fan exhausting through a radiator, adding another exhaust fan might help considerably. Secondarily, the auto fan control on the GPU is controlled by the BIOS. Yes there are ways to modify this but, if it goes bad, you risk losing your warranty.
    michael-evga
    Re:EVGA Precision X Fan Speed ? 2013/02/14 21:31:19 (permalink)
    I've definitely thought about adding another out fan, push/pull on the radiator would fit (i think). I don't have the power pins on my MB to do it cleanly. I would have to drive 2 pwm fans off of one plug. Not sure that pwm power arrangement would really work?
    I should run it with the case open and an external fan blowing across it to get an idea of how effective more exhaust could be? Or maybe add some additional exhaust in an ugly (externally powered and kind of duct taped in place) way as an experiment. I do have a couple of spare case fans to play with (1600rpm slipstream + 1400rpm silverstone, both non-pwm).
    I do know that running the GPU fan up does keep the temp down considerably. Borderlands2 at 60% fan speed makes for a max GPU temp in the mid 50s (chilly). Farcry3 is more demanding. Another thing about my current manual process that I don't like is that I have to have a sense of how demanding a particular game is. Will 60% work for crysis3, not sure? Anyway... primarily, I'm looking to better automate that GPU fan guy.
    Can you tell me more about adjustments to the auto fan control in the BIOS? I don't want to load a 'hacked' unsupported BIOS, but if there are tools with which to set some params that the default BIOS reads... i think that's what i'm looking for!
    • Ribbons : 135
    Re:EVGA Precision X Fan Speed ? 2013/02/14 22:08:02 (permalink)
    michael-evga
    Depends upon your fans. Fan headers generally are limited to 1 amp. Most standard case fans draw less than 0.2 amps. So two, per header, would not be an issue. You can buy 3 pin fan Y splitters for a couple of bucks on Amazon. Like this
    I don't recommend modifying the BIOS to control your fan unless you have experience.  I've been modifying GPU BIOS for a few years and I still stay away from tweaking settings other than clocks and voltages as it only takes one little mistake to brick a card. Afterburner and Precision, when just used to control the fan, are not resource intensive. What most folks do is set up a fan profile based on temperature to always keep the GPU under 70C for the 600 series to prevent throttling.
    michael-evga
    Re:EVGA Precision X Fan Speed ? 2013/02/15 00:43:47 (permalink)
    I think I found what you mean by modifying the BIOS.
    * i would put a link here, but the system keeps stripping it out
    Basically patch the binary, altering the fan speed values, embedded in there and flash it back into storage on the device. I'm not gonna go there for this. If the fan ramp values were stored off on the side, in some kind of PRAM or NVRAM for the purpose of independent modification... that's what I was looking for. I'm not up to using some tool to recompose the entire BIOS image and then blast that back onto the card (and hope for the best).
    So barring BIOS hacking, I have the two options I came in with... software fan control... or constant speed. Ok, I can pick one of those poisons.
    I do wish the stock BIOS was a little more aggressive about cooling with this high-end factory overclocked card. Out of the box, it could fight harder to stay under 70c and still be super quiet at idle. My old GTX 470 was lazy about cooling too, would get up into the low 80s with the GPU fan no where near full on.
    Thnx for the pointers.
    post edited by michael-evga - 2013/02/15 00:50:08
    johnerz
    • Ribbons : 7
    Re:EVGA Precision X Fan Speed ? 2013/02/15 03:39:54 (permalink)
    The software fan control is the better option a straight line rising up from 30% at 40c to 70% at 65c should work well for you
    michael-evga
    Re:EVGA Precision X Fan Speed ? 2013/02/15 10:18:28 (permalink)
    Thnx for the pointers!
    I'll try the software controlled way of doing this with a simple ramp; the purely manual set to 65%, play, restore to auto when done works too. In either case, I have to do something extra prior to starting up a game since I won't be running (and don't want it to be) precisionX all the time.
    I'm looking at the custom curve settings screen. What sampling speed do we like? 5 seconds is the default, seems a little slow? Also the hysteresis setting and force an update on each period, any tips about those settings?
    At some point, I may look into a push/radiator/pull setup to get more exhaust? Need to experiment to determine how much of a difference that would make. But I'm not doing that any time real soon. One of the selling points of the FTW card for me was the blower style fan that exhausts out the back.
    for grins... falcon nw talon from 2010 with some upgrades...
    i7-875k @ 3.73Ghz (whenever its not idling at 1.4Ghz)
    fun new evga gtx 670 ftw! (mine max boosts to 1175) (old card was an evga 470)
    8G of 1600MHz cl8 crucial ballistix tactical ram
    asus p7p55d-e-pro
    asetek 550lc + 2000rpm pwm noiseblocker-multiframe (very quiet!)
    silverstone 750w psu + 2x 1400rpm case fans
    win7 64bit
    post edited by michael-evga - 2013/02/15 11:54:23
